Question about GoVideo DVR4300 DVD Player/VCR
I cannot get my DVR4300 to go in to TV channel change mode while recording a program
I am recording the current channel's program. The manual says I can watch another television program while I am recording by pressing TV/VCR to switch to TV mode. I should be able to select a different channel on my TV. Nothing happens. I am literally locked in to the channel I am recording from. HELP!!
  • 22diamond Oct 15, 2008
    Thank you. Makes sense. In reading the manual, it gave the impression that the vcr remote could function as the tv channel changer as well.
    Sergeant:
  • 196 Answers
Why not simply record a channel tuned into the vcr and use your tv remote to watch a channel tuned into your tv? that is how it is normaly done... don't forget a vcr/pvr/dvd recorder has it's own channels just like a tv does... just no screen of it's own the tv has of course it's own channels and in fact does not even need to be switched on in order for your recorder to record a program neither does the recorder need to be on to use your tv
Posted on Oct 14, 2008
CANNOT GET PHILIPS DVDR3305 TO RECORD ON PANASONIC TV.TX-L37D25B WHILE WATCHING ANOTHER CHANNEL?.
What is your source? Since the DVDR3305 has an analog PAL tuner and most TV stations are broadcasting in digital, you probably have some sort of set top box connected to the recorder. If you change the channel on the set top box, you will record the program on the new channel. If you are recording PAL and your TV has a PAL tuner, you should be able to just record one show while watching another with the DVDR3305 daisy-chained to the TV. Just make sure to change the TV channel not the channel on the DVDR3305.
If your TV has a digital tuner, you can split the signal before the set-top box to record one channel and watch another. (Note: basic splitters will cause some extra loss of signal and may reduce a digital signal below the threshold needed to tune in the signal. An amplified splitter can avoid this - when the amplifier is working properly.) Otherwise, you need a second set-top box (or a dual tuner set-top box).
On my set-up with an aerial antenna, I would put the splitter between the wall jack and the electronics. The incoming cable goes to the splitter, then cable 1 goes to the TV. Cable 2 goes to the set-top box. Tune the set-top box to the channel to record and check the settings with the TV set to the DVD source. (DVD set to record on Tuner (and the specific channel of the set-top box output) or front s-video or EXT1 or EXT2.) Then change the TV back to the TV source and change to the channel for the second program.
The manual for the DVDR3305 is available from Philips. The link to the manual is http://download.p4c.philips.com/files/d/dvdr3305_05/dvdr3305_05_dfu_eng.pdf .
I hope this helps.
(I actually use an A/B switch and do not try to watch a second program on the TV connected to the DVD recorder. However, most of my recordings are for time-shifting of programs that air when I can't watch any TV program.)
Apr 29, 2012 | Televison & Video
We just dvrs hooked up a few weeks ago.when I am recording somthing down and my daughter goes upstairs to watch her tv and tries to change her channel to watch somthing a message comes up on the tv that...
Hi, poog_23350, I caught your post! How a Duo DVR receiver works is that the TV you have it set to record on will not allow you to change the channel while the recording is in progress. The other TV, that isn't recording anything, can be used freely to flip through channels.
In this case, it's TV2, the one upstairs in your daughter's room, that's currently set to record on while the downstairs TV is free to use. This can be adjusted by pulling up the Main Menu with the Menu button on the remote, selecting option 8, then option 5, and changing the TV1/TV2 setting there on the Record Plus screen.
If you'd like a receiver capable of allowing channel changing while recording a program, our VIP 612 receiver is a Solo receiver that acts like a Duo. What this means is that it has one TV output and two tuners. Along with being able to change channels while a recording is in progress with this type of receiver, you can also record two programs on two different channels simultaneously.
Hope that helps!
Aug 29, 2011 | DISH Network DVR-625 DTV Receiver /...
Programming TV-channels on old Samsung VHS video recorder VB-520T
I tried another position of te range switches and scanned again and again and then I found the tv channels finally.
Mar 25, 2009 | Televison & Video
Lost the manaul for GO.VIDEO DVR4300
Hi well you can get a online version of the manual its the same thing go to http://tv.manualsonline.com/manuals/mfg/govideo_1/dvr4300.html and click on get manual I hope this helps.
Feb 24, 2009 | GoVideo DVR4300 DVD Player/VCR
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
How to record TV program while watching another
how are the cable hooked up? Is there a TV/VCR button because once you start recording, it is at VCR mode, and you need to hit the TV/VCR button to get you back on TV mode,so that you can watch TV.
Jan 03, 2008 | Polaroid PDM-1058 Portable DVD Player
Copying vhs to DVD
unfortunly this model of dvd vhs combo cant record vhs to dvd it can only copy tv to vhs sorry.
Dec 21, 2007 | GoVideo DVR4300 DVD Player/VCR
DVD4300
Be advised that this unit, the Go-Video DVR4300, is a combined VCR (video cassette recorder) and DVD Player; it does not record DVDs. Only a DVD Recorder unit will serve your need.
Instructions for recording to VCR from TV is in the manual.
Dec 14, 2007 | GoVideo DVR4300 DVD Player/VCR
GoVideo DVR4300 DVD Player/VCR Logo
142 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
