Question about i-mate K-jam Smartphone
Device goes into "self-generating loop"
Tough one to describe to you. At times, the unit goes into what I call a "self-generating loop".
The cursor flies around the screen causing it to scroll/shift all by itself, plus menus appear/disappear. It's like having a ghost operating the device at high speed with things moving all over the place. During this time you cannot interrupt what's happening with the stylus or a screen press as it is moving so fast. I have to reset or go ionto standby then power up again.
It can go into and out of the "loop" with no discernable pattern that I have been able to identify. I've tried hard resets but that makes little difference.
Install the software again after formating the phone
Posted on Oct 21, 2008
How to reset the ipod tough 4th generation
Try holding power button and home button down for 10 seconds. It should reset.
Sep 03, 2016 | Apple iPod nano 4th Generation
How to connect the loops
6 Ways to Understand Security Camera Systems - wikiHow
www.wikihow.com > ... > Disaster Preparedness > Home Security
wikiHowYou can self-install a professional security camera system. ... the systemGet poweredCamerasMonitor(s)High speed internet connection ... after the hard drive is filled with video, the DVR simply loops around and starts from the beginning.
Methods for Recording with Home Surveillance Equipment ...
www.ebay.com > ... > Home Surveillance > Digital Video Recorders, Cards
However, many inexpensive security cameras only come with a way to view the ...places on the tape, continuous loop tapes rarely work with time lapse VCRs. ... If the camera needs to be connected directly to a recording device, then the user ...
Video Ground Loop Interference for CCTV ' 2MCCTV Blog ...
Jan 10, 2016 | Home Security
Coleman powermate generator runs with no power
If we assume for the moment, that the internals of the generator are all ok. This problem is usually caused by not running the unit on load for a long time, a year for instance. During this time the residual magnetism in the field coils will slowly decay. When the unit is running the field coils control the power generated by the main windings. The higher the excitation voltage in the field coils, the higher the voltage generated by the main windings. The field coils are controlled by their magnets which, once a voltage has been generated, they will then self excite themselves.
However, if all of the magnetism has decayed then the field coils cannot generated because they have no excitation to start them off.
What you need to do is to find the field coil windings and while the unit is running with a load plugged in to it, you need to flash a voltage across the field coils.this will excite the field coils, part of that is used to do whats called self-excitation, honest...it is.
If you do this then a 12 volt car battery is a sensible thing to use for a power supply. But, as soon as the field coils start to self-excite then that voltage will increase far beyond 12 vo9lts. That is why you need a good size load connected, As the unit starts to generate then that load will alert you to remove the temporary supply, if you leave it connected the battery acid would rapidly boil and it can split the battery cases. That is why it's called 'flashing' it up. Once generating it wants leaving for a good hour,
If that does not produce results then the fault is deeper and requires testing by a qualified engineer.
Nov 11, 2013 | Coleman Electrical Supplies
How do I use the self timer of the Coolpix L22?
Press cursor-left (marked with a one-handed clock). Use cursor-up/down to select "ON". Press the shutter-release button halfway to focus and set the exposure, then press it the rest of the way down to start the self-timer.
BTW don't put any credence in the number of views. AFAIK FixYa uses a random number generator to generate that particular number.
Sep 18, 2012 | Nikon Coolpix L22 Digital Camera
How much oil goes into Troy built self propelled mower
Your engine should take about 20 oz of oil to fill from empty.
Oct 23, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Red light coming on ; tank is filling up. I drain
Fortunately, from what you have described, the unit is working as it should. But, the frequency that it's occurring is what I think you're concerned about.
If you are operating the Dehumidifier Mode along with the Cooling Mode, this will generate more water in the tank and require more frequent draining. Running the Dehumidifier and the AC (Cool) at the same time is not recommended. It reduces the cooling capacity of the AC Mode and generates heat in the room. And, as you already know, more water.
Hope this helps you and thanks for choosing FixYa.
Aug 03, 2011 | Haier CPRD12XC7 Air Conditioner
Welder will weld for about 30 minutes and then will not weld until the unit cools down. generator function is normal. the repair shop told me that the welding leads were bad so I replaced them and have the...
If you check the wire A4 which connects the bridge to the current selector switch, make sure the connections are clean and tight. The sense wire parallels it and dirty connections on A4 can make more current flow through the sense wire than normal.
It is also possible the current sensor may be faulty, or has a bad connection, or is even seeing transient spikes from brush noise. The sensor connects to terminals 3 and 4 of J2 the 4 terminal connector on PCB1. And looks like a plastic and metal donut The sense loop for welding is supposed to be a single loop through and the generator sense should be 3 loops through.
Sep 12, 2010 | Lincoln Ranger 250 Gxt Welder Generator...
Hi there i recently got a e machines computer off my friend who formated it. im having a lil problem reinstalling windows xp on it. i have the restore cd that come with it model t2682. it goes though the...
This is a tough one. sounds to me like you have a bad driver. if you press f8 repeatedly at the beginning of boot before windows starts up, windows should give you a choice to start in 'safemode'.
Safemode doesnt load any drivers from your manufacturer.
The tough part is finding the culprit.
I suggest removing all the drivers in safemode and then reboot, and install one driver at a time till you get the error again.
If you need to change drivers while in windows normal mode you can get to the device manager by right clicking my computer and selecting properties with a left click. this will open a section with tabs, one of the tabs will have the device manager button on it.
Jun 17, 2010 | Computers & Internet
I have a 1999 Onan Generator start/stall issue
Check your oil level. The unit will stay running as long as you have the switch depressed. When you get enough oil pressure a switch closes & keeps it running.
Aug 16, 2009 | Sport & Outdoor - Others
General Use
The self-tests are described in the manual
Testing Calculator Operation . . . . . . . . . . .. A-9
Self-Test . . . . . . . . . . . . . . . . . . . . . A-I0
Keyboard Test . . . . . . . . . . . . . . . . .. A-ll
Port RAM Test . . . . . . . . . . . . . . . . .. A-12
IR Loop-Back Test . . . . . . . . . . . . . . .. A-13
Serial Loop-Back Test . . . . . . . . . . . . . .. A-14
You can download the manual from hpcalc.org or the HP website.
I would personally include photos of the screen during the test (e.g. "KBD OK").
Nov 28, 2007 | HP 48gx Calculator
i-mate K-jam Smartphone Logo
Top i-mate Computers & Internet Experts
Bilal Ahmed Qureshi
castletech
castletech
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
