Question about Aloha Housewares Breeze 29" Tower Fan
Tower fan The product did not come with a manual or screws to attach the base. Where can I get both items?
    Master:
  • 492 Answers
Go to any auto store or hardware store (Lowes/Home Depot) and buy a small assortment box of screws for $5.00. They will have he right size in the assortment. Manufacturer should have a manual on-line.
Posted on Apr 30, 2009
Hy108tgt
Our HY-108 (not a HY-108TGT) does not have a filter when it was purchased new from a Retailer.
IMHO, Honeywell/KAZ designed these Tower Fans to be disposable if they fail to work or need cleaning.
These Fans are hard to disassemble for service or maintenance, OEM replacement Parts are unavailable to the general public, service documentation is hard to find, and the Tower Fans tend to have a short Product lifespan. THEY BREAK EASILY! The OEM Service Manual points to replacing complete parts assemblies because few electronics diagnostics and no schematics are provided.
The HY-108 case can start to be disassembled (I have done so on ours) by *First* removing the screws and separating/removing the plastic Base from the main Case assembly. *Second* remove the Phillips-Head screws on the back of the Case. *Third*, the internal plastic 6 Tabs that keep the 2 halves held together need to be gently separated - careful, they break easily. You need to gently loosen the internal plastic "Tabs" by using a thin flat-head screwdriver to gently and carefully separate the outer shell cover.
Apr 19, 2014 | Honeywell Dryers
What type of screw driver do u use for a lasko 2543 tower fan? I would like to clean it and have never seen screws like this.
You may need to check the owners manual. If you have lost the owners manual, you can download a new from this site for free: http://www.laskoproducts.com/?s=Manuals... Just type "Tower Fan" in the search box and browse through the results until you find your model.
Aug 07, 2012 | Lasko Products 41" Elite Tower Fan 3spd -...
Motor stopped working. I need aloha breeze phone number
Aloha Breeze fans are manufactured by Litex. You can contact them at:
3401 West Trinity Blvd.
Grand Prairie, TX 75050
Phone: 800-527-1292
Jul 20, 2011 | Tower Aloha Breeze Fan
I need to take the fan apart to clean all of the dust inside. how do I do that
You will need a phillips screwdriver (preferably 2 different sizes - some of the screws are tiny), q-tips and a can of wd-40.
On the back of the brookstone (the darker gray side) you will find 4 screws inside of 4 channels. Take these out.
Put the fan on its head. pry off the 5 rubber bases and set aside carefully so as they won't lose their stickiness. You will see 5 screws beneath these. Remove them and then remove the bottom plate. Now remove the 2 screws and washers, noting that the rounded side of the washer was facing you. Now pivot the base so that the 4 holes on the outer part of the base line up with the 4 screwsheads that are screwed into the tower. Take these out.
The 2 gray tower pieces should now separate easily. set the fan on a newspaper and blow away as much of the surface dust as your can. Now use your wd-40 (with a straw nozzle attached) and spray into the motor area where the actual fan turns. Also spray, from the top down, along the metal rod that connects the fan to the motor.
Now use the q tips, dipped into warm water, to clean the dust from the fan "blades" and to clean any other nooks and crannies you can see.
Lube the motor up one more time, put the machine back together and leave to dry out overnight.
Will work like a charm afterwards.
Jul 07, 2011 | Brookstone MiniMax Tower Fan
Black & Decker BDTF1010B Tower
when you take all the screws out slide the back down. there is a screw at the bottom holding it from slideing the 9th screw so to speak. you have to take out the u shaped pin on the rod once that u shaped pin is out thats where you will find all the screws to the bracket holding the moter in place take all those out too. it seems like alot but it is really not.
Jul 12, 2008 | Black & Decker BDTF1010B Tower Fan
Tower fan 07586 parts (screws)
I have an Aloahbreeze Tower Fan. The remote control does not work,I put new batteries in and it still does not work. I am disabled and need the remote. It was a gift, as I have no income, so I cannot buy a new Tower Fa. Thank you, Sheila Pike Model No. 84001(FZ25-)
May 29, 2008 | Tower Aloha Breeze Fan
How do you open up a BDTF101B Tower Fan?
first you have to remove the two plugs on top behind the buttons remove the two screws next you have to remove the base stand and their is one screw you have to remove then you can remove the front cover and you can get to the motor and fan.
May 29, 2008 | Black & Decker BDTF1010B Tower Fan
Maytag SAV365ZAWW Agitator Comes Apart
The should be a bolt that goes thu the center that holds that down with the bottom part of the agiatator.. it might have pulled loose or rounded out the whole for the top part here is a link and a pic http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0153200&brandID=3048&modelDesc=WASHER&modelNumber=SAV365ZAWW&documentID=M0512408&documentTypeID=PLDM&documentClassCode=PV&titleType=TUB%2C%20INNER%20%26%20OUTER%20%28SERIES%2012%29&titleID=00010&
Sep 19, 2007 | Maytag SAV365Z Top Load Washer
How to open the casing
Question does the base underside have any removable screws that you can remove? If so, start from there. The top part of the fan should pop off with a screw driver. Exposing the screws securing the shell of the fan.
May 09, 2007 | Lasko 2115 Wind Tower Fan
Aloha Housewares Breeze 29" Tower Fan Logo
291 people viewed this question
Top Aloha Housewares Dryers Experts
Steve
Mike Carew
Fan Fair Of Boca
Fan Fair Of Boca
Are you an Aloha Housewares Dryer Expert? Answer questions, earn points and help others
