Question about Maytag MDG9206 Dryer
Timer stopped running, no heat
Found dryer running after starting night before. Timer does not run in regular or delicate cycles. OK in air fluff mode. Replaced timer module and cycling thermostat, still same problem.Also no heat, Igniter glows red, then shuts off. All other thermostats check OK with ohmeter. gas switch problem or what else?
  • 2 more comments
  • ivynewman Oct 14, 2008
    This is a gas dryer
    All electrical connections are good.
    Gas is on. What activates switch or regulator.
  • ivynewman Oct 16, 2008
    I checked on gas valve assembly cost ( $ 120.00 ) decided to call technicain out and was actually valve coil probem. Total cost of service call $ 87.00 including parts. Too bad I already spent $ 110.00 on parts I did not need ( Timer and cycling thermostat ) Sometimes your better off just calling an expert. By the way, the valve coil part was only $ 20.00 part. This is a common problem according to technician on most gas dryers around 6-10 years old.
    President:
  • 1,263 Answers
The valve body is the problem there is a one way valve inside it if thois fails the gas will not flow to your burner. this is a prevention feature it's design is to keep back pressure to insure a flame doesn't travel back through to the source and cause an explosion.the valve body will have an intergrated regulater so replace the whole valve assembly and it should take care of the problem
Posted on Oct 14, 2008
    Novelist:
  • 159 Answers
Stupid note --?? IS gas on--??
If igniter glows then the gas switch or regulator are not being activated. Igniter goes out because it isn't sensing a flame, so you thermocoupler should be working.
Fran
  • Fran Bednar
    Fran Bednar Oct 14, 2008
    Forgot to note: your timer may be being stopped by a gas pressure sensor.
  • Fran Bednar
    Fran Bednar Oct 16, 2008
    LIKE I SAID GAS SWITCH not being activated.
    Thanks for trying.
    Fran
    Sergeant:
  • 231 Answers
It could also be a loose or bad ground inside of the dryer itself. I actually had this happen once.
    Genius:
  • 3,422 Answers
If your dryer doesn't heat, check these:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
The dial on the cycles never advances to the "off" position
The timer is shot. Replace it. Check around there are places that rebuild them, sometimes at half the cost.
Aug 10, 2014 | GE GTDL200EMWW 27" Front-Load Electric...
Maytag dryer modle #mdg7657bww timer dosenot advance,I intalled new timer,same results,timer works very slow in air fluf mode
Sounds like you have another bad timer or possibly a bad temperature switch if you have a selector switch for the different heat ranges high medium low and air fluff try the high heat and see what it does set the timer and use a regular clock to see if its running on time. if so there is your problem its your heat selector switch if not I would take the new timer back and get a new one and if that dosent fix it I would have a qualified service technician come look at it to rule the problem out with out seeing it in person and trying a few things will be hard to diagnose sorry for the trouble hope this helps and thank you for using FixYa!
Jan 27, 2011 | Maytag Dryers
The dryer heats and shuts off in about 30 seconds repair guy has changed a thermo fuse? and i still have the problem i've checked my ducts no blockage it runs on air and delicate fine but on reg heat in...
its your timer that needs replacment. not the thermal fuse.
if the thermal fuse was ever tripped, it would not start at all. you would only hear the ticking of the timer.
if other cycles work its the timer not any of the sensors or fuses.
dryers are very basic, and are completely controlled by the timer (or control board for digital models)
Jun 16, 2009 | Dryers
Element heats, dryer tumbles, no heat in drum, never shuts off
Hi, If the dryer heats but will not advance in either time or auto cycles, you need to change the timer.
You can test to see if the timer is getting voltage. Remove the top rear panel and locate the two wires going to the timer motor. There should be 120V when the dryer is running in time dry.
Please let me know if this helps or if I can assist you further.
Thanks
Vic
May 27, 2009 | Whirlpool LER5636P Electric Dryer
My dryer ran all day long. The timer was still in the same position as when I left the house. The 'regular' heat is now not working either, air fluff only.
one of the fuses in your house's fuse box is blown check both fuses for continuity and replace the blown fuse you only have 115 v coming to the dryer which will run the motor but wont run the heat or the timer let me know how you make out and dont forget to rate this suggestion thanks
Aug 05, 2008 | Maytag Dryers
Dryers Logo
109 people viewed this question
Top Maytag Dryers Experts
Mike Cairns
Mike Cairns
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
