Question about Casio G-Shock G7100D-1V Wrist Watch
Time adjustement on G-Shock watch GS 1001
How do you adjust time 1 hour forward?
Thank you,
Emil Sremchevich
emil-sremchevich@micos.com.au
  • Anonymous Mar 09, 2009
    cant set the main time with red and silver hand
5 Suggested Answers
  • 73 Answers
SOURCE: Setting time on Watch
go to this website follow the instructions for finding your particular watch module located on the back of your watch and enter it in the space provided. This will lead you to a place where you can download your manual and learn how to set your particular watch. here is the link to follow and please leave feed back if it was helpful. http://world.casio.com/wat/download/en/manual/
Posted on Feb 04, 2008
SOURCE: Setting Time
Awesome! should have read further before posting!
Posted on Oct 14, 2008
foxpup
  • 6 Answers
SOURCE: G-shock Wavecepter is 1 hour to fast
(I posted this solution elsewhere but it should help you as well.)
Firstly, the manual that comes with these watches is absolute garbage,which is a stark contrast from the watches themselves. ( I love casiowatches - high value)
The good news is that Casio DID make a good manual for these wavecptor watches. If you go to this url
you will be at a spot where you can type in your 4 digit module numberand get a great document that tells you how to operate your unit andsome of how it works. (Adobe Acrobat - PDF file)
You should be able to hold in the "Adjust" button until the time zone starts flashing and push "Time Memo" and/or "Recieve" buttons until you are in the right time zone. Push "Adjust" again and your are done. The Manual above was very useful for me.
Hope that helps. :-)
Posted on Dec 26, 2008
escapement
  • 2334 Answers
SOURCE: adjusting the world time??
If your watch is Casio:
If not, give ALL the details.
Rate, please.
Posted on Mar 30, 2009
  • 2501 Answers
SOURCE: adjust the time in a casio g-shock shock resist watch
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
Posted on Mar 08, 2010
How to set time on timex 1440 sports watch
Welcome to FixYa!
Here's your request.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Thank you for using FixYa! Have a great day.
Jas247
May 06, 2011 | Timex Watches
Cannot set time @ date for Ohsen watch...AD0721...thanks
(A=LIGHT,B=MODE,C=START,D=RESET)
1.How to use the luminescence Any time indication,Press A the Luminescence will last for 3 seconds.
2.How to view date? Standar time indication, press C "month/ date" indication.
3.How to switch 12/24 hour systems In the normal mode, press B twice and press D twice ,then hold C until 24 hour system is actuated, then press B for recovering.
4.How to check alarm ring and alarm time? Standard time indication,press D alarm time indication.
5.How to set alarm time? Standard time indication,Press B twice. The hour area flickers,press C to set the hour. After setting hour ,press D,the minute area flickers, press C to set the minute. Last press B for recovering.
6.How to set alarm ring? In standard time indication mode ,Hold D then Press C this will toggle alarm symbol on & Off.
7.How to set Hourly Chime? In standard time indicationmode, Hold D then Press B DAY OF WEEK area toggle on and off.
8.How to use stopwatch(1/100 seconds) Press B,then Oress C for 1 timing; Press D for multiple timings. Press D once more to continue operation after multiple timing. Press D for 1 timing; press C once and press Dtwice for multiple timing. (1)Max range of the stopwatch is 23 hours 59 minutes 59 seconds. (2)When timing within 30 minutes, the watch indicates: minute/second/1/100 second (3)When timing beyond 30 minutes, the watch indicates:hour/minute/second
9.How to adjust time, date,day of week (1)Standard time indication,press B twice ,the second area flickers, pressC to adjust second. (2)Then press D the Minute area flickers,Press C to adjust minute. (3)Press D the hour flickers, press C to adjust hour. (4)Press D the Date flickers, press C to adjust date. (5)Press D the month area flickers, press C for adjustment. (6)Press D the Day of Week area flickers, press C for adjustment. Then press B for recovering.
Nov 30, 2010 | Watches
I need to change the date on my Cartier Roadster (back 2 days). How do I do that?
Thank you for contacting FixYa.
  • Pull the crown of the analog/date Cartier watch and rotate it clockwise or counterclockwise until you see the date advance in the display window at about 1 a.m.
  • 2 Use the quick date set method by rotating the crown counterclockwise after reaching 1 a.m. until the hands reach 7:30 p.m. Then again rotate the crown clockwise back to 1 a.m. Repeat the procedure until the correct date is displayed.
  • 3 Adjust the date forward or backward 12 hours if your Cartier watch changes the date at the noon hour.
  • Best regards. Jewel
  • Sep 13, 2010 | Cartier Roadster W62016V3 Wrist Watch
    Changing from 24 hr system to 12 hr system
    • Press "MODE" (lower left hand button) three times to get to the screen where the numbers are blinking, indicating that you can adjust the time
    • Make note of the hour if you don't have another clock handy
    • Press "LAP/RST" (lower right hand button) once to get the hour numbers to blink, indicating that you can change them
    • Press "ST/STP" (upper right hand button) to move the hour forward until you go past 24
    • At this point, you will notice a little "A" next to the time to indicate AM, and if you keep going past 12 hours, it will cycle back to 1, this time with a "P" next to it to indicate PM
    Apr 18, 2009 | Lucien Piccard 26024 Wrist Watch
    Need to fix time on Casio G-Shock
    The hands are set independent from the digital display
    Setting CASIO G-Shock Watch
    1) Home City
    2) Setting the digital time
    3) Adjusting hands
    4) Alarm set/on/off
    5) Snooze
    6) Hourly Chime
    A -- B
    ( ) Button reference
    C __ D
    1) Select home city first (if equiped):
    Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
    Press C until timekeeping mode is reached (high beep).
    2) Set time, Date, etc:
    Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
    3) Adjust hands (if equiped):
    Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands before correct analog time is reached. Press D to step to current time (hands only go forward). Press A to exit H-Set mode. Press C to return to timekeeping mode.
    In Timekeeping mode B is illumination and D is time/day/date display advance.
    4) Alarm set/on/off
    Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
    To stop any alarm, press any button.
    5) Snooze (SNZ):
    Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
    To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
    6) Hourly Chime (SIG):
    Press D to select hourly chime (SIG). Press A to toggle chime on and off.
    Good luck,
    Techjoel
    Apr 18, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
    Adjusting the world time??
    Rate, please.
    Mar 30, 2009 | Casio G-Shock 800D 7V watch
    Dec 05, 2008 | Casio G-Shock GW500A-1V Wrist Watch
    My G-shock wavecepter is 1 hour fast. I can't seem to get it to set to the proper time. I live in Oregon on in the Pacific Time zone. My watch is set to LAX. DLS is off and when I tried it on it jump to 2...
    This url (below) has a REAL manual for your watch, not the worthless one that comes with the unit.
    You can type in your 4 digit module number and get a great document that tells you how to operate your unit and some of how it works. (Adobe Acrobat - PDF file)
    The solution involves holding down the adjust button until the time zone starts flashing, adjusting with the right 2 buttons and pushing the mode button to get to other options. You then finish by pushing the adjust button again.
    Casio G-Shock G7100D-1V Wrist Watch Logo
    496 people viewed this question
    Top Casio Watches Experts
    Jimmy Accardi
    k24674
    Are you a Casio Watch Expert? Answer questions, earn points and help others
