Question about Epson Stylus CX3200 All-In-One InkJet Printer
Epson stylus cx3200 all in one ink jet
Cant seem to get the colours through properly.pictures scanning ok but colours all wrong. do not have instruction book can you help.
  • 55 Answers
You cannot seem to print properly. You can try and do the head cleaning.
For windows
just click on start / settings / printers & faxes
Check on the example below:
Right click on the printer icon then left click on printing preferences
Go to maintenance and click on head cleaning
After the head cleaning press on print nozzle check pattern. Check the patterns and see if there is gaps or breaks on it like this examepson stylus cx3200 all in one ink jet - 8dee7bf.jpg
Note: If there is gaps or breaks it explains why you cannot print properly because inks are not distributed correclty. If there is no gaps or breaks it means the printoepson stylus cx3200 all in one ink jet - c6f9621.jpgfine.
For Mac users
Then click on confirmation then press Next. It will print on the nozzle check pattern.
Posted on Oct 16, 2008
When I print out picture, pictur came out so many pink stripe across the picture.
There probably is nothing wrong with your PINK ink-cartridge.
It's one (or two) of the other colour ink-cartridges that either are EMPTY or having CLOGGED ink-jet mechanisms.
Run a "print-head-cleaning" cycle.
Aug 27, 2010 | Epson Stylus 1400 InkJet Photo Printer
Although new black cartridge insalled (colour OK) page will not print in black - seems a blockage?
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape. Not every cartridge that fits the printer necessarily works.
Nov 13, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus cx3200 wont print good.
You're jets are pretty much shot. Have you recently used generic ink or used ink that has sat for a while? I had almost the same model and bought my ink in bulk not thinking about it and same thing occurred. Time to upgrade to a new printer...sorry.
Oct 30, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Epson cx3200 wrong colour
It is possible that when the printer senses not enough black ink it will swap to using the colour tanks to try and make a BLACK.
It is also possible that you have mistakenly adjusted a setting in the epson printer program to use the colour tanks to print black and white photographs.
Either of those would certainly cause the problem you describe
Check ALL your printer settings both the windows ones AND your epson ones
If you found this information useful pleas click below
Aug 12, 2009 | Epson Office Equipment & Supplies
Epson sx200 One of the colour inks is empty and no print in black
Hi, this is not a solution because I don't think there is one apart from buying new inks. Epson and all other inkjet printers do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Printing in black only option will only work if the colored inks are OK. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing.
Apr 02, 2009 | Epson Stylus CX3200 All-In-One InkJet...
My epson stylus cx3200 is not printing in black but does print colour even though ink levels in both colour and black cartridges are fine
If you are brave I had the same problem. I removed my ink disconnected the data ribbon to the Head. Took off the nozzles. I used a child's med. syringe with the tube. Filled it will rubbing alcohol. placed the tube on the head where the ink cartage attaches and slowly put pressure on the syringe. Be care full it will flush the black ink everywhere. I kept doing this till the black was all flushed out. Put it back together. make sure you put the ribbons back in the right way. Mine works great.
Mar 04, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Spaces and gaps in black printing
I cleaned the ink heads and it fixed the problem.
Jan 07, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Changing black & colour ink cartridge
My guess is that it will be the non gen carts they cause heaps of trouble, beleive me. Hard to tell you for sure but the first thing I would do if you brought it in for repair would be to put in manufactures cartridges.
Dec 01, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
