Question about Audiovox FR2302 2-Way Radio
Only get static when trying to receive transmission
When trying to receive transmissions all we get is static on radios, we have tried all channels and they have different pitches of static or squeals.
  • 55 Answers
Turn the squelch knob eathier up or down to eliminate the static.
Posted on Nov 08, 2008
I get static and distortion in Stereo mode.
if you are reffering to a radio fm receiver, the issue is the signal strength is too the multiplex transmission cannot be correctly unscrambled.mono reduces the cross channel interference.
use a high gain 12 db or above external vhf antenna to solve this problem
Jul 29, 2014 | NAD 7140 Stereo Receiver With Phono Input
Cobra frs 104
look in the battery compartment for a series of tiny switches under the batteries.. these switches must be identical for each puts them on the same frequency..then select channels with no interference..retry radios..
Jan 26, 2014 | Cobra FRS 250 (14 Channels) 2-Way Radio
I have 2 SX709 handsets. When set to a number other than zero (on any channel) they communicate between each other well, but can't receive transmission from other sets. When set to zero, they will receive,...
Sounds like a receive sensitivity issue. The radio you have with the static is likely very sensitive to other RF (radio frequency waves) in the area. Turning on the interference eliminator code (setting it to a number) blocks out this unwanted noise. This radio is not repairable, and there is no fix for this problem. The only fix would be to set the "other sets" to have the same code.
best regards.
Mar 14, 2011 | Motorola Talkabout T5720 (7 Channels)...
BellSouth 1010 walkie talkie receives constant static
you have opened up the squelch - refer to the manual to close and return radio to normal operation
Aug 27, 2009 | BellSouth Radio Communications
Has static and cannot hear transmission
sounds like it is off frequency and needs retuning
Nov 23, 2008 | Northwestern Bell 99141 2-Way Radio
Cobra MicroTalk PR-3550WX - Static after transmission
Dear sir, try to operate ur radio in different channel ,( ur operating area seems to be have so dense radio smog ..if u are located near some border where ur adjacent frequency is in use this cud be the problem .
first try in low power channel ( 8-14) ..if it solves ur problem ok ur u try to contact ur seller , & get it replaced if its under warrenty period.
May 26, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
FR60 intermittent transmission
Hello snorker,
It could be battery / power issue. Two-way radios draw much more power when transmitting then receiving. If the batteries are weak the radio might work perfectly fine on receive and then cut-out when you depress the Push-To-Talk.
Best Regards,
Go Ahead. Use Us.
Apr 30, 2008 | Motorola Talkabout FR60 (14 Channels)...
Long range mode
For the Cobra PR4700WX:
The user's manual is available here
To turn on/off the long range mode - (If you are referring to low & high power); Press and hold the Hi•Low/Enter button for two seconds.
Alternately, if you are referring to the Light/Max Range (receive sensitivity), 3 options:
1. To briefly turn off auto squelch - Press the Light/Max Range button for less than five seconds. If you hear two beeps, you have turned the maximum range extender on.
2. To turn maximum range extender on - Press and hold the Light/Max Range button for at least five seconds until you hear
two beeps which indicates the maximum range extender is on.
3. To turn maximum range extender off - Press and release the Light/Max Range button or change channels.
Probable reason that "fishing was all right but for hunting there is to much static" is becasue these radios operate on line of sight principle. Anything that obstructs the linear view would reduce signal strength/range. There is not that much obstruction when fishing compared to that when hunting in the woods or rough uneven terrain.
Please note that when using Channels 1 through 7 and 15 through 22 on high power, the Hi icon will be visible on the display. When using those channels on low power and on Channels 8 through 14, the Low icon will be visible on the display.
For the Cobra PR3500DX:
The user's manual is available here.
The transmission message icon off when not in use - this icon will only display if the radio is receiving something or if your are pressing the PTT button.
The other three the transmission signal is on at all times - indicates that either you are transmitting (unlikely) or the radio is in constant receive mode (most likely). I would venture a guess that the Auto Squelch is switched "OFF" or Maximum Range is switched "ON"
Both the 4700 & 3500 has Power Saver and it is a built-in feature. Your radios have this unique circuit designed that extend battery life. If there are no transmissions for 10 seconds, the radio will automatically switch to Battery Save mode and the Power Saver icon will flash in the display. This will not affect the radio’s ability to receive incoming transmissions.
Hope that this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Nov 07, 2007 | Cobra 22 CHANNEL 2-WAY RADIOS
Motorola FV500 2 way radio can send/cant receive
Do you hear the Beeps on the speaker? Check for the QT and the code squelch are the same in both radios, try to set code squelch in "0". Make sure that the radio is not receiving or the other one is not transmiting, with two radios will see the same.
Aug 09, 2007 | Motorola FV500 2-Way Radio
Motorola t5000
If you have already checked both radios have the same code and channel both radios must reicive and transmit between each other check if you have any QT in any display this is a third condition to reicive.
Jun 06, 2007 | Motorola TalkAbout T5000 2-Way Radio
Audiovox FR2302 2-Way Radio Logo
378 people viewed this question
Top Audiovox Radio Communications Experts
john milligan
Computer Repairing
Computer Repairing
Are you an Audiovox Radio Communication Expert? Answer questions, earn points and help others
