Question about Refrigerators
Freezer floor has ice and spills out on defrost cycle
There is a layer of ice on the floor of the freezer section and when the defrost cycle runs it melts and gets all over the kitchen floor. I have defrosted the floor of the freezer only to have it quickly return. There is a small opening in the floor which is frozen. Do I need to open that for drainage?
  • 943 Answers
HI thanks for your question. yes that drainage hole must be cleared. unplug fridge for at least 24 hrs, pull fridge from the wall. remove back plate. clean all coils. locate the drain tube by the drain tray. put a small hose up the drain tube and blow to clear the debris. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 14, 2008
Why do I have ice build up in my freezer
Ice build on the freezer box floor or White frost build up on the freezer box back wall (inside). Ice layer on floor means your drain line blocked. White frost layer means your machine is not going into defrost cycle.
Oct 07, 2014 | Whirlpool Refrigerators
Do I need new frig or hav it repaired. Hav water under vegetable drawers
Its the defrost problem.In your unit the defrost cycle is not running on time.This is the procedure of the unit.--- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located.In your case the freezer gets cold, after that defrost cycle has to start, but in your case the defrost cycle is not starting on time so over ice gets internally build and when defrost cycle starts, this ice melts and this gets leaks in the vegetable and under vegetable drawer.-------- Get the defrost timer, and defrost assembly parts checked and repaired by the technician.Repairing will solve the problem.You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 04, 2011 | Frigidaire GLRT216TA Top Freezer...
GLRT216TAW2 Model Number. Water under vegetable drawers, No other water leaking. Back is dry, Do i need a repair man or new refrig which is only 10 yrs old.
I have a Matag Refrigerator Model MTB2156DEW. The freezer is located on the top of the fresh food compartment. For approximately a week the refrigerator has been constantly running without cycling. ...
Defrost the unit. The fridge section cannot cool if the freezer is iced over since the fridge gets its cold from the freezer. If you don't have a second fridge use a hair dryer to speed the defrost.
Apr 06, 2011 | Maytag 21.7 Cu. Ft. Top-Mount Refrigerator...
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you unclog the condensation drain on a GE gss25wgma model refrigerator? have water pooling and freezing on the freezer floor, spilling out onto the floor within days after removing it. Thanks!
usually the drain hole underneath the evaporator in the freezer section can restrict with anything from ice to bugs. take a wire hanger and try to run it all the way down into the drain pan. if you have ice then try to poor cool water over it to defrost ice. then use hanger
Jun 22, 2009 | GE GSS25JFM Side by Side Refrigerator
Water leaking from the left lower corner of the freezer
there is a drain at the bottom of the evaporator in the freezer section which is blocked,pour some hot water into the drain and that may unblock it
Jun 07, 2009 | Frigidaire FRS26ZSG
Freezer Defrosting
After a defrost cycle the ice around the evaporator melts, that water goes out and lands in a tray under the refrigerator. But sometimes the tube gets clogged and water spills inside the freezer and if enough water accumulates, it will make it to the floor. To fix this problem look for a small hole inside the refrigerator and open it up using a can of compressed air. Hope this helps
Aug 05, 2008 | Freezers
Water for some reason is coming out of the bottom we just happen to find it. also It is drippinging and freezing in the bottom of the freezer we clean it out and it comes back, but the water on the floor...
Sounds like you have a side-by-side...
The defrost drain is probably clogged or frozen. When the fridge runs a defrost cycle the melted water cannot reach the evaporator pan underneath the refrigerator. Some water makes its way out onto the floor to wet your socks, and some re-freezes inside the bottom of the freezer compartment creating a layer of ice.
Jul 25, 2008 | Frigidaire Refrigerators
Layer of ice in freezer.
a frozen defrost drain pull the back panel in the freezer section see if the drain hole is stopped up after clearing the ice
Mar 03, 2008 | Refrigerators
Refrigerators Logo
269 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
