Question about Refrigerators
HOW CAN I MAKE A DEEP FREEZER GO FROM -10DEGREES C TO -30 DEGREES C ?
    Genius:
  • 1,122 Answers
Change the thermostat,get it fom any local appliance parts store,let me now how it turns out-mike
Posted on Oct 14, 2008
What termperature should the refrigeration and freezer be at when running right? In degreees, please
Fridge 4 - 8 degrees C, 5 degrees preferred, though some say 1 - 5 degrees.
Freezer minus 18 to minus 30 degrees C with minus 25 being preferred.
Sep 10, 2017 | Refrigerators
Why doesn't freezer get cold enough
If the thermostat is turned up and the freezer still remains at around 10 degrees I would suggest the system coolant has leaked or the compressor is faulty. Check that the door seals are not obstructed or broken, that will stop the freezer getting colder.
Sep 01, 2014 | Bosch Freezers
What is thesharpening angle for mac cat 330-839 chain
25 - 30 degrees looking down on top of the chain.
Drop the handle end of the file no greater than 10degrees.
If the chain has been sharpened more than 3 times please check the "height" of the "raker" in front of the chain tooth on the chain.
As a general rule these rakers have to be lowered to allow the cutting edge of the tooth to "bite" deeper.
Aug 29, 2014 | Garden
Refrigerator FGHX2644KF2, THE FREEZER IS NOT COOLING OFF. I HAD A SMALL CHILD TURN OFF THE FREEZER AT THE CONTROLS, BUT DID NOT CATCH IT FOR ABOUT AN 30 MINUTES, when I turned it back on the temp said...
is it staying at 16?? a freezer thats attached to a refrigerator would be considered fully functional about id say 30 degrees and below, As long as it stays under 32 I wouldnt worry about it, you can always try unplugging it for a few minutes if you want, but as long as temp stays at 16 or lower than 32, its fine............. a deep freezer are the ones that usually get alot colder than 32, but generally only because thats the systems only job, its not also running a refrigerator.
Nov 01, 2013 | Frigidaire FRS3R5EMB Side by Side...
What temp for freezer and fridge
About 5-10degrees below zero for freezer and about 4 degrees above zero for fridge.
Sep 16, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
What temp should the fridge and freezer each be?
According to FDA safetey specs bacteria can grow at 40 to 140 F degrees .Refrigeration must be below this number but above 32F to keep from freezing. I maintain commercial refrigeration and they run at 34 to 38 F degrees. I have deep freeze set at -10F which keeps ice cream very solid but can go up to +2 F which renders softer ice cream...
Jun 25, 2009 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Deep Chest Freezer
Correct temperature for residential freezer for food is zero degrees Fahrenheit
Jun 07, 2009 | Kenmore Freezers
Refrigerator 50degrees; freezer 10degrees suspect fan outage/ge
I bought a wine cooler but I want to change the door I would prefare the door frame to be black
May 26, 2009 | GE Refrigerators
Freezer 28 degrees at full cold
that's good. It 's not a deep freeze.
May 01, 2009 | Refrigerators
The temperature in the freezer ~30 Degrees F
Condenser fan motor replaced. Refrigerator did not work either, so I got mistaken describing the problem.
Jun 09, 2008 | Whirlpool Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
