Question about Fisher and Paykel Washing Machines
NO BOOK FOR A M03 AUTO WASHING MACHINE - Fisher and Paykel Washing Machines
  • 94 Answers
Try that model number again. I think it not the right number.
Premmy
Posted on Oct 14, 2008
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
www.samsung.com/ae/support/skp/faq/1033383
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
How to Fix Washer That Won't Spin ' Washing Machine Repair
Nov 28, 2015 | Washing Machines
WT960 hotpoit washing machine shows F10 and stops
* F01 - Short circuit motor traic - Book a service engineer.
* F02 - Motor jammed or fan blocked - Book a service engineer.
* F03 - Front thermistor open/short circuit - Book a service engineer.
* F04 - No pump piloting - Book a service engineer.
* F05 - No feedback from the pump - Book a service engineer.
* F08 - Static heater relay with contact welded closed - Book a service engineer.
* F09 - Eeprom is not programmed or not functioning - Book a service engineer.
* F10 - Common of heater open or one shot open - Book a service engineer.
* F11 - No pump connection - Book a service engineer.
* F12 - Communication error between boards - Book a service engineer.
* F13 - Rear thermistor open/short circuit - Book a service engineer.
* F15 - Dynamic heater relay with contact welded closed - Book a service engineer.
* F-17 - Master relay welded closed - Book a service engineer.
Apr 06, 2015 | Washing Machines
Fault-F13 What does it means?
Hotpoint Washing Machines and Washer Dryers
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred. Book a washing machine repair
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a washing machine repair
  • F17 - Door not closed properly. Close door firmly at the 3 o'clock position.
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing. Book a washing machine repair.
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
  • F40 - Water below protection level during a heat step. Book a washing machine repair.
  • F41 - Water level detect sequence incorrect. Book a washing machine repair.
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a washing machine repair to re-programme your product.
The code f-13 refers to the water valve. Check it for any obstructuions in the screen and if your thinking it is bad you can always swap the hot and cold lines and change the settings to get the temperature you want and that will tell you if one of the valves is not working. Say if you want cold but no cold is coming into the waher, swap the cold and hot lines and call for hot water, if cold comes in then, then you will know that the cold valve is bad. If neither valve is working then replace the assembly
Sep 15, 2011 | Hotpoint Washing Machines
F-05 MESSAGE HAS COME UP ON MACHINE WHAT DOES THIS MEAN?
hi have a look below hope this helps, then goggle how to fix it!
Sep 06, 2011 | Hotpoint Aquarius WD640 Front Load...
Have just purchased a F&P Intuitive Fabric Sensitive washer and the water wont stop when filling the machine up ? This is a second hand machine so have no book.
Hi just read your posting.Now are you using the auto filling mode or the traditional water level mode eg-- low med or high?Has your machine got an led screen?If so go to the options section and you can select water level, traditional wash,and water temp.Please reply on how you got on or for further assistance. Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Washing Machines
Getting an error messsage on my hotpoint ultima wm72 code is e30
It means motor problem, see below
It could be as simple as the motor requiring new brushes which can be bought quite cheaply on ebay or as complicated as the pcb motor controller being faulty. The brushes are however easily checked
http://www.youtube.com/watch?v=0GmtRBiXLFc
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.Read on....
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Hotpoint Error Messages and Error Codes
The following are an explanation of specific error codes that may appear if there is a problem with your Hotpoint washing machine, tumble dryer, dishwasher, fridge or freezer. In most cases it is recommended to book a service engineer to rectify this fault but there are certain things that you can do to minimise any inconvenience or even avoid an unnecessary engineer visit.
Don't forget, should our advice fail to solve your issue then you can book a Hotpoint appliance repair . Alternatively phone us on 08448 224 224 to book your washing machine repair.
If an explanation of an error code on your Hotpoint appliance is not shown please contact us for an explanation
Feb 26, 2011 | Hotpoint Washing Machines
I have a 3G dongle (ZTE MF626) and can not get access to the internet. I tried with two Laptops via Wireless. One with XP and the other with Windows 7. The wireless is recocnizing the ESR 6650 but can not...
Try this link
The Connection Manager installed from the USB modem does not include Windows 7 Drivers.The Connection Manager M03 does include Windows 7 drivers.
For Windows 7 support do only one of the following two options:
a) Update your currently installed Connection Manager using the Windows 7 driver tool or...
b) Install the new Connection Manager (M03) after un-installing your current version.
Nov 01, 2010 | Computers & Internet
Hi our washing machine keeps displaying error code f12 and will not go on does anyone no what this means carolyn
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Nov 21, 2009 | Hotpoint Aquarius WD640 Front Load...
WF860. Machine auto fills when power come on
this is for standard hotpoint washers.
this is for hotpoint lcd evo1 washers.
F12 - Communication error - Book a service engineer.
this is for hotpoint lcd evo2 and v4 washers
F12 - No communication between cards - Book a service engineer.
please do not for get to rate and comment about your experience with fixya today.
Aug 20, 2008 | Hotpoint Ultima WF860 Front Load Washer
Open Questions:
Washing Machines Logo
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
