Re: removal and instalation of seats rear and front
First slide the seat to the back. You will find a bolt in the track on both sides. Remove them. Then move the seat forword and you will find 2 more bolts in the rear of the track. Be careful of the wires as you remove the seats! Frankster016
For 1990 Geo Storm 2+2 1.6L MFI SOHC 4cyl the OBD Diagnostic Link Connector is located front seating area, passenger side, under dash, above kick panel, mounted rear of glove compartment.
Hi, follow the instruction below...... Rear See Figures 3, 4, 5 and 6
Remove the lower seat cushion by pulling straight up on the front portion and disengaging the clips. Then hinge the seat upward to release the rear clips.
Fig. 3: Pull up on the front of the lower seat cushion and disengage the clips
Remove upper rear seat back-to-chassis bolts.
Fig. 4: Remove the bolts behind the center armrest ...
Fig. 5: ... and the bolts on the lower corners ...
Fig. 6: ... Then pull up on the seat to disengage the three clips on the top of the seat
Remove rear seat back by tilting forward and pulling straight up.
To install:
Install the lower seat cushion and torque the lower rear seat-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm).
Install the upper rear seat back cushion and torque the upper rear seat back-to-chassis bolts to 15-20 ft. lbs. (21-26 Nm)
the rear clips.
disengage the clips
To install:
Some of the rear seat lower pieces were bolted to the floor with 2 10mm bolts facing the front of the car one behind or inlign with each of the front seats the rest of the lower seat halfs are released by pushing the front part of the lower seat in the same area while pulling up there are pieces of metal that catch on hooks that are part of the floor/body
Retractor and Tongue—Sedan
SPECIAL SERVICE TOOL(S) REQUIRED
Description
Tool Number
Safety Belt Bolt Bit
T77L-2100A NOTE: Safety Belt Bolt Bit T77L-2100-A should be used for safety belt removal and installation.
Removal
Remove rear seat cushion. Refer to Section 01-10 .
Seat Cushion, Rear
Sedan Removal
Apply knee pressure to lower front portion of the rear seat cushion. Push rearward to disengage rear seat cushion pad and frame (600A88) from rear seat cushion front retainers (63370).
Remove rear seat cushion from vehicle.
Remove rear seat back. Refer to Section 01-10 .
Seat Back, Rear
60/40 Split Bench—Sedan Removal
NOTE: Safety belt bolts do not secure seat back to vehicle.
Remove rear seat cushion as described.
Fold down back seat and remove two bolts in the center of each seat back striker plates.
Remove two bolts from outboard rear seat back frame retaining brackets.
Lift seat back up and pull forward to remove from vehicle.
Remove panel (52018) and quarter trim panel (31012). Refer to Section 01-05 .
Trim Panel, Quarter—Sedan
Removal
Remove rear seat. Refer to Section 01-10 .
Pull up on rear section of rear door scuff plate that overlaps lower quarter trim panel.
Pull lower quarter trim panel away from body.
Remove safety belt retaining bolt.
Feed safety belt through lower quarter trim panel.
Remove safety belt anchor plate-to-sill bolt from quarter panel.
Remove retractor anchor nut and retractor from rear quarter panel.
Remove upper seat belt anchor bolt and anchor from upper rear quarter panel.
Slide anchor plate end of safety belt through the openings in the quarter trim panel.
Remove outboard front safety belt retractor and tongue (611B08) from the vehicle.
Item
Part Number
Description
386277-S190
Bolt (Part of 611B68)
Upper Rear Quarter Trim Panel
611B60
N800937-S190
Nut
5
389370-S190
Bolt
6
Rear Quarter Panel (Part of Body)
7
52018
Lower Rear Quarter Trim Panel
8
Mounting Stud (Part of Body)
Remove seat belt anchor bolt and retractor and tongue from rear deck panel.
Installation
To install, reverse Removal procedure.
Make sure the safety belt webbing is not twisted. If it is, remove the twist.
Tighten retractor anchor bolt and safety belt anchor plate-to-sill bolt to 34-46 Nm (25-33 lb-ft).
I think you have to remove headrst bfore folding seat back down. You may have to unbolt seat from floor. 4 bolts.
Rear Seat Backrest —Split Bench
Removal NOTE: The 40% rear seat backrest must be removed before the 60% rear seat backrest. 40% rear seat backrest
Remove the 40% rear seat backrest.
Remove the nuts and bolts.
Remove the backrest.
Remove the 60% rear seat backrest.
Remove the nut and bolt.
Installation NOTE: The 60% rear seat backrest must be installed before the 40% rear seat backrest. 60% rear seat backrest
NOTE: Do not tighten the nut and bolt at this time. Install the 60% rear seat backrest.
Install the rear seat backrest.
Install the nut and bolt.
NOTE: Do not tighten the nuts and bolts at this time. Install the 40% rear seat backrest.
Install the nuts and bolts.
60/40% rear seat backrest
Tighten the 60/40% rear seat backrest nuts and bolts in the sequence shown.
40% Rear Seat Backrest
Tighten the 40% rear seat backrest nuts and bolts in the sequence shown.
it is not designed to be removed. It is designed to slide back and forth as needed.
Section 01-10: Seats and Tracks
1998 Villager Workshop Manual
REMOVAL AND INSTALLATION
Seat, Rear
Bench Removal
Remove the center seat(s) if equipped. Refer to the procedure in this section.
Slide the bench seat forward to the center row seating position.
Use a flat-blade screwdriver to remove the cover caps from the front of the rear seat cushion latch cover.
Remove the two rear seat bolts from the front of the rear seat cushion latch cover.
Lift the rear seat cushion floor cover on the back of the rear bench seat and remove the two inboard rear seat bolts and the two outboard rear seat bolts.
Remove the bench seat from the vehicle through the body side door opening.
