Question about NEC LT 260K Multimedia Projector
NO VIDEO SIGNAL
THE LOGO IS SEEN BUT THERE IS NO ANY VIDEO SIGNAL
THE DISPLAY SAYS NO SIGNAL WHY
No vga input but output is ok.y is probloms
Posted on Apr 13, 2010
  • 94 Answers
There is no input yet meaning, it is not yet properly connected to your computer. Check the cable connection. Please make sure that the computer or laptop is already turned on.
Posted on Oct 14, 2008
I have the VE278Q which is connected by display port, every time i turn off my computer and then turn it back on the monitor can't be found, I have to unplug the display port cable, unplug the monitor,...
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
Jan 30, 2011 | ASUS LCD Monitor
My monitor is saying that it isn't getting a signal
A no signal logo is indication that monitor is functioning only requires connectivity to systemboard computer. Displayy terminal computers hosted by a mainframe computer system would display no signal logo when powered on in the absence of the powered on server computer terminal. Verify that the computer connections to the server frame is firmly attacked not loose. Also,, consult with a network specialist in instances of shared terminals.
Dec 22, 2010 | eMachines Computers & Internet
Our DS2 DVR gives the same display on camera 1 and 2 and sometimes it keeps on switching from 1 camera to another. Upon restarting the machine it will become ok but after a day or two, the same problem...
I've seen this before and it was caused by a faulty video card. It was sent to Dedicated Micros for repair and worked fine after it was returned. Sorry there is no permanent solution without major repair that I know of.
Jan 09, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
How to set up a UK Wii for use in the US
This is because UK wii's use a PAL signal for video display. If your TV does not support the signal, it's always going to be black and white. You might need to try a different TV.
Aug 11, 2009 | Nintendo Wii Console
Princeton Digital VL1716 Monitor "No Signal Message"
Roxio Changed Your display settings on the dual display.
Right Click on desktop>goto Prefences>
You should see both monitors indentfy the one and change it to a lower resolution.
Apr 28, 2009 | Princeton Digital VL1716 17" LCD Monitor
Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Dec 26, 2008 | Panasonic PV-GS39 Mini DV Digital...
No Display
hi i am enver parson can you tell me wot tipe of graphics card are you using
Dec 07, 2008 | ASUS K8V-MX Motherboard
Acer LCD Monitor only displays "acer" logo
You are correct, it could be a power surge that has caused it.
Try this..
Unplug the monitor from the wall.
Remove all the video connections at the monitor end.
Wait 10 minutes then plug the monitor back into the wall (do not connect the video leads)
Turn it on and see if it goes past the ACER logo now. If so, replace the video cables and try the computer.
If not, then one of these will apply and a tech will be required..
  1. The internal bios has been corrupted.
  2. The power supply inside the monitor may have issues preventing the video board from starting correctly. This could be as simple as a few failing capacitors.
Number 2 is the most likely cause with an Acer monitor though. Any local tech will be able to correct it fairly cheaply, but phone around for quotes..they can vary a lot.
Jun 03, 2008 | Acer X193W LCD Monitor
Fan, HDD... everything is working but no display.
You have no display, and cant even get to the bios screen.
OK, does anything at all show on the monitor when starting?
Logo,etc?
If that is the case, look to your video card or monitor.
I cant tell you how many times I have seen pins that are bent or proken on the VGA cable. or even plugged in.
Please check these things and let me know what you find
Nov 18, 2007 | Intel Desktop Board D845WN Motherboard
NEC LT 260K Multimedia Projector Logo
224 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
