Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool Side by Side Refrigerator
The center section (dividing the two parts for frig) is "burning hot" but inside seems to be relative cool/cold. We are in Houston and experienced power surges during Ike. Don't know if this caused problem with Compressor, or what.............am concerned about a possible fire from the heat.
    Scholar:
  • 112 Answers
You have a refrigerant loop that runs through the cabinet of the refrigerator and usually runs right under the door gasket seal. Usually, when you are getting too hot on the loop, it is because your refrigerator cannot shed the heat it is removing from inside the refrigerator. This is most likely caused my either a dirty condenser unit or a faulty condenser cooling fan. (both located underneath the unit). The fan should be running anytime the compressor is running.
Posted on Oct 14, 2008
My refrigerator is hot! To be clear, the frig is cooling, but the divider between the frig and freezer is so hot that it almost burned my arm! The lower part of the freezer is defrosting as well.
Your condenser grill under your frigerator is dirty and not able to get rid of the heat. If you take off the front grill and the back panel and vacuum it out or better yet, blow it out with an air compressor, it should solve your problem.
Also make sure that the condenser fan is operating because that would also cause the same symptoms.
Aug 07, 2011 | Hotpoint HSS25GFP Side by Side...
Center Divider VERY hot...
The center divider gets very hot , when the fan motor that cools the compressor stops or the coils at the front bottom , gets clogged with dust , lint , pet hair , etc . Check the coils to make sure they are clean . Next , pull the refrig out from the wall , and remove the bottom panel . Check that the fan is working and that nothing is blocking the fan blade , cooling the compressor and coils .
Oct 24, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Only the freezer side is working
I don't think the darkness is related to the fridge not being cool. The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp
OR
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 17, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frig not very cold & metal between freezer and frig gets hot
Poor cooling and a hot divider mean that air is not moving effectively over the condenser coils under the fridge. Check to see if the fan is blowing under there while the compressor is running. If not, then the condenser fan has failed and needs to be replaced. If it is, then use a vacuum with a long nozzle to give it a good cleaning under there.
Jul 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Compartment Divider on side by side refrigerator gets very hot
Clean the condenser coil underneath the dust bunnies keep the coil from cooling. What you feel is your elictir running away
Mar 14, 2009 | Kenmore Refrigerators
Whirlpool Side by Side - Overheating
HI thanks for your question. the heat between the two doors is normal. its heated there to stop moisture, from hitting a cold surface , and turning to water, so its normal. but pull fridge away from the wall. remove the back panel by the compressor. clean all coils. thanks the appliance doc. please rate my answer. thanks
Oct 13, 2008 | Whirlpool Refrigerators
No ice cubes
your freezer has to be below32 degrees to make ice,can you tell me if the freezer and frig are working ok?mike
Sep 12, 2008 | Whirlpool ED2FHEXN Side by Side...
Divider red hot
I'm not familiar with the Samsung refrigerators, but on most side-by-sides the evaporator (cooling) coils are located within the divider partition between the two sides.... along with the defroster 'heater' coils. During the defrost cycle, this panel may feel warm/hot to the touch. Are the freezer/refrigerator sections staying as cold as they should be otherwise? If they are also TOO WARM, then you may have a 'defrost cycle' relay or timer motor malfunctioning.
also see if the fan works properly.
Good luck..
Aug 09, 2008 | Samsung RS2630SH Side by Side Refrigerator
Center divider of refrigerator is extremely hot to touch. Is this normal? I don't recall it being hot. The refrigerator is operating normally.
Turns out a circuit board had failed and the fan (back of frig) was not working. Because of this, coils were overheating which triggered the icemaker to stop functioning. Until the part was replaced, we put a portable fan in the back and within a day, things were cooling down and the icemaker was functioning again.
The part with installation was $200. Took less than a week for the part to arrive.
Jun 07, 2008 | Whirlpool Refrigerators
Whirlpool conquest 2001 GS6SHAXKQ01 refrigerator side by side top part is not cooling
Don't let them tell you that the problem is related to "sulfur" in your water. It's a scam so that they don't have to repair the problem. The actual problem is that they don't use quality parts to build these units anylonger.
May 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
138 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
