Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Philips Magnoavox 8p6054 c101 60in rear projection
The tv is having a gren haze on the hole screen
Change the coolant on the pic tubes, its simple, Remove the 4 screws holding the lense down, use a vacuum and rubbing alchohol to clean, , tilt tv to level individual tubes, refill then reassemble.you can fix one for about 20 $
Have a problem email me" natsp2000 at Yahoo dot Com " no caps, use . instead of "dot", @ instead of "at"
Posted on Dec 07, 2008
I have a phillips rear projection tv model no 55PP8620/79. Its showing a a red haze and poor picture quality. How do I fix this?
If the red haze is not convergence---that requires parts.
The set has three picture tubes---with set unplugged and back cover removed clean the three large lens that are topside---as for the red haze a quick way to know what is wrong is with set on turn the color to zero----what color is the screen? Should be black and white--if red to some degree tracking or screen controls may need adjusting inside the set---Yellow picture in that situation is a different issue.
Jun 05, 2012 | Philips Televison & Video
Screen is red
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from sites such as www.TvRepairKits.com
Jan 16, 2012 | Philips 55PW9363 55" Rear Projection...
Phillips big screen tv is red and gren colors and a double picture when cut on....how do you fix it
Replace the two convergence ICs and the 6.8 ohm resistors. The DPTV305 - DPTV345 convergence repair kit from www.tvrepairworld.com works for your model and contains the cd with instructions
Oct 28, 2010 | Philips 55PW9363 55" Rear Projection...
White haze and very unclear picture. Seems the
Search for "coolant change projection tv", there are several good links including where to buy the coolant. I did mine yesterday and it's like having a new TV again, all for about $20 and 3 hours time.
Nov 11, 2009 | Philips 43PP9202 43" Rear Projection...
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips/Magnavox - Model 9P6444C105 - "Yellow-ish Haze" on Screen
You can get the entire coolant replacement kit at the following link. which contains 48 ounces of coolant and an instructional CD that explains the process step by step with pictures. Its listed under their repair kit catagory.
Here is the link.
http://servicemanuals.vstore.ca/
Jul 28, 2008 | Philips 64PP9901 64 in. Rear Projection...
Problems with my Phillips Rear Projection TV!!
have the coolant (glycol) in the CRT's....not as expensive as buying a new set...and sounds like it should be good as new if thats the only problem you have with it.
Jul 16, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
208 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
