Question about Zanussi FJS1225W Front Load Washer
E 20 showing on machine
I have a zannuzi jet stream but i keep getting E 20 showing ,what does it mean please?
  • pauline jankowski Oct 15, 2008
    what is that supposed to mean? explain in english
It means u should trow the **** thing from a clip. e20 goes on my nervs
Posted on Oct 14, 2008
Water is coming through the tray but there is a buzzing sound & there is not much water. Could there be a blockage with the jet stream feed into the drum of our Zanussi Jet stream 1400 ?
more than likely, the buzzing sound is probably the circ pump struggling. this is very common. first check filter is clear. if it is there is a hose from the circ pump to the top of the tub or to the door seal, make sure that isn't blocked. don't worry ab there not being much water in the machine, these machines don't use much.
Sep 01, 2016 | Zanussi Washing Machines
I have a Zanussi W/M ZWF1640 showing E34 fault codes in diagnostics mone. any clues?
Three things i would suggest on the zannuzi. Does water come into the drum at the beginning of the wash? Does the drum turn if asked to wash or spin? Does the drain motor disperse the water in the drum when supposed to. If motor does not turn, check the brushes. Sorry for being so vague, Zannuzi not common in S.Africa, but those are the common problems i have found while repairing the odd one.
Aug 03, 2010 | Washing Machines
When machine is filling it makes a really loud noise but when washing it's fine. The repair man said it was to do with the jet stream and said it would cost 60 pounds to fix. A day later the noise stopped...
hello,
the problem is from the power jet this mean that the stream need to be replace because it ha become weak from it position you can grt the part from any technician store or shop around you .
Good lock and thanks for using fixya.
Jun 10, 2010 | Washing Machines
Zanussi Jet Stream 1600 is displaying E10 as it has started its cycle to wash. Can you tell me what this means please?
I found that the water pipes were frozen! so I have 'gently' defrosted them and we are now working...
Thanks
Jan 10, 2010 | Zanussi IZ161S Front Load Washer
What does Jet navigator mean?
I believe it is a way of finding recordings the machine has made. Say you have recorded 5 TV shows on a tape. By pressing the search button or the onscreen message box, it will go and find each recording start and it plays it back at high speed (hence jet) for around 20 seconds then jumps to the next one and so on... This is so you can work out if you want to watch the various recordings.
Apr 08, 2009 | Panasonic Televison & Video
Problem
Check the drain hose, and inspect the filter for any foreign object.
I report :"E20 means your fluff filter / waste pipe is getting blocked and the machine cannot pump out the water. Try unblocking the fluff filter first at the bottom of the machine. This should work, if the fault appears again though and the fluff filter is clean your waste pipe is blocked and you need to flush this through. Can you tell what I've just spent my weekend doing, I have had to get the most unbelievable amount of limescale out of these 2 areas but machine is now working fine again."
From how to mend it
See also E20 Zanussi Washer Dryer WJD1667
Oct 15, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
119 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Chris Hall
Chris Hall
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
