Question about Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router
Can't call home phone
Just ordered vonage, got the router set it up but can't call my home phone. Why?
    Genius:
  • 1,268 Answers
Make sure your the internet is working fine on the router. If it is, you need to call vonage and have them activate the phone ports of the router. The phone ports on the back of the router needs to be registered first through vonage. That should do it.
Posted on Oct 17, 2008
I have comcast cisco cable that is working fine but when I hook up vonage I get no internet why?
More than likely you need to enable split tunneling on vpn settings in router. If Vonage uses a vpn tunnel like other VOIP services do, then it is probably encrypting all traffic on your Internet/WAN interface. With split tunneling enabled it will only encrypt traffic to and from Vonage. I'm making a few assumptions here, but it should be worth a check.
Jul 23, 2014 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Service Hook-ups...
1- in order of what connects to what
1- linksys connects to road runner modem. Should be a network connection on the back of the router that says uplink. This connects to the road runner`s wired port on the back of the unit.
Vonage phone will/should connect through the wireless section an in your personal wifi connection when you get the router wireless setup. Name your wireless something that other people are not using and then tell vonage phone to connect to that network.
Hope this helps
Feb 16, 2014 | Linksys E3000 Wireless Router
My desktop has a local area connection with limited to no connectivity. I had my desktop pc connected to a netgear n900 router and a vonage phone connected to the router's lan1 port. This caused i
Did this connection ever work before? I have a similar setup with Iristel and once in a while it goes down (Hurricane Leslie generated the problem last week).
Check whether the setup works without the Vonage device. This will tell you whether the problem is with your router or the Vonage box. If it works without the Vonage, the problem is in the Vonage box, you may find a good time to call Vonage for support.
I don't know whether the Vonage box (in my Iristel case it's a mediatrix 2 something) has to 'call home' before it lets your router set itself up.
If your router does not work without the Vonage, you have a simpler problem, the router is the issue. You can reconnect the Vonage and if the phones work, this confirms that the router is the problem. At least you can use the phones.
With the router, you need to log in to the admin screens and poke around until you find the problem. It is always a good idea to only change one thing at a time and always remember what changed immediately before the problem was noticed.
Sep 16, 2012 | Gateway Computers & Internet
Can you help me set up my home computer my time warner modem n vonage modem with my belkin router?
So you are trying to set up the router.
you can connect the router to the modem and the computer to the router.
Set up your router properly sothat your computer can go online through the router.
Pnce your computer is online through the router, then connect the Vonage to the router and it should work.
First make sure that your computer will be able to go online when connected directly to the Time Warner cable modem.
Click Here for step by step solution on how to set up router.
Nov 04, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Firewall block
you don't if you are sensible. Set the firewall with the correct ports instead, ask vonage for the port settings you need.
Oct 31, 2009 | Linksys VOIP VONAGE PHONE ADPTR 2-PORT...
Wireless network gets disconnected
i believe it supposed to be
modem--> vonage -->router
-->phone
Jul 18, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
My in-laws have vonage telephone service with comcast internet, before they just had at&t with no problems. Now when they are having a telephone conversation the connection seems to cut in and out and...
With choppy audio and one-way audio, either party on the call hears the audio breaking up, or no audio at all. Dropped audio is when a call is in session and both parties are unable to hear each other.
  • From your Vonage account, there is a feature called the bandwidth saver. This feature controls the amount of bandwidth used for a phone call. Try adjusting the bandwidth saver to either medium or normal. After you adjust your settings, test and see if there is a difference in the audio quality. Please note that when you change bandwidth saver it could take a few minutes for the device to reboot and take the changes. From your Vonage account, there is a feature called the bandwidth saver. This feature controls the amount of bandwidth used for a phone call. Try adjusting the bandwidth saver to either medium or normal. After you adjust your settings, test and see if there is a difference in the audio quality. Please note that when you change bandwidth saver it could take a few minutes for the device to reboot and take the changes.
  • Reboot all of your devices (Vonage device, any routers and cable / DSL modems). How Do I Restart My Phone Adapter and Network Devices?
  • Ensure that your Vonage device is at least four feet away from any other device.
  • Ensure your Vonage device is in a well ventilated area to keep from overheating.
  • Ensure no file sharing, P2P applications, or large downloads are running while you are using the phone. These activities can use up most of your bandwidth, leaving little left for your calls.
  • Connect your Vonage device directly to your cable / DSL modem, if it is not already. If this helps the audio quality, then the problem is occurring between the Vonage device and modem.
  • If your Vonage device connects to another router and not directly to your cable / DSL modem, try disabling any firewalls or SPI (Stateful Packet Inspection) on that router. Click here to learn about firewalls and SPI.
  • If you wish not to disable your firewall, then you can port forward the Vonage traffic to the adapter. Click here to learn about port forwarding.
Wireless Routers and Cordless phones — If you have a wireless router and a cordless phone:
  • Ensure all wireless devices and cordless phone bases are at least four feet away from each other.
Home wiring — If you are using home wiring:
  • Ensure the land line has been disconnected in the Demarc box. Ensure the land line has been disconnected in the Demarc box.
  • Ensure there are no more than five phones connected through the house wiring. The signal fades as more phones are connected to house wiring.
  • Test with one phone directly connected to your Vonage device. If this fixes the issue, there may be a problem with your house wiring.
If you have made it through this checklist and you are still experiencing an audio problem, our first class customer service is available to assist you. Please have handy your account ID, phone number, name of your internet service provider (ISP), and model numbers for your Vonage device and any other devices in your network.
Dec 03, 2008 | Vtech mi6896 Trio Cordless Phone
Vonage does not work with D-Link router
If you plugged a telephone into your D-link router, unplug it - that can not work!
You have to plug your vonage router (WAN port) into the D-Link (LAN port) and connect your phone to one of the LAN ports of the vonage router.
If you do not need the wireless capabilities of the D-Link, you can simply take that one out and only use your vonage router.
If you need more help, I would need more details form you:
Which vonage adapter are you using?
How is your setup (i.e. modem -> D-link -> vonage & computers)
What connections are you using (wire/wireless)?
You can also find help here.
Jun 17, 2008 | D-Link DI-704P Router
Have vonage fax and phone service
I am new in the network field.How can i set up a LAN net work using 5 hosts.What are the devices that I need to set up this net work?This is my email address.You can send it there:tunjiman23@yahoo.com.Mnay thanks
Apr 02, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Linksys VOIP VONAGE PHONE ADPTR 2-PORT PAP2 Router Logo
109 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
