Question about Panasonic Lands Phones
We have a Panasonic phone model N0. kxtsc7c. We get a dial tone but it will not allow us to dial out however, we receive calls on it. Should we replace the phone or do you have a solution? Thank you for your help in advance.
5 Suggested Answers
SOURCE: display blank, no keypad tones, Emerson EMG900 phone
you must use a ac adapter which the phone doesnt come with or 3 double A batteries
Posted on Mar 19, 2008
SOURCE: Phone problems
I'm unable to get a connection on my phone when i press the talk button is says connecting and then it states unavailable.
Posted on Sep 29, 2008
  • 1124 Answers
SOURCE: Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
Posted on Sep 17, 2009
  • 860 Answers
SOURCE: My phone says check Tel Line
Sounds like your telephone line might be dead. If you have a gray or tan telephone box on the outside of your house you can plug your phone in there to test the line. If you get dialtone then thrers a problem in your house wiring, if you don't get dial tone then the line is dead and you need to conact your telco provider.
Posted on Apr 14, 2010
Unblock phone calls from phone
need more details on problem.
do you have access to programming the pbx?
do you mean that others using the pbx cannot call?
are they allowed to access a dial tone, but cannot dial out?
Oct 13, 2013 | Panasonic KX-T7730 Corded Phone
Panasonic KX-TCD220E - pulsating busy signal for a few seconds then dial tone
If that pulsating tone is anything like what I sometimes here on my phone, then it has nothing to do with your phone. It's your telephone company telling you that there's unheard voicemail on their system. You'll need to contact your telephone service provider for instructions on how to access their voicemail system.
Apr 10, 2012 | Panasonic Lands Phones
My BT studio telephones are not working. No dialing tone on receiver. Dialing in goes straight to answer phone. Incoming line has been checked by my service provider and confirmed as OK. I have tried my N0...
The main socket has an external socket and an internal socket. When I plugged the phone into the internal/ primary connection the service was resumed. There must be a fault between the 2 points . I will have to get a Telecoms engineer in to fix it
Dec 15, 2009 | Lands Phones
Cannot get dial tone to make a call ane cannot receive an incomming call.o
Double check your wire from the wall to your base set.
Is it possible you have something 'off hook' and the phone company has turned the dial tone off? Look in the front of your telephone book for the procedure to check the service to the "De-Mark"
I hope this helps you
Sep 27, 2009 | Panasonic KX-TG1033S Cordless Phone
No dial tone
you may need to contact panasonic to get a servce center referral because the speaker is already damaged in your phone
Jul 25, 2009 | Panasonic KX-TG5632 Phone
Swicth from tone to pulse
1) When the phone is in standby mode, press and hold the caller id/menu key.
2) Press the vol/ / key three times to select Dial.
3) Press the select key to toggle between Tone and Pulse.
4) Press the end key or return the handset to the base unit to complete the setting. The handset returns to standby mode.
This phone also has a feature that allows you to use Pulse dialing to make calls, but allows you to switch to tone dialing for automated systems (like “Please Press 1 for English) here are the steps for that:
Initially make your call with the pulse dialing mode. Once your call connects, press
the */tone key. Enter the desired number. These digits will be sent as tone dialing.
Once the call ends, the tone mode is canceled and pulse dialing mode resumes.
Apr 06, 2009 | Uniden Cordless Phone
Conference Calling
If you have a flash button, you would use that to place the first call on hold and dial or answer a second call. If this is a single line phone in your home, you would have to have "Three Way Calling" feature with your local phone company. If you do, you could ask them what the dialable feature code is. It's possible they allow you to use your flash button, get dial tone and dial another person, when they answer, flash again to conference. If you don't have a flash button, they you would be using your Green or Off Hook button that you use to get your dial tone.
Apr 03, 2009 | Panasonic Lands Phones
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
