Question about Cisco 7912G IP Phone
CISCO 7912 Ip Phone,Red lights are continuously on.
I am using Cisco 7912 IP phone as my my Voip device by connecting internet cable,It was working fine since last one month,But now since yesterday I have noticed that Red light on the Headphone and Two round lights on the base set (Where headset sits) are continuously on in red color.If I turn the power of the phone off and turn it on again ,These lights goes off for 20 to 25 minutes and then come back on a continuous basis.Where as they used to turn on for a short period of time when I used to get the call or when I used to save the settings after new configuration .If anyone have an idea why it is like this?, My phone is still working fine.
Thanks.
I have seen this problem when there is no Voicemail, all old Voicemails deleted.
Posted on Jun 27, 2009
  • 48 Answers
Well, in most Cisco VoIP phones those lights are used to tell you if you have a voicemail. Have you checked your vm and cleared any new ones? This might be your issue ;)
Posted on May 18, 2009
Cisco 7960 turns it self off
Do you have a power block for the phone or are you getting power from a POE switch via cat5 cable?
How do you know you purchased a working phone? When was the last time the phone worked properly?
Any other information you can supply about your VoIp setup would help us troubleshoot the power issue with your phone.
Jul 17, 2012 | Cisco 7960 IP Phone
Cisco ip phone 7912 is not working. when conecting in LAN then it will not boot, while another same series ip phone on that LAn port works perfectly. Only red and green LED blink continue in...
If it is getting an IP address, goto that IP address and there you will be able to see some console messages. See if alternate TFTP is set and is going to a different CM server. If so change it to the ip of your CM.
Aug 17, 2017 | Cisco 7912G IP Phone
No dial tone on cisco 504G phone
to use an Ethernet phone you will need a VOIP supplier ( You will need to Google this for the country you are in ) . You will not be able to use it until you have these set up. Ethernet phones are not like a standard home phone which use your local exchange to route your calls they use servers on the internet to do that and route your call to landlines.
I hope this helps if so please give me a thumbs up
Jul 23, 2010 | Cisco SPA504G IP Phone
VOIP headset PlantroMX500i 72517-01 to use with Cisco IP spa504G
mx500i.gif MX500i 3-in-1 VoIP Headset Sorry your headset + phone combination is not currently listed in our database. Please contact Plantronics Technical Assistance Center to confirm compatbility
Versatile 3-in-1 Headset for Internet/VoIP, cordless and mobile calls
Part Number: 72517-01
Apr 21, 2010 | Radio Communications
Want to migrate fom sccp to sip protocol for cisco IP Phone 7912
Here's a great little document from Cisco directly, called "Converting a Cisco 7940/7960 CallManager Phone to a SIP Phone and the Reverse Process"
Easy to do, just follow the step-by-step directions.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_tech_note09186a0080094584.shtml
Jan 21, 2010 | Cisco 7912G IP Phone
Can I use a CISCO IP 7941 phone, that has been on a company network, in my home? Should it just work by plugging in a telephone connection and using the appropriate power supply? Is there programming that...
Yes, there is programming which would need to be removed. However, you would need a cisco call manager($800) at home. Unless of course you have voip in your home. then you could just set it to DHCP I'm assuming and then it should just work!
Jan 14, 2010 | Cisco 7940 IP Phone
Cisco IP Phone 7940 and 3com nbx as 3rd party SIP phones
Here are the instructions for configuring these units for 3cx
http://www.3cx.com/sip-phones/cisco-7940.html
http://www.3cx.com/sip-phones/polycom-soundpoint.html
Since the 3cx softphone worked well, I don't see why you couldn't configure each as for 3cx and make them work as well.
Dec 09, 2009 | 3Com NBX 2102PE IP Phone
7906G Home VOIP installation Problem
Then you need power adapter for Cisco 7960 IP phone ( -40V DC).
Cisco phones work best with Cisco, and sometimes ONLY Cisco switches.
One question which voice gateway you will use for your 7960 VoIP phone calls to go through ?
(AT&T probably supports only their IP Phones with special and usually hidden settings from end user)
Jan 17, 2009 | Cisco 7906G IP Phone
Cisco 7912 sip phone
Can you please make sure that you can ping the device - you might have a routing problem
Feb 28, 2008 | Cisco 7912G IP Phone
Cisco 7912G IP Phone Logo
2,935 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
