Question about OKI MICROLINE 320 Turbo Matrix Printer
Microline 320Turbo 9pin
My printer prints fine but the print head keeps slamming against the side of the printer. Can you please tell me how to fix this. I have blown the dust off the eyes and no fix.
Thanks,
  • 138 Answers
The problem your having is with the carriage assembly. You'll need to remove the ribbon and printhead. It's the black piece under them. Here's a link to a replacement part for $38.95.
http://www.str-s.com/okidata-turbo-carriage-assembly-p-716.html?manufacturers_id=6&osCsid=8849c8b4
Hope that helps you. :o)
Posted on Oct 19, 2008
I have a OKI Microline 590 Matrix Printer at my store. When we used to hit Utility it would print decently. The ink would be on the lighter side but it was legible. Recently someone came in to change the...
Re-install the printer ribbon. It's probably slipping or dragging on the head mechanism, and the printer synchronization control is slowing everything down to compensate.
Mar 08, 2011 | OKI MICROLINE 590 Matrix Printer
As it is printing cartridge will jam/stutter when going from left to right sometimes prints fine and sometimes stops at left side and alarm will light up
Put some light oil like 3in1 or even wd40 on the round metal bar that runs from side to side. The one the print head rides on. The bushings that ride on the rail dry out and start to bind up. Just a little oil should solve this for you.
Good Luck and Thank You for using Fixya.
Jul 09, 2010 | OKI MICROLINE 320 Turbo Matrix Printer
Printer keeps printing over the =same line, paper is not moving
Theirs a small gear in the gear train on the left hand side that turns the paper roller(Platen).
It has lost a couple of teeth. Has the paper is no longer feeding the print head simply keeps printing on the same place.
You need a service repair.
Cheers
DeJudge
Aug 11, 2009 | OKI MICROLINE 521 Matrix Printer
We have a microline 320 turbo. we installed a new dell computer and now cant get the printer to print corectly on contineas feed labels. The print head starts on the right side and prints off the sheet...
Try downloading and installing an updated driver for your printer.
Here is the driver download page for your printer: MICROLINE 320 TURBO < Drivers & software
Select your operative system, download the file, then run the installer.
Mar 03, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata 320 turbo microline prints jibberish
sounds like a job was sent to the printer with the wrong driver. There is no way to purge it just load some paper and let it run until it stops. They make sure your emulation matches the driver youa are using. Example Epson 9pin compatiable or OKI ML320 Turbo-IBM drive you want the emulation set to Epson FX. Or if using the OKI ML320 Drive you want the emulation set to ML.
Jan 15, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata Microline 420
This would be the print head pins not moving forward or the ribbon bunched up at the top.
Sep 23, 2008 | OKI MicroLine 420 Matrix Printer
OKI Data Microline 320 Turbo
Suonds as if your spacing motor is going out. The part number is 56513701. Here's a link to a free complete Okidata Service Manual for your 320Turbo. The manual will walk you through the testing process to verify the problem prior to ordering the part.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
If this helped you, please hit me a fixya!. I'm just a tech trying to help people in my spare time.
Aug 29, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Okidata 320 Turbo print head carriage slamming
There is a Optical sensor under the print head drive assy. You might have dust blocking this sensor.
Feb 07, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Ribbon Slips Off Okidata ML 395
Your printhead is in correctly but not aligned, Please loosen the 2 screws that holds the printhead.Remove ribbon(all this while the printer is powered off) Now look on the right side there is a lever that makes the printer go closer to the ribbon ,move the lever to number 9 and move the head over to the left side of the printer.push the head forward slightly towards the black roller and tighten the 2 screws again ,install the ribbon and move the blue lever to 1 and try printing again.
Hope this helps.Dezzi
Oct 22, 2007 | Okidata 591 Printer
OKI MICROLINE 320 Turbo Matrix Printer Logo
224 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
