Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
My electric was off for about 12 hours. When it came back on , my ice machine would not work. It was fine up to that point. No ice dropping. water was running in and then would stop after 1 time.
  • Dennis Boxerman May 11, 2010
    a little more info. When turned on, does water enter the machine? The pump should not be running during the "fill" cycle. If water is entering and nothing else is happening, it just keeps filling with water? Look at a stuck float switch. Unit starts with water entering. check their web site. Their tech line is good too. 1-800-233-1940
    Will the machine turn on? If unit is exposed to improper power source, it may "Lock Out" to protect itself. Try calling their tech support line. It's worth the wait. You may just have to turn it off and then back one.
    Guru:
  • 462 Answers
Did you try unplugging the machine?
And look at the fron left do you see a small cylender inside next to where the ice freezes?
Posted on Mar 21, 2009
My portable igloo icemaker is not making ice
i had the no ice making issue , it was running water in the tray but not enough to make the ice. I call service for the machine it self and they told me to . 1. turn machine on . 2. press the select button for 10 sec. then 3. press the power button for 10 sec. and then turn off the machine and unplug it for 6 hour but I only did it for 1 hour. when I plugged it back in and started it. It is now making ice.
Mar 05, 2013 | Igloo Cooler Igloo Portable Countertop Ice...
When I got home I heard the buzzer going off on the freezer..the temperature had dropped from -12 to -2 and I'm trying to reset it to-12 again how do you do that?
You dont have to reset it, you need to defrost it, the defrost element has failed and you have ice build up within the chiller plates, air cant pass through it due to the ice, I think you will find that food is starting to defrost and you will see a bit of ice on the back panel inside the freezer.
Defrost it for 2 days with door open, after that, should work fine for a week or so, very common problem.
Hope that helps, Russ
Jun 29, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My ice maker does not work
Good day,
The freezer must be below 12 degrees before the ice maker will activate. If it's o.k. then follow the steps outlined below. It will solve your problem.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Nov 28, 2010 | Kenmore Freezer 20.6 cu. ft. Upright...
My ice maker isnt working in my fridge model 106 59292993 the bar is in the down position like it is supossed to be and it sounds like its trying to make the ice but just isnt, do you know why?
Good day,
First off the freezer must must be at 10 degrees or lower. The ice-maker will lock out automatically at any temperature above 12 degrees.
Follow the steps. It will get you there.
Nov 27, 2010 | Kenmore Freezers
When the room is full stop making ice , the problem is leaking water with rush from the ice maker
Good day,
don't understand your question at all. When room is full. Full of what ??
But for know, I'll include a step by step procedure for repairing ice makers. Any further questions, please just ask..
Mar 31, 2010 | Freezers
We have a nice ice and it has worked fab for three years but has just stoped making ice yet is still operating normally
Good day,
Without the make and model, I could be missing something, but ice makers are more alike than different. The best way, is to follow a step by step procedure. It should solve your problem.
Mar 28, 2010 | Freezers
Won't freeze
I just had this problem with my wife sister in law if it got lots of ice of snow like build up turn it off and let it defrost it took a matter of may be an hour then it kicked back on and it works fine
Nov 04, 2009 | Kelvinator 12 cu. ft. / 340 liter Chest...
Takes too long to drop ice
Unit is functioning on the back up freeze timer.
Cause:
Float Switch stuck in the up position.=Empty sump, remove float switch (Carefully and watch the small pin that keeps the float inside). Clean and reassemble.
Water Valve leaking by:=Only fix is to replace. Turn unit off. If water continues to run in and overflows the sump, it's leaking.
The other things that can cause this requires a qualified tech as it is a refrigeration problem.
Hope this gets it for you.
Jul 05, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Small production of ice? What should be the normal production of ice?
The way I understand how Hoshizaki machines work, the model number is usually what the unit will produce, in pounds of ice. Their manual states: "Approximate production/ 24 hours @ 70 degrees air/ 50 degrees water (incoming)" So, yours should be producing 450 pounds a day, approimately. Since I can not pin point your exact model, I found one that is close. It states: "Ice Production per cycle: 6.6 pounds, 360 pcs." Again, it is not you exact machine. Their web site does not show this model either. So this is the best info I can get for you. Hope this helps.
Jun 03, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
137 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
