Question about Frigidaire FRS26R4C Side by Side Refrigerator
Water Leaking Water is leaking from the bottom left side of the fridge?
  • 943 Answers
HI thanks for your question. the drain tube in the freezer is clogged, not allowing the defrost water to go down to the drain tray. to repair. turn fridge off , for 24 hrs. remove back panel from fridge clean all coils. locate the drain tube by the drain tray. use a small hose to shove up the drain tube And blow , to clear the debris from the drain tube. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 14, 2008
Water leaks at bottom of fridge
The same thing happened to me then I noticed ice had formed at the bottom of our fridge. It was covering a drain hole so water was leaking out the front of fridge instead of going to the drain pan or wherever the hole goes. After I chipped out the ice and cleared the hole with warm water the leak stopped. I also fixed another leak coming from bottom of fridge caused by a loose brass connection on water line going to the door.
May 25, 2014 | Hotpoint HSS25GFP Side by Side...
Leaking and fan stops then starts?
Don't know if this will help but our fridge was leaking and then I noticed there was ice at the bottom and it was clogging a drain hole so the water ran out on the floor in front of the fridge. I chipped out the ice, melted the drain hole and slightly raised the fridge temp so the ice would not re-form on the bottom and it worked. - no idea about the fan.
Jan 17, 2014 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerator leaking bad at bottom after manual defrost still leaking
Ah the bottom. The drain pan is overfull and can not Handel the amount of water going into it. Normal running operation will evaporate any water left in the pan. You can pull out the fridge and drain the pan or clean up the water until it stops. Good luck
Sep 09, 2012 | Amana 22.6 cu. ft. Side-By-Side...
Ge side by s
found norcold #160107210--new #160107200-----on E-Bay ,under RV Thermostate-----thru seller---- eastcoastrv---Lexington,South Carolina
Oct 26, 2009 | GE Refrigerators
Water leaking from left side of frezzer out the
There is a restriction in the condensate drain. You should be able to press a piece of tubing against the drain opening (inside fridge) and BLOW (NOT ****) through the other end. this should clear the obstruction. The obstruction would be slimy goop, sooo again -
NO ****!
Sep 15, 2009 | Jenn-Air Refrigerators
Leaking water on bottom left side ...water to ice maker is shut off in basement...still leaking
check the water drain is not plugged...you may need to take the inside back panel off if you have water on the floor see if the drain hose is in the tray under the fridge
Aug 07, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Water is leaking on the inside bottom draw of the
Clean the drain tube and drain pan under fridge.It may be clogged.
Hope this helps.
Aug 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
My frig is leaking water & bottom tray is full
you need to change the filter on the bottom of the refrigerator, take off the outside cover on bottom of fridge and on the left hand side right above the tray that keeps filling up there is a round filter that unscrews. unscrew it and replace the filter. You can get the filters at Lowes or Home Depot for about 20 bucks, hope this helps.
Jul 12, 2009 | Refrigerators
Water leaking from bottom of refriderator
dear ricurtsmith..
your fridge has a water trap pan underneath it to catch the water from the drain line when your fridge automatic defrost.
either the pan is not in place proper or the pan may not be underneath, period. or pan could be stopped up/need cleaning. or if pan is made of plastic, it could be cracked.
it is located at the bottom of fridge where you see something loos like a grilled vent. remove that bottom piece to get to the drain pan.(it just slides out!!) good luck & hope i was helpful.
brbharo....
Dec 05, 2007 | Kenmore 52642 / 52644 / 52649 Side by Side...
Frigidaire FRS26R4C Side by Side Refrigerator Logo
340 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
