Question about Kitchen Ranges
My matsui ceramic hob has just been connected but when using it the element on the ring will come on heat up then go off and it keeps doing that throughout cooking is this normal or do i have a fault
  • guiness1 Oct 19, 2008
    ok thanks
  • mingbop May 19, 2009
    new Matsui touch control hob, the letter H keeps flashing constantly and won't go away !
    President:
  • 1,462 Answers
That is normal
Posted on Oct 15, 2008
I have an EKI 807.2 Glass hob. I can't turn the heat up on more than one ring without E flashing on all the Rings followed by 6
Are you sure it is properly wired? For 1 phase 230v:
1= power earth
2-3 intersected = N
4-5-6 are L1-L2-L3 that should be conected together to L
Kuppersbusch is not very cooperative about what their error codes indicate, but E6 seems to be a (low) voltage issue, so you might too check the cabling to the outlet, measure the voltage with a multimeter when you successively switch on elements
Dec 22, 2015 | Kuppersbusch Glass ceramic induction hob...
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
Mar 11, 2014 | GE Cooktops
I have a cata ceramic hob. the child lock has been engaged & is restricting operation of any of the 4 hob's
When you turn on the hobs main power, press the the rear left hand element pad at the same time and the lock will come off.
press the centre minus button and the bottom right plus button at the same time it will work if not keep trying
You have to hold down the centre sensor button with the minus on and the sensor which turns on the bottom right ring immediatley after turning the hob on. It should unlock, then press the minus again
the hob switchs off
when you now switch on there will be no lock
Feb 04, 2011 | Microwave Ovens
PRODUCT DETAILS For MSP60SS
Matsui MSP60 Stainless steel Built-In Oven and Gas Hob Package. Matsui MSP60 with Hob: 4 Burner Gas Hob, Fan oven, Minute Minderand B Energy rated top oven. Matsui MSP60 Stainless steel Built-In Oven and Gas Hob.
Product Features
•Dimensions (cm): (H)59.0 x (W)59.5 x (D)57.0
•Ovens: Fan oven
•Timer: Minute Minder
•Hob: 4 Burner Gas Hob
•Colour: Stainless steel
•Energy rated top oven: B
Hope this helps. Your generous rating will be much appreciated.
Oct 20, 2010 | Ovens
The top of my halogen hob has cracked from top to bottom thro the centre is there any way of repairing it? it is a 5 ring creda rangemaster
you cant repair the glass but you can get the ceramic glass as a spare part. you will need the exact model number to get the correct part once done your hob looks brand new. if cracked through one of the zones you could chack there is no damage to element or themal cutout running across the centre of the element before proceeding.
Aug 22, 2010 | Cooktops
CERAMIC HOB EC 60 T. LETTER L NEXT TO CONTROL BUTTONS
Hi i had the same problem the L means Locked after lots of combinations of button pressing it is the - button in the middle and the 4th RING front right togeather that will unlock it took a couple of goes so persevere
Apr 15, 2009 | Kitchen Ranges
Zanussi ZKC5540W ceramic hob keeps turning itself down
More likely to be a faulty regulator switch, if the element was faulty, it is unlikely it would work at all.
Plz rate my solution. Thanks.
Dec 23, 2008 | Indesit W 123 Front Load Washer
Hob turns off
hi im gerbee my suggestion is replace the pcv control wat brand u have,always also in philipines the electric hob is so very sensitive,the pcv cotrol is not repairable.or next time u by a new one gas cooktop more ok compare to electric ceramic hob, or use electric ceramic hob w/knob control compare to sensor type,i think the part of the sensor or pcv control is so very expensive,that why i buy an another one.dont try to repair more difficult to com.tnx
Nov 24, 2008 | AEG 23 in. 6410KF-N Electric Cooktop
Kitchen Ranges Logo
286 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
