Question about Canon PIXMA MP830 All-In-One InkJet Printer
Canon MP 830 Error 6a00
I've tried everything listed in the maual and on the forums including turning it upside down as my last resort. Any other ideas, other than don't buy Canon home printers (I've already come to that conclusion after one warranty return in year 1 and this problem in year 2)?
Thanks,
Jim
  • 1 more comment
  • wtwar Oct 15, 2008
    Same Problem, 6A00 error code, nothing in manual as to meaning, and nothing I try helps.
    Bill
  • ascothill Oct 21, 2008
    When I go to print an other error comes up 5110
  • wtwar May 11, 2010
    Tried all that was recommended, removed and cleaned the ink tray, checked for objects. No luck Still get 6A00 error.
  • 76 Answers
Thats because 6a00 is a service error not a user error, It could be down to use of none canon inks glogging the ourge unit up after time, it could be due to paper or objects in the purge, i would take the covers and inspect the purge and make sure that it moves back and foward, who ever told you to turn it upside down is having a joke., that will never work. Some times it could be gearing on the back on the purge.
I would ask for a service engineering, depending where you live i have a few contacts. Mp830 is a very good product and you shouldnt have alot of problems.
Posted on Oct 20, 2008
I have a Cannon MP830 printer, that is displaying a 6A00 error on LCD, and the orange alarm light is flashing. Also the ON switch is not working, I have to unplug it to turn off the power. Checked under the hood, it appears that the purge thingy.. is not sliding at all. With the power turned off, I can easily push it from side to side. No paper jam or anything blocking that I can see. Any ideas on how to fix, or what is wrong. It was working fine this morning. This occured trying to send a fax. Hope you can help. cheers
Posted on Jun 10, 2009
My phone does not ring when fax is on
Posted on Feb 02, 2010
Canon MP 830 showing error code 6A00. alarm light flashing, no lights on ink cartridges.
6A00 is AP position error.First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 29, 2009 | Canon Office Equipment & Supplies
I have a error code 6A00 and alarm light flashing on my canon pixma mp 830
Canon lists the solutions for the error 6A00 as...
1.
Press ON/OFF switch to reset the multifunction device
2.
Press Stop/Reset and ON/OFF to reset the printer
3.
Removing paper jams
4.
The MP830 may require repair
5.
Unlock the scanner lock switch (MP830)
Oct 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP 830 flashes between the copy button and hazard light(triangle symbol with squiggle in it)12 x.then starts the same 12x after a short pause.It will not do anything..whats the problem?
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Sep 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My canon mp 830 all-in-one printer says 6A00,
no need to reset your printer, the things your should do is you just open the over at the back of your printer, then you can see a paper hang on, then please remove it, then try to print, if it does not work open also the tray which is your bond paper stored, just see if there is also a bond paper hang, then remove it, then print again, that the cause of paper jam
 Good Luck!!
 Nice
Jul 01, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 950 has a error code 6A00
There is a problem with the carriage lift mechanism.
Probale causes
1.PR Lift shaft assembly
2.Sheet Feed Unit
3.Logic Board
Only your local Canon Dealer will know
Mar 12, 2009 | Canon Pixma MP950 All-In-One InkJet...
On my MP 830 Canon Error on my computer 5C10 Error on printer screen 6A00 Print head moved top the far right and appears to be jammed Had removed and cleaned printhead, reinstalled printhead and inkwells...
Hi
This happens a lot
Solution 1:
Solution 2:
Solution 3:
Feb 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon mp 830 error code 6A00
hi!!!
try to re-install the driver
Nov 17, 2008 | Office Equipment & Supplies
6A00 error
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Sep 23, 2008 | Canon PIXMA MP830 All-In-One InkJet...
6A00 error
This error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
hope this helps...
Sep 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
2,538 people viewed this question
old marine
old marine
