Question about MGE Galaxy 3000 UPS System
Fault diagnoses my ups system goes off by itself, it goes off over and over again when even I restart to work for some time. I have my checked circuit breaker and it was functioning good. May I know what the problem is and the solution to it.
2 Suggested Answers
SOURCE: ups problem
The batteries need to be replaced. They probably have more than 3 years.
Replace the batteries and let the new ones charge fully for a day and your UPS will work like new after that.
Posted on Oct 27, 2009
My cars panic alarm goes off by itself.
possible -but all these fancy electronics are beyond the realms of most people and you need the factory to reset and diagnose the fault .even us mechanics have to admit defeat with faults like this and return vehicle to the dealer then charge for the time involved in taking and collecting the car ,take it straight to the dealer yourself
Feb 21, 2016 | 2003 Chevrolet Cavalier
My 2006 Buick lacrosse reduce power light came on today--what does that mean
Reduced Engine Power
Refer to Throttle Actuator Control (TAC) System Description in Engine Controls - 3.6L or Throttle Actuator Control (TAC) System Description in Engine Controls - 3.8L
TAC System Default Actions/Reduce Power Modes
There are 2 reduce power modes that the engine control module (ECM) can default to if an error is detected in the throttle actuator control (TAC) system. If an accelerator pedal position (APP) sensor 1 or APP sensor 2 circuit fault, throttle position (TP) sensor 2 circuit fault, or if a TP sensor 1 circuit fault is detected with some APP angle, the ECM goes into one of the 2 reduce power modes. In this mode, the engine torque is limited so that the vehicle cannot reach speeds of more than 100 km/h (60 mph). The ECM remains in this reduce power mode during the entire ignition cycle even if the fault is corrected.
If there is a condition with the throttle actuator control circuits, throttle actuator command vs actual position fault, return spring check fault, or a TP sensor 1 circuit fault, the ECM goes into the other reduce engine power mode. In this mode, the engine speed is limited to 2,500 RPM and the 3-6 fuel injectors are randomly turned OFF. At this time the Reduced Power indicator is commanded ON. The ECM remains in the reduce power mode during the entire ignition cycle even if the fault is corrected. Observe, if a TP sensor 1 or throttle actuator control circuit fault is present at the time the vehicle is at idle, with no accelerator pedal angle, the engine may stall.
Jun 21, 2015 | Cars & Trucks
Video turn off and audio works fine
There could be several things going on. I would seriously recommend you get a diagnoses on the set. But the first thing I would do is when the video goes away, dim the lights in the room and shine a bright light on the panel. If you see a faint image on the screen, you have a back light circuit fault. If you see nothing while shining the light on the panel, you have a fault in your video circuit which could be due to overheating on main board or t-con. Again with so many possibilities at hand, I would get a professional diagnoses.
Nov 24, 2012 | Televison & Video
Car runs fine then power loss till switch of engine then ok again
You MUST have the electronic engine control module scanned for fault codes to even begin to diagnose the cause of this.
Apr 06, 2012 | 2004 BMW 320d Touring
My protection light is on and the amp goes in and out. how can i fix this problem?
Either there is a malfunction on the amplifier , or more likely there is a short on the speakers cabling. If the cables are shorted, or broken, not allowing a sufficient load, the amplifier will protect itself by tripping a fuse. After a while, or on restart, the fuse will rearm itself, only to be tripped again by the malfunction.
Jul 28, 2011 | Dual XPA2100 2/1 Channel 300 Watt...
P0463 and P0499 both codes refer to half circuit high. I keep hearing about good trip equal to zero? have no clue what that means.
Code P0463 refers to the fuel gauge sending unit circuit and P0499 refers to the Canister Purge Solenoid circuit - two totally different circuits.
The reference to "good trip equal to zero" requires the use of a scanner that is capable of reading the data stream from the various Circuits. Many inexpensive scanners are really only "code readers" and will output only the fault codes. They cannot provide you with much of the information required to properly diagnose and repair the problem.
The way a circuit is diagnosed changes completely if the problem is an intermittant problem and is not occuring at the time the circuit is being tested. The data stream will give the fault code and tell you how many trips the vehicle has made without the failure reoccuring. For example, if the circuit failed three trips ago and worked on the next three trips, the good trip count will be "3". If the good trip count is "0" this means that the circuit is failing right now. The troubleshooting charts will send you to different steps depending on whether the fault is current or whether it is an intermittant fault.
There is a lot of misconception in the general public about what fault codes actually do. A lot of people think that you simply plug in the "Magic Box" and it tells you exactly what is wrong with the car and what parts to replace. If anyone finds one of those please let me know...I WANT ONE!!!
What fault codes actually do is give an indication that one of the circuits or systems that are monitored by the computer is malfunctioning. They NEVER tell you what parts to replace. It is up to the person making the repairs to diagnose the malfunctioning circuit or system to determine if any "parts" are actually even needed. Many codes can be fixed by making a simple wiring repair (like cleaning a connector) without replacing any parts.
Dec 05, 2010 | 2006 Chrysler Sebring
Tv shut off and will not restart flashing green timer light tried system restart also unpluged and restarted checked the cable singnal changed the bulb
projection TV`s have integrated protection circuits
built into the circuit design, these circuits turn the
power off automatically when a fault has bin detected indication of this is a flashing light on the front panel
this is in order to prevent a more costly repair, these circuits monitor
power supply , vertical and horizontal deflection
over voltage, or x ray, and also faults with convergence circuits.
Diagnosing these faults require test equipment and a good knowledge of
electronic repair techniques, and also a repair manual.
Nov 21, 2010 | Mitsubishi WD-52825 52" Rear Projection...
Dear sir My sony vaio grx570 do not turn on properly. 1-if keep it up off for one day, it does not starts booting. but after 5 to 6 tries it get power on with AC power. Windows xp logo...
When you boot the machine, use the proper key to enter the BIOS and check the date and time. If it is wrong then the BIOS battery is bad. Replace it.
Mar 03, 2017 | Sony VAIO GRX550 Notebook
D61W20 61 in. Rear Projection Television: turn on tv ligt blinks 3 times and goes out....
power off automatically when a fault has bin detected this
Apr 28, 2010 | Televison & Video
Amp comes on and goes right into protection mode
Turn the reciever on for a second or two and then off before the protect mode shows up on the monitor. Repeat this step about five times and check to see if the reciever does not go into protect mode. If it does go into protect mode try it again. Dont know if this is the proper way to fix the reciever but it worked for me. Good Luck
Mar 09, 2008 | Audio Players & Recorders
Computers & Internet Logo
99 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
