When i plug in my charger to my laptop it doesnt work and i dont know whats wrong with it
  • A Womans Computer Man
    A Womans Computer Man May 11, 2010
    the charger does not work or the computer?
    Genius:
  • 1,124 Answers
This issue can be caused by any of the below possibilities. 1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Posted on Oct 14, 2008
Dont work, is dead
Wrong font? Did you put the wrong voltage charger in the machine? You may have blown a component inside if so
Feb 28, 2014 | Dell Computers & Internet
Dell latitude D420 wont charge when plugged in
If the laptop works without the battery, just the charger, the charger is OK.
Jan 13, 2014 | Dell Latitude D420 (DELLD420) PC Notebook
Toshiba Satellite A45-S120 laptop battery does not charge
Sounds like you need a new battery. Try removing the battery and running the machine on mains power. If that works, you know the charger is ok. Its usual for batteries to deteriorate over a few years, so my money would go on a new one.
Mar 23, 2012 | Toshiba Satellite A45-S120 Notebook
Gateway laptop died. Several times it appeared to reboot only to go black and go off. No fan or lights. How can I fix this myself?
does it show that it is charging from the charging light/power supply? Is there any life left in the battery? is the charger charging the battery? the batteries dont last in laptops usually about a year before the go bad and have to be replaced, Is the charger working? The chargers go faulty all the time, The little plug that plugs into the laptop goes faulty and is a very common fault and doesnt charge/power the laptop, The only thing you can try is another power supply of the same name/model/output voltage and current with the same small plug and polarity or another battery of the same type/model, If you can do this and it doesnt cure your fault it needs looked at by a technician, Hope this helps, If you need more assistance let me know,
Sep 19, 2011 | Gateway Computers & Internet
Optio a10 charger
if you don't see a light on the charger lite up its the charger, or the internal batteries are no longer excepting the charger. my first guess is the charger itself.
Sep 25, 2008 | Cameras
I CANNOT OPEN!!!
Hi, Try running you laptop with the battery and the AC adapter. If by plugging in your adapter there is no light indicator likewise or no powering up, then presumably there is a problem with the power supply circuitry in the motherboard. Normally the laptop should work with just the adapter, just the battery or both the battery and the adapter. If it will not perhaps your best bet is to seek professional repair service since this would require opening the motherboard. In most instances, this involves an smc fusible link, regulator transistors or even just cold solder or loose connections. Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Sep 24, 2007 | Acer Aspire 5500 5570-2609 Laptop
Computers & Internet Logo
129 people viewed this question
David Payne
David Payne
