TV not working ~ no response to power button on unit or remote. Checked fuse at power line/circuit board ~ not blown. Mitusbishi Model VS-50705
  • lovesun123 Oct 14, 2008
    How difficult to replace power supply? How expensive?
    Thanks!
    Master:
  • 538 Answers
Time and materials..around 2 hours..with the right tested power supply...of course, having the right tools helps too..is that what you had in mind for this adventure?
Posted on Oct 14, 2008
  • 282 Answers
Most of the time the convergance ic go bad:
but try this:
The 3 flashes of the led when you plug the unit in is the
microprocessor initializing.
This unit has an error code diagnostics.
On the front panel of the unit press and hold the INPUT and MENU
buttons at the same time and hold them down for about 5 or 6 seconds.
The unit should activate it's error code mode.
The led will flash count the number of flashes. It will then pause for
1/2 or 1 second. The led will flash again count the number of flashes.
The unit will repeate this for about 5 or 6 times.
You now have the two digit error code. The first time the led flashed
is the first number of the error code, the next time the led flashed is
the last number of the error code.
12 ----------- indicates no error
21 ------------- X-Ray Protect circuit
22 ------------ Short Protect circuit
23 ------------- Horizontal Deflection failure
24 ------------- Vertical Deflection failure
Most units give a error code "22" short protect circuit. If so check:
Q5A00
C557
If Q5A00 check bad there are other parts that have to be checked or
replaced.
If you are able to do above call a tech to service the unit
source :http://www.fixya.com/support/t293427-mitsubishi_vs_50705_50_inch_rear
    Guru:
  • 558 Answers
Since when this problem arised, is anything wrong goes with it during this period.
Check out the powersupply.. and hold it off for 10 minutes.
Then replug the system and push the power button on.
If you are able to check out its internal wiring and PCB Board, then check the control board.
NOTE: Caution hazardous voltage remain inside TV, better to plug off before taking any action.
Regards
Ellin
  • 52 Answers
Most of these rear projection tvs need some type of service repairs at 5-6 years old+ and if this tv has been dropped even a few inches lately, then that could cause the board to crack and not power on. ive heard of some cases when some acid has dropped onto the board rendering it inoperable. Unfortunately, Mitsubishi (or anyone else) stocks replacement boards for that particular model. you should have a service repair guy come in and take a look at it or you could look around the vast recources of the fixya forums and see if you can get anymore answers. good luck with the tv!
ionfreek458
  • 19,396 Answers
Check if there is continuity in the power cable.
  • Ginko
    Ginko Oct 14, 2008
    Check first if the power cable is good, test a different socket.
    If you have a multimeter you can also test the power cable for continuity, check also if there had been a short on the power board where power cable connects.
    If that is fine , probably you will need to replace the power board.
    You can get the part at shopjimmy,
    or contact Mitsuparts
    If you want to call a technician you can call the number printed on the owner manual.
    Sergeant:
    Champion:
  • 334 Answers
Most like bad power suplly
  • nick helpap
    nick helpap Oct 14, 2008
    sumwhat hard and 60 bnucks to 300 bucks
  • nick helpap
    cheak ebay for ones once u get old out type in #s on ps in ebay see if sumone has used onet thats been tested good ok
DAIKIN Aircon Multi Unit - One head unit not working, others are fine. No lights or response
Check for power at unit . If there is power to unit check for blown fuse on circuit board or bad board .
Nov 11, 2014 | Heating & Cooling
Vertical bars and lines run up and down the screen. Need service manual or parts outlet
There is no such thing as a "vertical sweep circuit board" in that set. The vertical circuit is part of the sweep module. And BTW that type of symptom is more often a power supply filtering problem anyway.
May 05, 2009 | Mitsubishi VS-50705 50" Rear Projection...
VS-50705
Power off is when you press the switch.
Shut down is when you turn off from remote and TV stays in standby with led on.
Jul 18, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Rolling picture
Try replaceing capacitors C2C52 10uf 50V capacitor and also C2P05 100uf 16V capacitor. these are both on the signal board. It that doesnt correct the issue replace IC2P01 which is the 9volt regulator also located on the signal board. That should take care of your problem
Jun 08, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi YS-5075
yes, this sounds like a fuse blown or open. What model is this a VS or YS?
Mar 10, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Mitsubishi vs 5075
THIS MODEL IS EQUIPPED WITH A KEYBOARD LOCK FEATURE; THIS CAN BE MISTAKEN AS A NO POWER CONDITION. TO UNLOCK THE KEYBOARD PRESS AND HOLD THE "MENU" BUTTON ON THE FRONT PANEL FOR 10 SECONDS
Oct 11, 2007 | Mitsubishi VS-50705 50" Rear Projection...
No Blue. Horizontal Lines.
Not to me, but it also depends on if you could do this yourself or not. And the area you are in sometimes is responsible for the cost being high.
Sep 02, 2007 | Mitsubishi VS-50705 50" Rear Projection...
Cant get the tv to power up
I'm having the same problem. No power at all, tv was working fine and shut off by itself WS-65517. Please help!
Oct 15, 2006 | Mitsubishi VS-55601 55" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
