Question about HP Pavilion dv9000z Notebook
I think i am connected
Hiya again, i think the connection has worked. are you able to access my pc? thank you
hayleybear12
Hiya,i can"t connect to the
It depends on the connection mode you are using.
If you are using a wired network connection, then you have to ensure that your pc is configured to the address of the network you are using. Make sure that you have the correct IP address configured on your system. If you can not do this yourself, contact the technician who installed the connections to help you further.
If you are using a wireless connection via wireless LAN, ensure that you search for the network. Go to the notification area icon at the bottom right of the screen, right click on the internet access icon, and search for the network. Before you connect to the network make sure you have access to it.
If you are using a modem, be sure that the subscription is intact. You should have subsribed to a bundle.
When you have satisfied those conditions you click on connect.
If you have further problems, feel free to let me know by posting a comment on this post.
I hope that fixed your problem?
Have a lovely day.
Jun 27, 2011 | Computers & Internet
Acer travelmate 290 wireless switch crashes laptop
Its probably the driver, you'll have to go to the acer website follow links for support and downloads. Download and install the latest driver for your wirelsss modem.
May 04, 2010 | Acer TravelMate 290LCi Notebook
Hiya, i think i've lost the power supply for my Belkin Wireless G
Yes you can get a replacement power supply from any computer store near you, and when the router is already working better reset it and reconfigure to do a fresh installation on it that will correct your problem...
Aug 13, 2009 | Belkin (F5D7231-4) Wireless Router
Onix wont accept music download
dear first check ur internet settings in ur onix. if not plz configure it. but the fact is for access internet u need internet service provider. i think u can use internet from ur pc connected ur onix with pc. when ur pc is connected net then ur onix is also with connected net. then u can access from it. thanks
Jul 27, 2009 | Audio Players & Recorders
Network trouble
do you get generic host win 32 error
Jun 22, 2009 | Nokia N70 Cellular Phone
Screen picture froze, powerd down, powerd up, blank screen
open cbinet of crt,
then internally check circuit connection.
or check for external lead connect very well or not ,one of power,and data cable.
Jan 25, 2009 | Acer Aspire 5100 Notebook
My wireless connection is not working on my Lenovo, t61, Thinkpad. When i called the technical support they told me i might have pressed a button on my computer to disable the wireless connection and I...
yoiu can press the button again and when promted eturn turn back on the wireless radio . also there is the access connectipons that you can run and that will set it up for you
Dec 23, 2008 | Lenovo ThinkPad T61 Notebook
Belkin can't work it out!
If u r wi-fi router uses encryption u have to put it in u r connection wizard and trying putting DNS servers of u r service providers.
Oct 24, 2007 | Belkin (F5D7231-4) Wireless Router
No signal
Is the wireless switch of your pC on? if it is, then try to reboot your PC and the router. You should see one. Check also if the SSID broadcast of your router is enabled.
Oct 06, 2007 | Compaq iPAQ Connection Point CP-2W...
No Signal
hey i hope this issue has been resolved by now... ami i right .. if its not then jus lemme know n i l post ya the exact solution for this one ,,, i think its a very minor issue,,, plz respond
Aug 18, 2006 | Compaq iPAQ Connection Point CP-2W...
HP Pavilion dv9000z Notebook Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
