Question about Sansui Televison & Video
Two DVD's are stuck in slot -- will not eject. I did not realize that a DVD was in it and slid another in -- now they are both in there. Dumb Grandma
  • pwick0229 Oct 14, 2008
    Thank you -- you are wonderful!!! Now this Grandma will not look foolish to her grandchildren.
    THANK YOU!!!
    Genius:
  • 1,124 Answers
Hold down the power button a while to unlock the deck.
If not work open the unit to release the DVD.
Posted on Oct 14, 2008
  • Sansui Master
  • 19,396 Answers
Press repeatedly the eject button while you restart the unit.
  • Ginko
    Ginko Oct 14, 2008
    The DVD wont probably eject now, as the two dvds are stuck inside, try first the following:
    Unplug power.
    Plug it back and press repeatedly the eject button while you turn the machine on.
    If that does not work it means that the DVDs are really stuck inside.
    In this case get somebody that is good at using a screwdriver to help you, ask to unscrew the bottom screws from the unit (after unplugging power) and so access to the dvds.
    Once you access the DVD tray, removing the disks from the inside won't be too difficult.
    As usual, DIY at your risk.
    Let us know how it goes.
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
How do you open the mouse case, I realize this sounds dumb but I can't seem to see any way to open the mouse case?
Hello, is it to get to the batteries? if yes, try sliding back the top rear half of the mouse, the bit that has the logitech logo on it. Once slid back it will then lift off. Easy when you know how! :-)
Regards,
nicam49
Jan 04, 2011 | Logitech Cordless Mouse
Nextbase slot-in portable DVD player with a stuck DVD.
You can either use a paper clip and bend the metal so a long metal part pokes out. Push this metal part of the paper clip into the DVD player where there is a small hole for emergency openings when no power is available to DVD players. The other option is to unplug the DVD player, then unscrew the casing off the DVD player and then you can manually use your hands to remove the DVD. Cheers, eiger3790.
Jul 28, 2009 | Televison & Video
A cd is stuck in my macbook.
The same thing happens to me all the time.
Ok so, you have the cd in ur laptop. Restart your laptop and hold the "eject" key until it comes back to your desktop. If your computer cant restart, hold down the power button till its off then turn it on again and hold the eject button. And hopefully it will come out.
Hope I helped
**Dont forget to rate**
Jul 10, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Same as others. DVD stuck..won't play, won't eject
I use a produce bag tie. Stick it in the bottom of the dvd slot after pushing the eject button and the disc pops out for me.
Jun 10, 2009 | Mintek LCD TV Progressive Scan DVD Player
CD stuck in laptop
There is a very small hole in the cd tray, left or right side of the eject button of the CD/DVD tray.... insert a very small needle or a hardwire of 2 inches length and the cd will automatically come out of the tray..
Cheers - Parveen
Aug 03, 2008 | Toshiba Satellite A45-S150 Notebook
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
Stuck DVD
there should be a small pin hole in the draw of the dvd, put a pin r paperclip in the hole and push to manually open it.
Sep 16, 2007 | Samsung DVD-VR330 VCR and DVD Recorder
Televison & Video Logo
91 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
