Question about M-Audio Delta Audiophile 2496 Sound Card
Not receiving input through spdif connector
We digitize tapes using a Midiman Flying Cow a/d converter and
Sonic Foundry's SoundForge 6.0 software. I just got a new Dell
XPS 360i, installed the old software, and installed the old M-Audio
Delta Audiophile 2496 sound card. I downloaded and installed a new
Vista driver for the sound card.
SoundForge recognizes the SPDIF connector as an input device, but
I don't get a signal. I can get audio through the Line 1/2 inputs on the
sound card (connecting the tape player directly to the sound card.) That's
not what we want, though; we want to use the external a/d converter.
The old driver that came with the sound card (must have been for
Windows XP) didn't seem to work. SoundForge offered the input device
choice "Bad wav input 2". I tried it; it didn't work :-).
It's probably something to do with the driver settings, but I don't understand
them - they're not enough like the old ones for me to figure out. Please help!
Thanks!!
Heidi
The Archive of the Indigenous Languages of Latin America
2 Suggested Answers
jamesmac
  • 71 Answers
SOURCE: RECORDING GUITAR USING AUDIOPHILE FIREWIRE AND GUITAR RIG 3
I've ran the audio in on my sound card to my mixer and had the guitar on the mic in.  I've also ran the line in to a small cracker amp.  Keep it turned down. If I would directly connect it use an adaptor.  I haven't tried using a 1/4 to 1/8 adapter and directly connected to it as I wanted to control the tone. I don't see why it wouldn't work.  Keep everything muted and turned all the way down when you first connect it.  Then start raising volumes slowly  I will try and report back As far as spdif you're just recording analog to digital conversion.  I get more realisitc sound just keeping it analog til it hits my line in.  Have a quality sound card.  Not some walmart special.  I use Adobe Audition 1.5 to multichannel record.
Posted on Sep 09, 2008
Does the LCDVD326A have the ability to attach headphones? If so, where are the connections?
First of all, here's the manual:
http://www.curtisint.com/html/custservice/manuals/CUR_LCDVD326A_EN.PDF
Refer to page 11. Apparently this set only has audio input connections (as analog audio) It does have an audio output but it is digital audio. you can't just plug in speakers or headphones, you need an adapter to convert digital to analog.
If you're a techie and want to know about SPDIF, look here:
Everything You Need to Know About the SPDIF Connection Hardware Secrets
You will need the converter:
Fosmon Digital to Analog Stereo Audio Converter Adapter Changes Digital...
and a cable to connect the adapter to the TV (choose the length you want)
AmazonBasics Digital Optical Audio Toslink Cable 6 Feet 1 8 Meters
they don't make it easy, do they?
Good luck
Oct 19, 2013 | Curtis LCDVD326A TV
Now that Midiman/M-Audio has been eaten up by Avid, does anyone repair Flying Cow AD/DA converters?
paul .i worked with jack douglas many years ago.question do you repair soundtracs console. anthony 1 212 213 1731 hope your well.ps im up late
May 18, 2012 | M-Audio Flying Cow (99004074400) Analog to...
What is the opticalout with usage
Optical out is Digital Sound output, which is used to connect speakers with Digital Sound input. This port, (also known as SPDIF, TOSLINK), is used to send digital audio from your PC/ television to a sound bar or stereo receiver.The signal is transmitted over either a coaxial cable with RCA connectors or a fiber optic cable with TOSLINK connectors.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | ASUS P4P800-VM Motherboard
Connecting a receiver to a computer
No. That's for connection between JVC compatible units.
Not knowing what kind of inputs your PC takes: if it has only analog RCA-type inputs, run a pair from the receiver's tape out; if the PC has digital toslink (optical) or spdif (coaxial) inputs and the receiver has some sort of digital output, use that.
You could also rig a connection from the tape out, using adapter cables, to the PC's headphone in.
Jan 18, 2010 | Audio Players & Recorders
When connecting hdmi out from my panasonic blue-ray player to the dvd input in my yamaha rx-v365 there is not audio or video,why?
There are several video and audio inputs named DVD. For video you have HDMI, component and composite. For audio you have standard analog stereo and digital coaxial spdif input.
You need to configure the receiver to use the correct inputs - that means HDMI and coax. Also you need to connect the BD player via coax spdif cable to the receiver, because rx-v365 doesn't support audio via HDMI. If BD player has only optical output, use DTV/CABL HDMI input and DTv/CABL Optical input on the receiver.
Nov 23, 2009 | Yamaha DVD-S661 HDMI DVD Player
Sony playstation 1
If you can borrow anothe lead for the ps1 try that.
Also check that your display is also set to the correct input.
If that produces no result then you may need to have it repaired.
if this information was useful please click
Aug 13, 2009 | Sony Pictures / Sonic-Foundry 1001 SOUND...
TOSLINK to SPDIF ?!?
Hi, check on ebay for toslink digital converters(radio shack),
cheers.
Nov 19, 2008 | Sony DTC-ZE700 Dual Cassette Deck
Pioneer vsa e06
depends what audio outputs you have on the sky box,analogue (two phono usually red for right channel and white left channel)in which case just use phono leads to the phono inputs,Optical(toslink),connect an optical cable from the output to the optical input on the dvd channel of the pioneer,coaxial (spdif)connect to spdif input on the laser disk input of the pioneer,dont connect to the attenuated spdif.In the unlikeley event of the sky box not having any audio outputs,just use the outputs from the tv to the pioneer.The optical digital input gives the best quality on the vsa eo6
Jan 24, 2008 | Pioneer VSX-1015 Receiver
Composite Media
Well it can be one of two problems,,
Check your settings for the device, especially your input settings and see if composite is elected or disable. Look on the net for compatable recording software for the composite input as well..
Or
it could be a hardware issue and the device is defective..
Jan 14, 2008 | Computers & Internet
M-Audio Delta Audiophile 2496 Sound Card Logo
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
John Bolton
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
