Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Service Manual? >Looking for a copy of the service manual for Philips HDTV 37PF7320A. TV currently will not power on. Green light quickly turns to red flashing = 1 long, two short. Any thoughts on the problem? Fuses? Thanks for your help.
  • 488 Answers
Hi!you can get the manual at http://www.retrevo.com/support/Philips-37PF7320A-TVs-manual/id/278ci358/t/2/
you may  have to make a fast and free registration..
hope u get ur TV working fast!
regards!hope i could help you..
Posted on Nov 05, 2008
Philips 42" Model # is 42PF7320A TV Yr. 2005
Most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light flashing codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
TV won't power on, repeating doulbe red light blink
Question Television is not working, screen is black, blinking red led.
Answer Television is probably malfunctioning due to electrostatic discharge. Try resetting the television by unplugging it from the power outlet for 10 seconds.
  1. Make sure that the power cable on the display and the VGA cable with trailing audio cables are connected correctly (use the originally supplied VGA cable.) between 'MONITOR' of the TV and 'VGA1' of the display.
  2. Make sure that the display is switched on.
Jan 24, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking Red Lights
Sound like an error code 14 (Audio supply) is beeing blinked...
You probably would want a qualified technician to take a look at it.
Jan 16, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A Service Manual
service manuals cost around 14.00 online -- you can download a free owners manual from philips.... the flashing lights are a protection code
one flash / pause / two flashes
this means that there is a problem with the software -- this television was probably made in 2006 and in 2007 - they had to supply customers with an upgrade to the software -- you can download it for free on philips/software/support.com
look in the section - drivers/software---- put it on a thumb drive and install into the USB port on the right side of the television--- the television will come on and scan for the software----
Oct 11, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blinking red lights
Call the manufacture of the TV set to find out who their authorized service is in your area.
These sets are expensive to service. They are serviced by mainly board replacement. There is very little support for component level service.
The boards use high density SMD technology, and is all uPC controled using firmware.
As for your fault, you would have to determine if the power supply is in the protect mode because of a defect on another board, or if the fault is the power supply only. This is usualy done by doing board swapping to find out which boards are defective.
Some of the manufactures will sell the service manuals for their flat panel sets. Not all the schematics will always be complete. The information is mainly for how to replace the boards, and do the factory level calibrations if necessary. You will need the proper calibration and diagnostic tools to do the tests and adjustments as indicated by the service manual.
Jerry G.
May 16, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Red flashing light
This is actually a common fault/problem with this model. The first thing you need to do is press 062596 and then the info/menu button. This should display an error code which you can look up in your manual or online. I beleive it is a fuse problem and if so needs to be taken to a technician to fix/change the fuse(s).
Jan 08, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37pf9631d/37
The TV is in some kind of protection mode, the blinking LED show you an error code.
Try pressing 062596 and then press menu button (do these in quick motion, don't let them to time out while keying)...see what happens
Well I think that if you would have a service manual for this set that would help a lot, I can send it to anyone who wants it via email/gmail. Let me know if anyone want one.
I also heard that this problem appeared with some people because the of the burnt fuse in the TV. To fix that it has to be taken to the tech shop. mecry.gif
And yes I also heard about this issue many times, seems like this TV set is very popular with this kind of problem.
Dec 05, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Red light flashing
Nov 27, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
296 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
