Computer Keeps Shutting Down on its own - Computers & Internet
    Genius:
  • 1,124 Answers
This issue could be caused by any of the below possibilities.
Heat related issue.
Hardware issue or error.
Computer virus.
Issue with operating system.
Other failing hardware
Heat related issue
A computer that turns off without warning is often a heat related issue. Many computers today are designed to turn off or automatically reboot if the computer, processor, or other device in your computer gets too hot. If you have heard any abnormal noises coming from your computer recently such as a high squealing, this could indicate a fan may be failing in your computer.
You can first start by verifying the fan on the power supply is working by examining the back of the computer and seeing if the fan is moving and moving smoothly. For all other fans in the computer, you will need to either open the computer and make sure the fan are working (processor fan and case fans) and/or if your BIOS monitors the RPM of the fans, enter BIOS and make sure the BIOS does not report any errors.
While inside the computer it's also a good idea to verify the processor heatsink is properly connected by disconnecting and reconnecting the heatsink. If the processor heatsink is not properly it will not keep the processor cool causing the computer to overheat.
Any failing hardware component in your computer could cause your computer to unexpectedly turn off without warning. If you have recently attempted to add a new hardware device, remove that device to make sure it is not causing your issues.
Before attempting to remove any hardware, make sure you are not encountering this issue because of hardware conflicts by viewing Device Manager for errors.
If you have not recently installed any new hardware into the computer, the next best solution to determining if this is a hardware issue would be remove any hardware on the computer that is not needed. For example, remove your modem, network card, sound card, and any other expansion cards that are not needed for the computer to operate. Run the computer without these cards to see if they are the cause of your issue.
Computer virus
It's possible for your computer to be infected with a virus that is designed to shut down your computer or turn it off. If your computer seems to be turning off when executing a certain program at specific times in the day, it could be infected.
If you believe your computer may be infected with a virus or are uncertain if your computer is infected with a virus, make sure your virus scanner definitions are up to date.
If after following each of the above recommendations your computer still continues to reboot, it is likely that you are experiencing a Microsoft Windows operating system related issue that cannot be explained. To help make sure this is the case, please try the below steps.
Reboot the computer and enter CMOS setup as the computer is booting.
After you have loaded the computer in CMOS setup, let the computer sit.
If the computer does not turn off while letting the computer sit in CMOS, it is likely that you are in fact experiencing an issue with Microsoft Windows or your operating system and it is recommend that if you have followed all of the above recommendations that you reinstall your version of Microsoft Windows.
If after reinstalling your operating system, or during the installation of your operating system, your computer turns off abnormally, it is very likely that other hardware is failing in the computer. Often this is RAM, CPU, Motherboard, and/or Power Supply (in that order).
If you have extra available parts or have a friend or co-worker with a similar configuration that is willing to allow you to test their hardware in your computer, try swapping these parts to determine if they are at fault. Otherwise, you will need to have the computer serviced.
Try to get into your computer after start and before windows load hitting the key F8 and selecting SAFE MODE and see what happen there. Check for virus and spyware.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Posted on Oct 14, 2008
    Problem Solver:
  • 4 Answers
After making sure your computer is cleared of all the viruses then read the following.
I had a the same problem and i changed the ram,then i replaced the Processor and then i had to buy another mobo and all that did not solve.Than finally i went for the PSU a very cheap item of hardware.Eureka!!!!!!!!! It did the job.
good luck i hope it works for you.
taburi
Posted on Mar 15, 2009
My acer 5750 i7 keeps shutting down
The infected laptops encounter random shutdown problem until some maintenance activity is being performed on the system.
Two important things that you should do to fix a laptop which keeps shutting down are:
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes.
For an instant fix use system utility tool Reginout.
WebRepOverall ratingThis site has no rating(not enough votes)
Dec 12, 2012 | Acer Computers & Internet
Windows keeps shutting down unexpectedly
Your computer is overheating, it is shutting itself down to prevent damage to the internal components.
Your computer should be serviced by a computer technician. He/she will clean the components and chassis of dust. This will increase airflow over the components, meaning your system will be stable and will not shut down unexpectedly.
Take care!
damnor01
Apr 28, 2012 | Microsoft Computers & Internet
Computer keeps shutting down and states "computer
Did u put the FAN to the right CPU FAN board connection? or Align ur heatsink to the processor, procie might have been overheating 'cause the heat sink didn't touch the procie!
Nov 09, 2010 | Intel Motherboard
Computer keeps shutting down change operating
replace all leads including IDE and SATA and electrical before replacing a new PSU
Jul 25, 2010 | Foxconn 661FX7MI-RS (661FX7MIS)...
My computer keeps shutting down (the internet) It
If you are using windows operating system then try to restore operating system to back date by dowing below steps.
1 Go to "Start"
2. All programmes
3. Accessories
4. System Tools
5. System Restore
6.Restore my computer to earlier time >Next
7 Select a restore poing > Next
8. After completion of restore it will rebooted.
Thanx
Jul 15, 2010 | Dell Inspiron 530s Desktop Computer...
My sansa willo not charge. It keeps shutting down
try checking every five minutes and turn it on.
Sep 29, 2009 | SanDisk Sansa e250 MP3 Player
Keeps shutting down 5150inspiron
thermal shutdown.... it's overheating and you need to make sure the fan is working and clean out the dust and dirt
Robert
Jan 19, 2009 | Dell Inspiron 5150 Notebook
Computers & Internet Logo
767 people viewed this question
David Payne
David Payne
