Question about Kenmore 46462 Front Load Washer
INSTALL DRIVE BELT FOR FWX833AS1
THIS BELT WENT OUT. I BOUGHT ANOTHER ONE AND AM HAVING TROUBLE WITH PUTTING THE BELT ON.
    Scholar:
  • 112 Answers
You have to put it on the motor pulley first, and then "walk" it around the larger pulley by starting it on one side and then pulling it on the the pulley by turning the drum.
Posted on Oct 15, 2008
How do you tight the serpentine belt in a matrix. when i am putting in the alternator back in place but am having trouble putting in the belt on it.
It takes a long wrench to turn the bolt for the tension pulley.
You release tension on the belt to remove it, then let go of the pulley when you have the belt back on.
The tensioner is spring loaded and keeps the belt tight.
There is a video on YouTube.
Mar 06, 2013 | Cars & Trucks
My power steering pump went out. Went and got a new one but having trouble getting the pulley on. Is there a easy way of putting this on.
There is a special set of tools for taking the pulley off/putting it back on. I bought the set from Harbor freight for about $15.00..This set is available at most auto parts stores and the price may vary. It is called a pulley remover/installer set.
Sep 13, 2011 | 2000 Ford Taurus
Having trouble putting serpentine a/c belt on 2000 chevy silverado with 4.8 I cannot get it around pulleys
if you are using the tool to release tension of the belt tensioner and you are putting the belt on the pulleys in the right sequence as shown on the under hood decal and you still can`t get the belt on then you have a belt that too short for the application either the wrong belt in the sleeve with the right part number or it`s just plane too short of a belt
Mar 02, 2011 | 2000 Chevrolet Silverado 1500
I'm having trouble replaceing the motion drive belt on my LT1000 lawn tractor. The mowing deck is off, the old drive belt is off. I can't get the belt around the transaxle pully. Any suggestions?
Often there is a keeper on the back of the pulley, and the belt must go inside the keeper. Get an inspection mirror up in there to look if necessary. Start by putting the belt on the transaxle pulley, then on the PTO pulley, then on the idler, last have someone sit on the mower and depress the clutch pedal while you put the belt over that pulley.
Sep 26, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a hoover wind tunnel model# u6476-900 and I'm having trouble replacing the belt. The extra belt that came with it was belt # 38528-035 and it's smaller then the old one and I'm having a hard time...
yes it is the right belt. the easiest way to get that belt on is to put it on the motor shaft first, stretch and start at the top of the self propelled pulley and rotate til the belt tracks on. you will need to keep pressure on the belt while you rotate the pulley. make sure you install the 38528-034 first before the flat belt
Jan 07, 2010 | Hoover U6476-900 WindTunnel Vacuum
Putting a belt back on... issue
you have to put a wrench on the belt tensioner rotate it all the way back, this allows the room you need to install the belt
Oct 10, 2009 | 1998 Oldsmobile Regency
Having trouble reinstalling alternator belt on 2005 chevy impala 3.4
TELL ME WHAT TYPE OF PROBLEM YOR ARE HAVING PUTTING ON THE DRIVE BELT BACK ON THE ALTERNATOR.YOU NEED A TENSIONER TOOL.ITS LONG AND FLAT.YOU PLACE THE 3/8 SQUARE ON THE TOOL.IN THE 3/8 SQUARE IN THE TENSIONER.YOU PUSH TOOL TOWARD REAR OF CAR.THE BELT WILL HAVE ENOUGH SLACK TO GET BACK OVER THE ALTERNATOR PULLEY.
Sep 18, 2009 | 2005 Chevrolet Impala
Trying to find out how many inches of belt i would need for a 97 crown victoria without the airconditioner is it a serpentine belt or drive belt
all the parts places i called said i wouldnt be able to get an accurate measure of the belt and suggested i get a airconditioner bypass pulley system that takes the place of the airconditioner pulley so i went and bought one and i will be putting it on today
Sep 15, 2009 | Lisle Serpentine Belt Tool
MY VACUUM IS NOT PICKING UP
Hi This is quite complicated but I'll try and simplify this for you:
If this is a Panasonic upright then there are two drive belts as you know. Once you take off the sole plate (where the beater bar is) by undoing screws and the beater bar is looking at you, you would have to take off the smaller belt motor pulley first before putting on a new larger drive belt. If the smaller belt is still intact and you only need to replace the larger belt, you'll still have to take off both belts to put on the new drive belt.
Motor pulley belt has to be taken off first then the old drive belt, then grasp the beater and slide on new larger drive belt before having to attach the motor pulley belt and then the larger belt onto the motor pulley. Once all belts have been attached ensure that the beater bar is pushed in correctly before you screw the sole plate back on.
Apr 03, 2009 | Panasonic Vacuums
Changing the belt
flip over
remove 3 phillips head screws and remove cover
pull agitator roller out of groove opposite end of drive belt area
install new belt by putting loop around silver drive shaft then putting over belt roller
put roller in appropriate grooves( belt will feel stiff make sure belt stays on roller and under drive shaft put cover back on
You are ready to go!
Jan 03, 2009 | Eureka Luxury Family 8-Person 2-Room Titan...
Kenmore 46462 Front Load Washer Logo
64 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
