Question about Whirlpool Refrigerators
I lost power for several days during Hurricane Ike. When the power came back on, I cleaned out the ice maker bucket and let it make new ice. It makes ice and the light comes on when you press the dispenser lever, but it makes no sound and no ice comes out. Then 2 days ago I had to change the Pur water filter on the refrigerator. When I ran some water into a cup, I noticed the water was coming out much faster than usual. When I filled the cup and pulled it away, the water kept running all over the floor. I pulled on the lever a bunch of times and the water finally stopped. But now, when you press the lever, no water comes out, until you release it. When you release it, a few tablespoons of water escape.
  • 120 Answers
When you repl the filter it has to be purged to bleed all the air out just keep askig for wtr until you purge all the ait out dispence at least 15 large glases of wtr
Posted on Oct 15, 2008
E11 thermador
Thermador built in Fridge-freezer (T36IB..) experienced a 3 day power outage in area thanks to Hurricane Irma. During that time it was cleaned out and freezer was dumped and when power came back on it was working, and in a few minutes it started it's beeping noise and error code E 11. Freezer and refrigerator are both working, I have tried turning it on and off at the button and then once at the breaker. I have tried holding down the alarm button 3-5 seconds; I have a hunch it may be the freezer/ice maker trying to "start up". Any ideas what to try next?
Dec 19, 2013 | Thermador Freedom® T18IF70NSP
No power
sounds like a carb problem, you should have them cleaned and re-built
Apr 11, 2009 | Light Outboard Motor Boat Bass Fishing...
Ice maker does not consistently make ice...
try turning off ice maker for a day. remove the bucket that holds the ice. look all around bucket and into ice maker to determin if there is a jam, or if there is a cube stuck there preventing operation. Check that the ice arm can move freely and it is properly inserted on both ends. Make sure there is nothing in your freezer that could be getting in the way of the ice maker operation, either above or below the unit. One hint-wear disposable gloves when working with the ice maker-if you have any moisture on your hands, you tend to stick to the unit.
Jan 17, 2009 | KitchenAid KSCS25FKSS Side by Side...
Water/freezing to ice at the bottom of the freezer MZD2766ge
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all that ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youll melt everything) or by pouring hot water down the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 17, 2008 | Maytag MZD2766GES Side by Side...
Freezer section not cold enough/fridge ok
sounds as if you might have a compressor related sealed system problem, youll have 5 year war on such an issue from the manufacture
Oct 29, 2008 | Maytag MSD2758GEW
Odor coming fromback panel
you can also use bleach let it sit there for a couple of days so it will kill bacteria and odor the smell is all the meat and blood that drain down to the pan
Oct 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
JCD 2389 GES Not cooling
Yes. I would suggest the control board is possibly damaged.
Model jcd2389ges JENN AIR SIDE BY SIDE REFRIGERATOR Parts
This is not the only place to look, but it is where I would start.
Dec 19, 2017 | Jenn-Air JCD2290HES Side by Side...
Freezer not freezing
Check to see if the fan motor in the freezer is running. Most likely it is not circulating the cold air Also make sure the defrost drain line is clear and has drained out. A frozen sheet of ice will restrict airflow also
barneyluc.
Sep 28, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Sep 19, 2008 | LG LSC26905TT Side by Side Refrigerator
Ice maker trobleshooting
We lost power due to hurricane Ike and now that the power is back on the ice maker is not working. Is there a reset button or what needs to be done to get it working again?
Aug 10, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
108 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
