Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 60" HDTV
There is alot of blue around all images especially words and dark backgrounds. I tried to adjust the convergence, but it didn't help. Any suggestions?
  • Philips Master
  • 19,396 Answers
If the blue looks like an aura of light around the picture then it is likely to be a problem with the color wheel, probably it should be replaced.
Try first doing a color auto balancing (magic focus) and see how it goes, probably you will need to replace color wheel.
Posted on Oct 14, 2008
  • Ginko
    Ginko Oct 14, 2008
    Use the Auto IntelliSense Focus , that is the name for autofocus on Philips DLPs, if that does not work you may need to replace color wheel, or to have the TV repaired by a technician.
    If you need to call a technician, or the TV is still under warranty, or you want to buy a guaranty extension, you can use the model number listed on the TV owner manual.
  • Ginko
    Ginko Oct 14, 2008
    Errata: I mean you can call the "phone" number listed on the last pages of the user manua.
You can see the red blue and green lines on my tv it is like it is out of sync
I'm not sure what you mean by the "lines". If you mean the image looks like "double" (or triple!) vision, then you need to adjust the red/green/blue convergence. This is especially noticeable with white images on dark background (like text of credits). If this is it, check you manual or explore your menu via the remote. Sometimes convergence can be a problem if the tv was moved or experienced large changes in temperature... or sometimes all by itself!
Jan 22, 2011 | RCA D61W20 61" Rear Projection Television
Our phillips 60" TV
Ur convergence is dead.Know how to solders?Must changed the 2 convergence ICS,and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergencce kit.The shop will cost $300 for parts and labors.
Feb 01, 2010 | Philips 60PP9202 60" Rear Projection...
BLUE CONVERGE NOT WORKING
most likely convergence IC's usually 2 of them
Aug 10, 2009 | Philips 60PP9202 60" Rear Projection...
I have a philips rear projection 60 inch model60pw936317f its got kind of a 3 d blue line on all the words
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Feb 28, 2009 | Philips 60PW9363 60" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence contols on Philips 60PP920217F
You have bad convergence amps and most likley 2 bad resistors in the convergence circut.
Jan 10, 2009 | Philips 60PP9202 60" Rear Projection...
My Philips HDTV 60PP9202 has blue and red curved lines
Check to see if you can adjust the convergence. If you can't adjust the red and blue in all directions you need to replace the convergence chips and resistors. If you not sure how to check the convergence goto the site www.TvRepairKits.com and goto the Tips section.
Dec 25, 2008 | Philips 60PP9202 60" Rear Projection...
Double image in bright blue with philips model 55pw9363/17f
You may have 1 of two problems.
1) Convergence Chips are failing - Using your original remote goto the "convergence" screen.
Try to adjust the red - UP - DOWN - LEFT - RIGHT
Next try to adjust the blue - UP - DOWN - LEFT - RIGHT
If you can move both colors in all directions you do not have a convergence issue.
If you can't move one or more colors in one or more directions the convergence chips are defective and need to be replaced.
If your convergence chips test out ok the most likely problem is......
2) CRT Coolant is cloudy  - The bright outline you described is one common symptom. Other symptoms include dull images, red or orange tint, halo around images.
If you goto the site www.TvRepairKits.com - and click on "Tips" - you will find more detailed instructions on how to check the convergence.
Dec 04, 2008 | Philips 55PW9363 55" Rear Projection...
Philips 60
sfriley are you seeing tripple?
Jul 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 43PP6360/79
if the hase your refering to a glowing halo its the blue coolant that needs changing. If it causing a 3D image then its the convergence ICs need changing
Mar 23, 2008 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
79 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
