Question about Acer AL2017 20" LCD Monitor
Acer AL2017 20 inch LCD Monitor comes on for 2 sec during start up then goes black. I 've had it for a year now. During start up it comes on 2 sec goes black then as the start up continues comes on 2 sec goes black. Any solution WAZ
  • 1 more comment
  • lima126 Oct 15, 2008
    Hi thanks bammbammfran
  • ctsui7 Dec 29, 2008
    I'm having the same problem with the monitor not coming on! I'm guessing it's the power/inverter board since the light comes on but I get no picture at all. Does ANY1 know where I can find either the power/inverter board or capacitors to fix this cheap monitor... I know you get what you pay for but come on!!
  • Anonymous Feb 07, 2009
    I'm having the same problem. How did you fix the pwoer supply board or does anyone know where I can get a new board?
    Novelist:
  • 159 Answers
Hi
I repair monitors
Based on other models , it sounds like you are having a powerboard-inverter issue.
It just so happens that I hjust got one in that's doing that, I should know in a day or two (maybe sooner) what the whole story on this model is.
Good timing !!??
ebaysbammbammfran
Posted on Oct 15, 2008
  • Fran Bednar
    Fran Bednar Oct 15, 2008
    I had 20 minutes to open it, so I did.
    Not a fun one to open up !!
    As I guessed, I found 6 bad capacitors So you problem is more than likely the same, They must have used cheap ones !!!
    Fran
  • Fran Bednar
    That fixed it !!
Hp f2105 black screen after 2 sec on?
You've asked this question in two places. This is confusing--try to ask it in one place only.
I answered it in your other request.
Nov 20, 2011 | Rosewill R700J 17" Flat Panel LCD Monitor
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
The laptop screen is almost blank/black. an external monitor is working ok. when i close the lid of the laptop and open it again the screen comes on for a sec but then goes off again almost blank/black....
As per Dell Technical support LCD kit needs to be Replaced.
I Would recommend to
Run PSA Diagnostics. Check for PSA Error codes
if unable see display during PSA Diagnostics use External monitor to make note of Error code.
Check Error code on support.dell.com
If no Error codes. Then Only option is replace LCD kit
Jan 19, 2010 | Dell Latitude D430 Notebook
Acer monitor swtiches itseolf off in i9n about 15
After much ado and waiting for tech support from Acer, remembered that some years ago something similar happened with a printer so I downloaded a new driver from acer for the monitor onto another computer, copied it to cd and then with much fiddling installed this on the acer, as it was installing monitor started to flicker and finally lit up again normally. Now working perfectly! When tech support phones, will tell them!!!!!!
Nov 20, 2009 | ViewSonic VX2235wm LCD Monitor
Monitor comes on for seconds and then goes black
This may be because the resolution that is set in your user profile when you log on has been changed to a resolution not supported by the monitor. The best way to fix this is by going into Safe Mode (press F8 as the computer starts to load Windows) and change it to a lower resolution once you get logged in. 1024X768 is a pretty safe resolution to start with. Then restart and see if that fixes the issue.
Sep 02, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
VX 910. Goes to black every 10 to 15 seconds then comes back on after 3 to 5 seconds With ''analog'' displayed in the lower right corner. Happens when connected to 2 different computers.
hi my lcd AL1916 acer monitor keeps going black or loosing signal after 2 or 3 sec. i press the moon on my keyboard 2 times it comes on then off again please help
Aug 11, 2009 | ViewSonic VG930m LCD Monitor
Won't come on
Try starting it after unplugging the devices Viz. Printer, Modem, ADSL, then during bootup Press F8 key to start it in Safe Mode..
Once you get in.. Run a checkdisk and diskcleanup.. and run Virus Scan etc. to get back in Normal mode.
Thanks
Scott
Apr 28, 2009 | Acer V193w LCD Monitor
Black Line bottom of LCD Monitor
May be a manufacture defect or the Screen goes wiped out during transportation.
Call to the support for warranty issues immediately.
Regards
Ellin
Sep 26, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor works at Startup, then goes black
yes you can fix this problem go in to start menu then control panel then double click display, then screen resulution and add the secondary screen, bc windows doesn't add the screen automaticlly you have to do it this way
Dec 15, 2007 | Computers & Internet
Acer AL2017 20" LCD Monitor Logo
583 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
