Question about Electrolux Vacuums
Need replacement drive belt for tempest Z178 cannot locate a supplier. any assistance please?
What is the replacement belt number?
Shop for Eureka Vacuums What is... on Google
Eureka® Replacement...
$2.89
Staples Eureka Upright Vacuum Clea...
$5.99
Eureka Eureka Hand Vac Belt
$2.49
Eureka Eureka R Type Replacement...
$5.99
Bed Bath & B...
(4) Eureka AS1104 Drive Belt
$3.49
Google Trusted StoreeVacuum... Search Results
    Belts - Eureka
    www.eureka.com/en-US/Vacuums/Accessories/Belts/
    EurekaWith high-quality vacuum cleaner belts from Eureka, you can get better performance from your ... For optimum performance replace belts every 12 months.
    Eureka Replacement Belt for Upright Vacuum ... - Walmar
Jan 19, 2016 | Eureka Vacuums
I spare part needed drive belt for navigatior power head. Where is S.A. distributor?
If you are able to find a supplier please post back where you found it. I work for a vacuum repair store in Greenville, SC and we have not been able to find belts for Shark vacuums.
Feb 17, 2015 | Shark Navigator gray canister bagless pet...
Cleaning rollers and belt come off on one side, cannot figure out how to put back.
For wonderful step-by-step instructions on how to replace the rollers and belt, please refer to pages 17-19 of the user manual located here:
http://www.sylvane.com/images/prodphoto/bi1129/CleanShot_User_Manual.pdf
Let me know if you need clarification, and I'll assist. I hope this helps. Please rate this solution.
Thanks!
~PCF
Mar 07, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
I need to replace the brushbaron my DC17 Animal model Dyson. It's almost four years old. I can't find the correct part number on the Dyson Website and I can't seem to find a Dyson repair center in...
The original Dyson part number for the brush bar (often called brush roll) is: 911961-01
If you type the above part number into Google Products (click link below) you will get a list of suppliers at varying prices. A genuine Dyson part will cost about $20-25. There are some cheaper replacements available but you may need a different belt to use these, so I suggest you buy an original. Make sure the supplier states the part is Original / Genuine Dyson or OEM.
http://www.google.com/products
http://www.google.com/products?hl=en&q=911961-01&scoring=p
I can't help you locate a Dyson service centre in Albuquerque, but you should be able to fit the new brush bar yourself. If you do need a local service centre, you can call Dyson on the following number - they will provide details of your nearest authorised service centre:
Dyson Helpline (USA): 1-866-MY-DYSON / 1-866-693-9766
8am - 8pm (CST) Monday to Friday
9am - 3pm (CST) on Saturday
10am - 2pm (CST) on Sunday
If you need any further assistance, please post back.
Please rate this solution if you find it helpful. Thanks!
Nov 01, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I NEED A BELT FOR A RICCOR 8900..............................PART NUMBER A20-R2 CAN YOU TELL ME WHICH ONE I NEED.....................THANK'S CRISTA HARDIN
You seem to have two model numbers. I plugged the following into Google and got plenty of locations for Riccar belts.
Riccar 8850 Vacuum belts
You can do this and find a supplier you might want to deal with.
Sep 15, 2010 | Riccar 8850 Vacuum
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Need to change a belt on my Hoover Concept One Power drive
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766023
Generic problem for all Vacuums
Posted by gentilly on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Hoover Concept One Power Drive Upright vacuum there are 2 belts, a drive belt and a power drive belt, always use the Hoover genuine belts and for the best cleaning always change you vacuum belts every 4 to 6 months for the best cleaning. !st, remove the bottom plate and cut off the old belts – then you need to lift up the one side of the brushroll that has the pulley side for the longer of the 2 belts and slide it on. Replace the brushroll, B4 you go to far remember which went on 1st, the power drive belt (smaller belt) or the brushroll belt, in either case hook the belt(s) onto the pulley 1st and then use a belt puller or a screwdriver with a hook or bend on the end and stretch the belt(s) onto the motor pulley and then track the belts in a straight line – do this on both belts. Once you have done this then replace the bottom plate. Check your owner’s manual in the trouble shooting guide to see if they also have suggestions or check with your local vacuum cleaner dealer in your area or contact the Hoover website or the Hoover factory cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
Need a replacemnet belt for upright hoover durabrand
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=723179
Need a replacement belt for
Posted by madasalorry on Jun 30, 2008
Need a replacement belt for upright Hoover durabrand
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best place to get a replacement belt for a Hoover DuraBrand vacuum is to contact your local vacuum cleaner dealer in your area or to contact the factory @ Hoover listed below and call cust serv and they will direct you to the parts dept. but, please use the genuine belts instead of replacement belts and the average belt change for flat belts is every 4 to 6 months and if it is a geared belt than once a year for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jun 30, 2008 | Vacuums
Keep replacing belt that drives brusher but keeps breaking. When feel belt driver rod it is superheated.....could it be melting into the stretched belt causing it to weaken?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559226
Posted by andy78billy on Apr 30, 2008
Depending on the brand name and model # it is my opinion that it is not the belt, it may be that your brushroll is bound up with thread, hair, dirt, etc., and is not spinning well – place the brushroll on end and try to spin it, if it does not spin freely, then you are bound up, try to clean it up and lubricate by using one drop of oil and then wipe off the excess, you don’t want the oil to hit your carpet, if that does not work replace the brush and the new belt, am average flat belt change is every 4 to 6 months – also you may have the wrong size belt of which would cause the to burn up fast. Always use the genuine vacuum belts when replacing.
Don – The Vac Man
Go Ahead. Use Us.
Apr 30, 2008 | Vacuums
Vacuums Logo
60 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
