Question about Protron PD-DVR100 DVD Recorder
DVR100 - Can't use it at all
I bought this machine newI keep getting a small circle ( on the lower right hand side of the screen) with a red line thru it and with a right fist with the index finger pointing downwards inside this circle. I can't get anywhere because every button I push on the remote, gives me this pop up. What does it mean and how can I get rid of it?? I have not been able to use this recorder yet. The toll free number I called gave me some idiot who did not know what to do. What can I do??
Have you performed setup? This has happened to me but it was because I had to do somethig else before it would let me do what I was trying to do. email me jazzyjill2b@yahoo.com and maybe you can give me some specifics and I can help you out.
Posted on May 19, 2009
Call back, ask to speak to someone who speaks English and you can understand. If that person do not know then ask to speak to someone else. The toll free number doesn't work for me now, don't know why, but I used it before and got someone who walked me thru that problem and was told that if it did it again, call back and they would send me another one. I did not do that, but other things and then I could not reach anyone with the number I have, what happened?
Posted on Oct 24, 2008
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Need instructions on changing the spool on electric grass trimmer/edger
Turn the trimmer over, I put it in my lap.Remove the orange spool cap by squeezing with thumb & forefinger. It will come right off. Remove & discard(there has got to be something they can be recycled as?) If you are right handed, hold the new spool firmly with left hand with flat side with the arrows up, keep a firm grasp & use small needle nosed pliers(I use hemostats) etc. to free the loose end of the line where it is looped thru the 2 slots. Keeping hold of the spool so it doesn't all unwind, let enough out to feed thru the hole on the side of the compartment where the old spool was. 2-3" will be enough. Then, place the spool into it's compartment with the flat arrow side up.Keep a good grip on the spool until you get it into place. Replace the spool cap by aligning it in the 2 slots that it came from & gently squeezing again until it locks into place & you are set to go. Don't worry about feeding the line out to proper length, it will do that all by it's self.
Aug 03, 2013 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Screen issues
I think better to replace the set as all this sounds like a light engine failing.
Dec 08, 2012 | Televison & Video
I have an old Guardian Power floor model drill press and do not know how to change belt positions to change speed. help please.
See the picture below. The small red circle shows the locking screw on the right side of the drill. There is another locking screw on the left side of the drill. Loosen them both a half turn. The larger red oval is the handle to pull the motor closer to the spindle, thereby loosening the belt. Once loosened, it is easy to move the belt. Then use the handle to push the motor back, which tightens the belt. Keep pushing on that handle with your right hand while you tighten the locking screw on the left side of the drill with your left hand. Once you have that tight then tighten the right side locking screw.
Good luck! I hope this helps.
Jul 12, 2012 | Drills
My mouse touchpad is locked. Keeps showing a diagram on screen with a red line thru the touchpad??
There may be a button towards the top of the keyboard (one of the ones with LEDs next to them) that turns the touch pad on and off. Otherwise, there is usually a keyboard combination (the Fn key in the lower left + one of the F1-12 keys) that can toggle it on and off as well. Otherwise, in the lower right hand corner, if you plug in a mouse, you should be able to right click the touchpad icon and re-enable it.
Aug 23, 2011 | HEWLETT-PACKARD ProBook 6460B
How do i turn on the flash?
On the menu there should be an icon that looks like a yellow lightning bolt with a red circle around it and a red line thru it (this means that the flash is off)....in the lower right hand corner you should see a white lightning bolt. Tap the red circle 2 times and you should notice that the yellow lightning bolt now stands alone and the red circle and the red line has been removed (now your flash is on). Note: Each time you turn on the camera and you need flash, you will have to make this adjustment...I hadn't figured out a way so that it happens automatically..
THANKS.
Apr 11, 2011 | Vivitar Cameras
DVD side of SLV-D350P does not play DVD. Shows loading and Sony logo screen. Pressing any buttons on remote gets me a red circle with a line thru it in upper r/hand corner.
Open the DVD door/drawer and let the warm air get to it. Condensation which can form is dried and the DVD worked again. Leave open for 3 to 4 hours.
Dec 27, 2009 | Sony SLV-D350P DVD Player/VCR
I have a 32in element flat screen had for couple of months now tonight there is a black box in the middle of my screen what should i do
I would like to know the same. We purchased ours on 10/25 and on 12/29 a black half moon shape showed up in the lower left hand side of the screen. Now the rightmost side of the screen is almost covered in black circles. There are also varying widths of lines going up and down on the right half of the screen.
We have tried contacting cusomer service and keep getting voicemail.
Nov 05, 2009 | Element Electronics FLX-3211B 32 in. LCD...
Psp hanging
The circle in the lower right hand corner of the PSP screen is showing that a disc is being read. I would say take out any discs you're using and try to run things directly off of the memory card. I'm not going to dive into anything else, because Custom Firmware on the PSP is a tricky situation that you really shouldn't be asking about on FixYa.com.
Oct 06, 2008 | Sony PlayStation Portable (PSP) Console
Red lines on right hand side of the screen now no picture on right hand side!
I'm not an expert, but I have determined that the vertical bars that are often red, sometimes blue ... and sometimes both ... are related to a bad control board. I've also read that a common fix is to buy a repair kit with includes the ysus, zsus and control boards ... all replaced together. My experience was that after a month or two with the 1.5" wide stripes, that you eventually loose the entire picture and have sound only. MIne comes back, but won't stay working for very long and the stripes are always there (buy used to fade and flicker sometimes). I'm planning on replacing the control board.
Jun 09, 2008 | LG DU-42PX12XC 42 in. Plasma HDTV
Protron PD-DVR100 DVD Recorder Logo
125 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
