Question about Microwave Ovens
My sharp r-1381 is shooting sparks out the top of it any do it your self fixes?
  • Anonymous Jan 19, 2009
    shooting
  • Microwave Ovens Master
  • 8,968 Answers
That model has a stirrer motor and blade in the ceiling above the waveguide cover.
Arcing can occur if there is grease or food particles on the front or back of the stirrer cover, on the blade or around the motor shaft.
You would need to remove the stirrer cover and inspect the parts, then use a damp cloth to wipe the parts clean.
We have a partial service manual for this model and have uploaded it to our site here to help you. You may also need to refer to this base manual.
You will need the free Acrobat Reader to view or print them in case you don't have it already.
The best place to order Sharp parts is Tritronics.
Posted on Oct 20, 2008
  • William Miller
    William Miller Oct 20, 2008
    CORRECTION
    Sorry, but the first service manual link above should have been here.
    The base manual link is correct.
When the unit is turned on it shoots flames from the roof of the unit WHY?
It sound like the antenna behind the plastic plate may be warped and touching the cavity. From my experience when they start shooting sparks it is time for a new microwave.
Apr 23, 2015 | Sharp R-820BK Microwave Convection Oven,...
I have a sharp p-651zs microwave and it does not work I opened the back and found a small switch type thing on top of of the magnetron with two wires ,it is not conected to the magnetron. Can you t
That is probably a thermal safety. Be glad it did not turn on with the covers removed you can cook your self very quickly unless you are trained in servicing them.
Dec 06, 2014 | Sharp Microwave Ovens
Shooting sparks out left side near bracket for shelf
if there are any sparks inside the cabinet it is time to throw the microwave out or send it out for a powder paint $$$$$$
Nov 27, 2013 | Kenmore Microwave Ovens
Sharp R402JK-T sparking on starting
Unplug the unit and do not plug it back, I can almost picture someone doing this, watching the sparks and smoke and oh the lights dim--Be smart here===either replace it out of hand or take to a repair shop to see if worth fixing or not and do not attempt to turn it on again.
Dec 12, 2012 | Sharp R-9H66 Microwave Oven
My tappan microwave just stopped working. I changed the fuse it worked for 15 seconds and blow out again.... Please help im dependeant on my microwave. Thank You Sonia
Did you hear any popping or weird sounds while you turned it on. If you are on a fixed income you can fix it pretty cheap if the inside paint on the top is coming apart. This makes the metal shoot an arc across the cage from the power source. Am I making my self clear here? I have fixed on like that before. If there is any other reason besides that causing it to burn the fuse most likely it cannot be fixed cheap. I used white appliance spray and coated it a few times.
Jan 04, 2011 | Microwave Ovens
My microwave door sags to the right from the top hinge. The microwave is a Sharp R-930CS. How do I adjust this?
The only adjustment is by removing the outer cabinet and examining the hinge side will be self explanitary.
Beware that the door must close squarely and if it is very mal adjusted will take out the mains fuse!
Oct 19, 2010 | Sharp R930CS Microwave Oven
Sharp r-930ak microwave oven is sparking
A dirty or damaged wave guide cover can cause sparks, fire and noises. You can order a replacement wave guide cover from many appliance parts websites for less than $15 in many cases. It should fix the problem.
May 03, 2010 | Sharp R-930AK Convection/Microwave Oven
I put a mental bowl in the my Sharp micro modelR-1610 saw sparks took it out and now it still sparks what can i do to fix it..
sounds like bad shorted megatron or transmiting at wrong freq 2 repair this replac hv cap if u dont have a knowledge or electriciyt do not attemp a microwave has about 15 thounsand volts in side and x raditation it will kill u just because it unpluged its has a 100 years later it still has that charge until it physicaly released good luck shan
Aug 29, 2009 | Sharp Microwave Ovens
Dacor Microwave
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
The waveguide cover is usually about the size of a playing card and often held in place by a plastic rivet.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced.
The part would be much cheaper if you get the Sharp version (these ovens are made by Sharp) instead of the Dacor branded part.
The model DMT2420 is essentially the same as model R440D / R540D.
The Sharp part number is PCOVPB085MRP0 (zero on the end) and you can order Sharp parts from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 17, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
Microwave Ovens Logo
103 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Are you a Microwave Oven Expert? Answer questions, earn points and help others
