Question about Dell Latitude D600 Notebook
Still hurting here
The bluescreens and memory reductions continue....
  • 128 Answers
Pls check your Random Access Memory (ram) try to remove it and clean the metal pins with a pencil eraser and insert it back to your pc make sure you turn off your pc before you remove it.
Posted on Oct 16, 2008
After 30 sec exposure on bulb my Nikon d60 has 20 second wait before it will let me take another picture. Why?
The camera is performing noise reduction. To avoid this, make sure the ISO is set to 800 or less and Noise Reduction is turned off in the Shooting menu.
See "Noise Reduction" in the manual (page 108 in my copy).
Aug 16, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
Laptop in continuous reboot after windows update
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
Apr 16, 2008 | Toshiba Satellite A45-S150 Notebook
What is the memory module used in dell optiplex 755 service tag-9sc3jh1-dy
Dell Optiplex 755 supports a maximum of 8GB of memory. Memory modules should be installed in pairs of matched memory size, speed, and technology. If the memory modules are not installed
in matched pairs, the computer will continue to operate, but with a slight reduction in performance.
DDR2 Synch DRAM Non-ECC Memory 667MHz or 800MHz speeds are supported.
For further details please refer to Product Technical Specs (Page 12)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 21, 2011 | Dell Optiplex 755 Desktop Desktop Computer...
Hi i have a m4a77td pro motherboard with amd phenom quad core 810 cpu running a 9600 gt with win 7 32bit on 4gb of drr3 1333 clockspeed 9,9,9,24 im receiving problems while gaming the game might pause or...
My first "guess" is memory timing. Are all your memory sticks the same size and speed? If that''s good, then you may want to play with the timing and speed. Slow it down a bit. For gaming, I would prefer 8Gb for a larger swap file. Hope this helps.
Mar 30, 2017 | ASUS M4A77TD Motherboard
Physical memory dump
Hmm... Well a Bluescreen is when your computer crashes, and (as you have found out) preforms a physical memory dump. This can be caused by multiple things. Such as bad drivers, PFN(page frame number) or problems with your memory. When a bluescreen event occurs, the is a technical information which has an error code that can be used to help find the problem. In order to fix this problem, you may have to remove any software, or hardware that you have recently installed. To uninstall software, you may need to boot in safe mode, which is where your computer starts up using the minimal amount of drivers needed, in order to try to prevent the computer from crashing.
Here are some useful websites (sorry, my hyperlink icon isn't working):
  • www.datarecovery.com.sg/data_recovery/hard_disk_symptons_blue_screen.htm
  • www.maximumpc.com/article/features/blue_screen_survival_guide
Feb 27, 2010 | Dell Dimension 8400 PC Desktop
Hi K akima...have followed your advice, but no luck. When I go to continuous mode, it only lets me shoot a single shot, the display briefly reads r 08 then returns to r 09 again. I`ve tried my other lenses...
nikon r09,r11, etc . it mean memory buffer of your camera. memory buffer is a temporary memory for your captured images before it store to memory card.
if r00 it mean, you can't take a picture, even 1 picture... that because the camera buffer memory is full.
the number of memory buffer will also drop if noise reduction on
Feb 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
Bluescreened a few times and went out? I updated
Try testing the memory modules 1 at a time to check for faults. Bluescreens are commonly caused by bad memory especially with XP.
Dec 08, 2009 | MSI K8N Neo3 Motherboard
Cannot change operating system on Gateway GM5478?
Be sure you have a 64-bit system before installing this will not work on a 32-bit system.
Dec 05, 2008 | Computers & Internet
Installing XP on HP m8120n
The Blue Screen of Death (also known as a stop error, BSOD, bluescreen, or Blue Screen of Doom) is an error screen displayed by some operating systems, most notably Microsoft Windows, after encountering a critical system error which can cause the system to shut down, to prevent damage.
Bluescreens on NT-based Windows systems can be caused by poorly written device drivers or malfunctioning hardware. In the Win9x era, incompatible DLLs or bugs in the kernel of the operating system could also cause bluescreens.
Bluescreens can also be caused by physical faults such as faulty memory, power supply issues, overheating of components, or hardware running beyond its specification limits. Bluescreens have been present in all Windows-based operating systems since Windows 3.1; earlier, OS/2 and MS-DOS suffered the Black Screen of Death, and early builds of Windows Vista displayed the Red Screen of Death after a boot loader error.
I hope it helps!!!
Dec 04, 2008 | MSI K8MM-V Motherboard
Bluesreen and restart
Bluescreen problem is associated with Hard disk drive failure or RAM-Random Access Memory. Try and change those two components and try again.
Nov 08, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
Alun Cox
