Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
Removing doors from a samsung rsg 5 dumh american fridge freezer
Ihave purchased a samsung american fridge freezer and think i will have problems getting it in the doorway. can i remove the doors to enable it to get in my kitchen.
  • Anonymous Mar 23, 2014
    I got a WSE 6970 side by side and have to move from a house into a apartment, the kitchen door is only 70cm wide and the fridge 84,5cm including doors, but only 60,0cm body alone.
    Have to remove the doors.
    Is it simple/ what is with the electric at the freezer door where the electronic is located?
    President:
  • 1,462 Answers
Doors are removable. wiring to the door is plug and socket
Posted on Oct 15, 2008
  • si pooley Aug 16, 2013
    thanks pal
Why is ice forming under the bottom drawer of my Samsung American fridge freezer Rsa1shpn and then water eventually leaking out the door? I have defrosted the fridge freezer but still have the problem
There is a drain tube located under the panel of most freezers. If that clogs up, the auto defrost can't work. The freezer defrosts by evaporating all the moisture out of the compartment. So, check that first. Secondly, a leaky door seal can also cause that problem. You can order door seals online or on Amazon.
Oct 17, 2014 | Samsung Freezers
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
SAMSUNG RS21 AMERICAN FRIDGE FREEZER SOUNDS LIKE A GENERATOR RATHER THAN A FRIDGE AND NOT SHOWING CORRECT TEMPERATURE ON READINGS. FOOD BARELY FROZEN AT TIMES BUT FRIDGE PART SEEMS OK. ANY IDEA'S?
Ring samsung up because this is a common fault in that make. I had the same problem, They should do something depending on when it was purchased ( 2005-2006 i think it was) it was on watchdog.
Nov 12, 2009 | Refrigerators
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung RS21DCNS Fridge not getting cold
0845 726 7864 samsung know of this problem and are doing free fixes to all of them just phone the number it doesnt matter about the warranty as they have extended them all free to 5 yrs.
There are numerous problems including noisy fan that stops when doors open to no water and all are free to fix.
Hope this helps.
Sep 01, 2009 | Samsung RS2556 Side by Side Refrigerator
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Samsung fridge freezer
hey gordon is this model 4 drawer electronic control with the display in the ice door
Feb 16, 2008 | Refrigerators
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
2,048 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
