SOURCE: were is blower motor 1997 acura tl 3.2?
Check this link. May change your mind.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528008be4b
SOURCE: blower motor for a 1997 acura tl
Unless you are an expert do not even attempt this. This is one of the first things that they put into the car, it requires you take off the entire dash, drop down the steering column, remove multiple vents / ducts, remove the chiller, remove screws from inside the engine compartment. This is at least a 10 hr job if you are good.
SOURCE: how to remove door panel on 1997 acura tl
Follow this link. There is detailed step-by-step info here
Please kindly let me know if it works for you
Good Luck
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528008c18d
SOURCE: How to remove factory radio acura rl 99
the best and safest way to remove this radio is with the special tools that Acura made specifically for removing the radio. Any radio store or best buy can easily remove it for you. I hope this helps please rate this and thank you.
