Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson DC01 - can't get starter button switch off.
The yellow starter button isn't pushing down hard enough on the starter switch to make the motor stay on. As soon as I let go of the button the Dyson turns off. I got a new switch and still have the problem so assume I need to get a new button - but how do i get the old one off?
  • 3 more comments
  • smselzj Oct 18, 2008
    I have a similar problem, we have to tape the button down with a small toy in order to use the vacuum, would like to make the repair my self.
  • Anonymous Oct 25, 2008
    We have the same issue with our purple Dyson...the red switch that turns the vacuum on won't stay engaged...we haven't had it for a year. :0(
    I can't believe this...
  • ccarzoo Nov 01, 2008
    Wow, I have a purple Dyson, and I have the same button... It's a shame a 500.00 vacuum has to be jimmy-rigged to work properly.
  • Anonymous Nov 06, 2008
    We've had ours for less than a month. The switch wouldn't stay in the on position. After waiting on hold with Dyson for over 20 minutes, I hung up and took it back to the store and exchanged it for another one.
  • aniachka Nov 30, 2008
    Thank you - I resolved the problem - I just removed the yellow button! Now I turn it on by pushing the switch directly. There's a hole but at least I can use the machine.
  • 65 Answers
This issue is known well with dysons to be honest you will continue to have this problem for as long as you have the vacuum. they use substandard plastic parts which break easy. You will have to replace the button and make sure there are no other broken pieces of plastic in the housing before putting it back together.
Posted on Nov 30, 2008
Troubleshooting dyson dc01 upright hoover
If you are referring to the bearing cover on the wheel, this appears to be purely cosmetic. The disc is clipped onto the wheel and can easily be replaced IF you have not broken off the latches.
Aug 19, 2014 | Dyson Vacuums
Reset switch location
the reset button is in the on switch what you need to do is unplug from wall socket then press the on button down hard to reset.
Aug 14, 2013 | Dyson Vacuums
My dc01 upright does not pick up dirt as well as when I first used it (new) after many years of faithful service. I regularly disassemble barrel and wash it and clean turbine head and clean filters. Does...
Sorry to hear of your problem with your DC01. Although it sounds as if you've already checked your machine over quite thoroughly, you might find it helpful to visit the Support section of our website to ensure you've covered everything:
http://www.dyson.co.uk/support/help.asp?article=1919&product=DC01-SY-STD
Unfortunately, we are no longer able to supply spare parts, or carry out service or repairs for DC01 and DC02 machines.
However, as the owner of a DC01, you can receive £100 off selected Dyson Ball™ vacuum cleaners, or £70 off selected other Dyson vacuums. We'll also collect and recycle your old machine.
If you have any questions about this offer or would like to discuss this further, please call 0800 954 0153.
Kind regards,
Jack
Dyson Customer Service
Jul 21, 2011 | Dyson DC08 Hepa Allergy Bagless Canister...
How do I get the barrel off to empty my Dyson DC01
At the bottom of the clear cylinder, at the front in the middle, there's a yellow tab, or lever. If you push that down, the cylinder can swing out. The clear cylinder can be slid out downwards, you may have to wiggle it a bit.
Just out of interest, if you wish you can swing the cylinder right up, and the hinge at the top will pop off; that might make it easier for you (you can hold the cylinder between your feet and pull the other part off the top of it!), but it's a bit stiff to push it back on, and I always worry that I'm going to hurt it when I do it with mine.
Mar 24, 2011 | Vacuums
Just put together my dyson dc25 and beater bar wont spin
The brushbar on your DC25 can be switched on for vacuuming carpets, or off for vacuuming hard floors.
To turn the brushbar on or off, use the silver button located to the motor on/off button. Information on how to operate DC25 is provided in the user guide supplied with your machine. You might find this link useful if you don't have your user guide to hand: http://www.dyson.co.uk/support/help.asp?article=1575&product=DC25-ALLFLOORS
Hopefully this should resolve your issue. If you require any further advice on using or maintaining your DC25, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), so we can provide the assistance you need.
Kind regards,
Jack
Dec 09, 2010 | Dyson DC25 All Floors Bagless Upright...
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC01 Blocked Hose
unclip the hose and push a garden hosepipe throughit. that will clear any blockedge in the dco1 hose.
Jan 07, 2009 | Vacuums
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
856 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
