Question about Singer 3116 Simple
Bobbin not picking up through the needle part of the machine
I have a singer simple 3116 my bobin thread wont pick up through the needle part of my machine I have taken apart the bobbin part thing at the bottom that houses the bobbin and have put it back just like it was thinking that that would help but when I watched it from slow motion the needle would come down but not catch the bobbin thread like it is supposed to. please help.
  • 2 more comments
  • lewis_russ Nov 08, 2008
    i have the same problem as lisa. how do you get your machine retimed?
  • rvblackelk Nov 17, 2008
    Mine is also not picking up the bobbin thread.
  • charley3116 Nov 28, 2008
    I have a similar problem with a different outcome.
    The needle DOES pickup the lower thread, but with observation I noticed the bobbin assembly does not rotate far enough (clockwise motion) to release the the lower thread past the bottom center.
    Since the thread does not make it past the center point at Bottom center, it moves back (counter clockwise) to the pickup location and catches a second loop thereby causing the machine to lock up.
    The machine is 3 days old and worked fine, I've used light broadcloth with no heavy fabrics.
    I need to know if this is common and do I need how to correct this issue for future use, or should I buy a different brand or much older Singer sewing machine?
    A service manual would be nice for the small problems.
  • Anonymous Mar 30, 2014
    bobbin thread wont catch
Thread only shows the bobbin thread when i sew and needle thread also please e-mail me the attachment instructions. marybellroberts@msn.com
Posted on Nov 09, 2008
How do I put the bobbin and parts back together so the needle picks up the thread?
Time to visit the local dealership. I wouldn't try to replace it myself. Too many things can go wrong. Find local dealerships on official website or inside the user's manual: Singer Simple 3116 manual Download Free Manuals
Oct 11, 2015 | Singer 3116 Simple
Simple singer 3116 isn't picking up bobbin thread
needle needs to be in correct position. try threading from other side.. if in correct position.
Feb 17, 2015 | Singer 3116 Simple
My singer simple the needle hits the bobbin and my needle thread will not pick up my bobbin thread. what can I do?
change the needle to see if that will take care of the problem
if it doens't then the machine needs to be checked at a sewing machine shop about the timing
May 28, 2012 | Singer 3116 Simple
My needle wont pick uo bobbin thread
Check the needle. Is it the right size? Right type? (for the fabric). Put in correctly? If sewing though thicker material you need a bigger needle.,
Check the bobbin tension and make sure it isn't too tight. Also make sure it is wound correctly. Does it pull through by hand when you pull on the thread?
Then check the top tension and make sure it isn't too tight or too loose.
Those are the most likely problems.
Apr 09, 2011 | Singer 3116 Simple
My threaded needle will not pick the bobbin thread??
In most cases the reason for that is the needle is not in the right way. Turn your needle around and check to make sure the bobbin case is completely inserted in the machine and it clicked in.
Mar 14, 2011 | Singer 3116 Simple
When running the machine, the needle does not grab the bobbin.
check your needle to see if it's damaged
make sure you have a 3-5 inch tail on the bobbin thread
then make sure you have a 3-5 inch top thread tail, then hold the top thread tail in your fingers (away from the needle) & turn the handwheel on the right hand side of the machine slowly letting the needle down in the bobbin area & see if the bobbin thread will pick up that way
Sep 27, 2010 | Singer 3116 Simple
Cannot pick up the thread from the bobbin.
first make sure that the needle is put in correctly the flat of the needle is to the back of the needle bar
Jun 30, 2010 | Singer 3116 Simple
My Simple Singer sewing machine will not thread the bobbin thread. For some reason it will not pick up the bobbin thread from the bottom of the machine, does anyone know how to fix this problem?
Your needle may be in backwards, flat side should face rear of the machine or you bobbin is unwinding in the wrong direction, refer to your manual and dvd. Call Singer at 1-800-4singer if problem persists. Good luck
May 30, 2010 | Singer 3116 Simple
Singer 3116. There seams to be a timing Problem, The needle thread won't pick up the bobbin thread. How do I adjust the timing.
I would check my video dvd that came with my machine again, and manual, also make sure that your needle is inserted with the flat side away from you, I don't think it is in the timing.
Feb 04, 2010 | Singer 3116 Simple
Bobbin thread wont pick up
Be sure needle is inserted correctly with the flat side in the proper position. Rethread the machine and try again. If it still won't work you have a timing problem which requires a technician or a good mechanic.
sewman7
May 15, 2008 | Singer 3116 Simple
Singer 3116 Simple Logo
592 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
