Question about Frigidaire Ovens
Oven PLEF398ACA had one burner would not shut off right RF turned off power worked fine now getting F7 reading and no top burnners are working oven works fine
  • petevuk Nov 19, 2008
    Yes, I have the same problem. I am trying to get the schematic for SpitFire Controls SF5601 board but no luck. Right now I just disconnected the wire for inner smaller burner.
    Waiting for a solution.
    Thanks
I have the same problem with the LR, it is on all time and do not go off. What I did was to disconnect the yellow wire from the SF5601 power board terminal P3. Now I can use the other three burner until I got a new board. I don't have the circuit schematic but my diagnostic is that the board integrated output relay contacts are welded together. That is why the burner element is on all the time and or intermittent. THE VERDICT: The solution is to replace the surface power board SF5601
Posted on Dec 17, 2009
  • Bert Gunn
    Bert Gunn Sep 19, 2014
    you can just replace the relay if you can solder, or alternatively, you can use a standard burner control and rewire to the element. a little complicated but possible
I have this Frigidaire Oven PLEF398ACA. It is 6 years old. Right front, inner small burner won't turn off. It happened in March of this year. I called for service. Before he came it started working. It did not work for few days. Now again for 4 days, I could not turn off the inner/small element. I was turning on and off using the switch board in the garage. Now all of a sudden when I turned it off, after cooking, it is off. Tell me what the problem is. Is it thermostat or loose contact or something like that. I have tried different knobs from the same range. Why is it sometimes I can turn it off, sometimes I cannot.
Thank you for reading my stove problem.
SR
Posted on Nov 08, 2008
ALL FOUR BURNNERS ON MY FRIIGIDAIR PLES389ECH STOPPED WORKING AT SAME TIME BUT OVEN WORKS
Dual fuel range, will they light with a match? If all 4 burners are not working. It is more then likely the spark module. I'm sure you check your gas supply.
Oct 26, 2014 | Ovens
Kenmore elite dual fuel range model # 790.75503- My power was cut off and since my oven won't heat (display shows on, but doesn't heat - stays at 100 degees) - also my burners won't ignite (unless I t
It could possibly be you are not getting 240 volts to the range. The top igniter may be getting a current back through the other side of the 240 circuit and that is why it works when the oven is turned on but the oven will not be getting power to heat. Have the 240 circuit checked or make sure the circuit breakers are reset correctly.
Feb 09, 2014 | Ovens
F1 Error Code : Kenmore Self-Clean Electric Range. Oven wont shut off. I can silence the F1 alert but it keeps coming right back on every 30 to 60 seconds or so. Range top burners work fine, but oven
An F1 error code usually means that the temperature probe isn't sending the correct signal back to the control board. Try disconnecting power to the range for at least a minute. If F1 displays after you cycle power you may need to replace the EOC (Electronic Oven Control).
Dec 05, 2012 | Ovens
I have a maytag pilotless ignition gas oven. the top burners work fine the broiler ignites fine. we just tried clean mode and its working too. the problem is we cannot get the oven to heat up. we turn bake...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Oct 13, 2010 | Maytag Ovens
Bottom burner in my oven barely comes on, in turn, not heating my oven to the temperature that is selected. Top burner (or broiler seems to work fine). The gas stove is a GE XL44 and is 6 years old. Please...
You need a new t-stat control. Your element is fine. Give us a call with your complete model number and we'll get the right part out to you asap to get you ready for the winter.
Oct 18, 2009 | Ovens
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Oven does mot work
F-7 on the GE is a touch pad error, all you can do is replace the whole touchpad. You can try shutting the power off at the breaker leave off for 5 min at least. turn the power back on sometimes this will get rid of it for a time.
Feb 23, 2008 | GE JGRP17 Gas Single Oven
My oven won't work
Replaced ignitor on mine, fixed it.
Nov 18, 2007 | Magic Chef 9122 Gas Single Oven
F7 SHOWS UP ON THE SCREEN
this problem just occured to me last nite. we had to shut the power off at the breaker box. we turned it back on this morning and it seems to be working fine. it is still a mystery as to what occured but it appears it had to reset itself. not sure if this is a solution, but it has appeared to be working so far.
Nov 23, 2006 | Kenmore 33464 / 33465 / 33469 Gas Single...
Ovens Logo
425 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
