Remove and check color cartridge [it dosnot work]
  • 2 more comments
  • Anonymous Dec 01, 2008
    help! I've replaced this color cartridge too many times! Its not empty and it appears its in correctly. How do we fix this?
  • superdiva Dec 10, 2008
    my printer is saying "remove and check color cartridge." I did this but it is still saying the same message. It wont allow me to print anything color or black copies. Please help me.
  • helpmeoot Apr 05, 2009
    C4180 has message saying remove and check color cartridge which prevents use of machine.
    So checked with HP website and apparently its a common problem.
    So, armed with capful of vodka and a cotton bud I cleaned the terminals on the cartridge, including around the print head, and the contacts on the machine.
    I had to do this three times but eventual success, and now working a charm.
    Good luck
  • Anonymous Apr 11, 2009
    cleaned the contacts on the cartridge and printer...brand new cartridges, still cant get rid of the message
    Problem Solver:
  • 6 Answers
I went to the hp website and they acknowledge this problem they have a page on this http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&cc=us&lc=en&dlc=en&product=59273
it appears that there may be dirty contacts in the printer as well, i changed the black cartridge and it started working, just luck i guess
Posted on Mar 06, 2009
Had an old HP G55 that had not been used for a while and needed cartridge replacements. When replacing black cartridge I got the Remove and Check Black Cartridge message. HP recommended cleaning carrier and cartridge contacts with water (pretty stupid, HP) and that did not work. So I cleaned same contacts again with GOOF OFF paint remover (just a dab will do ya). Reinstalled black aftermarket cartridge and G55 unit went into alignment and now prints fine, thank you very much.
Posted on Jun 05, 2009
HP 6210xi Officejet suddenly stopped with ALL lights blinking (including LED panel) with message that the color cartridge was not intended for this printer (it was an HP 97 - right item!). Changed the cartridge then noticed black cartridge was fading. CHANGED THE BLACK CARTRIDGE (HP 94) and all is well. Note: the cartridge access door safety switch seemed to be getting a bit sketchy... wonder if that contributed to the event??
Posted on Jul 28, 2009
ve3wtj
  • 147 Answers
SOURCE: remove and check color cartridge
Sounds like the contacts are dirty. A cotton swab and some rubbing alcohol might help.
Posted on Sep 19, 2008
pdabbs
  • 4 Answers
SOURCE: says to remove and check color ink cartridge
Take out cartridge and clean the contacts. On the printer and on the cartridge. Mine did that and there was a speck of ink where the cartridge meets the printer contact. Actually, it was a defective cartridge.
Posted on May 24, 2009
geo_jonas
  • 555 Answers
SOURCE: New color ink cartidge won't work
try to check if that ink cartridge is compatible from your printer. then try to removed it and installed it back.if it doesn't work ship it back to your supplier.
Posted on Jun 16, 2009
  • 72 Answers
SOURCE: HP4150 error "remove and check color cartridge"
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, and then wait until the carriage is idle and silent.
  3. Press down gently on the top of the cartridge to release it.
  4. Make sure all the clear protective tape has been removed from the nozzle and electrical contact area
  5. Reinstall the cartridge in the product and try again to print.
  6. : Make sure the cartridge is compatible
  7. Open the printer lid and wait until the carriage stops moving, and then unplug the power cord.
  8. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
  9. Dip a clean cotton swab in distilled water, and then squeeze it to remove most of the moisture.
  10. Clean the print cartridge contacts. Do not touch the nozzles.
  11. Clean the contacts inside the carriage, inside the printer.
  12. Either let the cartridge sit for ten minutes to allow the cleaned area to dry, or use a new swab to dry it.
  13. Reinstall the cartridge, plug in the power cord, close the printer cover, and then try again to print.
Posted on Aug 08, 2009
  • 109 Answers
SOURCE: Message says Remove and check color cartridge. We
you should clean the gold contacts where the cartrige is inserted they may have ink deposits preventing contact to the cartrige good luck!
Posted on Sep 08, 2009
I got a message "Remove and check color
you can try to remove and clean the chip contacts of the cartridge and or the cartridge housing. if it still doesnt work try resetting the printer ink counter.
Feb 28, 2011 | HP PSC 1610 All-in-One Printer, Scanner,...
Won't print: "remove and check color cartridge"
remove your new color cartridge and make sure you have removed the safety tape on the botton of the cartridge.
Mar 07, 2010 | HP PSC 2110 Color Printer
Did you remove the tape on the bottom of the cartridge before you installed it?
Jun 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Says to remove and check color ink cartridge
May 24, 2009 | HP Photosmart 2610 All-In-One InkJet...
Installed new colour cartridge did not use for 3 months now dosnot print colour pictures
Did you remove the clear film covering the contact point on the new cartridge? Try a Q-Tip dipped in rubbing alcohol and gently clean the contact surface of the new ink cartridge.
Mar 27, 2009 | Lexmark X2250 All-In-One InkJet Printer
ASKING INSTALL COLOR CARTRIDGE
Check if the cartridge was inserted correctly (right slot) (remove it and insert it again)
Check if the cartridge is original and the sticker was removed. Turn off your computer, and your printer. Start up your computer and after your printer. Try again.
If the problem continues, insert the old one cartridge (which was removed before) and see what happen...
If stop asking for install color cartridge, you have failure on your new cartridge
and need to be replaced.
Sep 24, 2008 | HP DesignJet 750c plus InkJet Printer
Sep 19, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    OR
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    the problem is the little poorly designed metal thing that is holding up the ink cartridge get's stuck between the cartridge and the printed circuit and it brakes the circuit.must have been some **** drawering on a napkin that came up with that one.wasted a nice unit for that two cent piece of metal.
    Jul 23, 2008 | HP Photosmart 2610 All-In-One InkJet...
    Color cartridge wont print
    The color cartridge is defective. Sometimes, when the printer detects a refilled cartridge, it "marks" the cartridge as defective hence the refilled cartridge will not work on any printer.
    Jul 21, 2008 | HP PSC 750 All-In-One InkJet Printer
    3,511 people viewed this question
    k24674
