We unplugged our Maxtor basics 500GB to move it and when we plugged it in again it asked us to reformat it we can aford to lose the data but it doesn't seem to be taking a reasonable timt to do help!!!!
    Master:
  • 538 Answers
That is correct..re formatting takes quite a bit of time for that size hard drive..on the other hand, there is a method to plugging and unplugging from the desktop, prior to removing the usb cables..
Posted on Oct 14, 2008
Maxtor harddisc wnat to format error
If any of you still have these monitors, and wish to sell them, i am interested in finding some to use as spare parts if i can’t get them working. send email to elah4@zoominternet.net.
I have two of these that i have already repaired successfully.
Or if you would like to have me repair for you.
there is software to retrieve data from hard drives that have lost the table of contents because of power failure during a wright session, which usually causes this to happen. get the software and learn how to use it before doing anything else to the drive, any formatting or weighting to the drive will cause less chance to retrieve your data from the drive.
i have successfully done this on several external drives of my own. and just tor the fun of it i did a reformat and then by the use of software retrieved the data again afterwards, much to my surprise
you will need a extra drive wit space for the retreved data during this process. then you can transfer data back to original drive to use again.
Dec 21, 2009 | Maxtor OneTouch II external hard drive...
I have maxtor basic 500G ex works fine when I plug into old laptop with XP, but when I plug in to new laptop with Windows 7 it says I have to format drive..Why is this?
Try opening the device manager and changing device removal policy to "Better Performance" (remember to always safely remove the device afterwards or you'll likely lose data).
Also, verify that the partition type is recognized in Local Computer > Drive Management and the drive letter doesn't conflict with anything else.
Dec 04, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
My maxtor basics 500GB external hard drive was writing some music files from itunes when my son tripped on the power cable disconnecting it and knocking it from the coffee table to the floor (approx 18...
Try going through the initial install procedure again, but don't allow it to reformat the drive. These devices are quite fragile especially while reading or writing data, and yours' may be toast. If this is unsuccessful, there are data recovery firms that can retrieve some of the information, but are quite costly.
Aug 23, 2009 | Maxtor (L01F500) 500 GB Hard Drive
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Open external drive maxtor basic 500GB
it may be like the one i have which is a maxtor basics 1.5tb drive. There is only one screw behind the sticker. The rest is clips. This is the guide i used when opening the case.
http://www.computer-aid.com.au/blog/2009/02/17/how-to-take-apart-a-maxtor-basics-external-35-usb-drive/
Mar 28, 2009 | Computers & Internet
I recently purchased and downloaded Maxtor One Touch4Plus Backup faile and I get a message Of Parameter is incorrect to edit my settings backup log states "Destination is not accessible" All file "not...
please try reformat your maxtor external driver. use default allocation size wait for a minute after finish unplug the maxtor external, restart your pc and plug in your external see what happen and try again to backup your data from pc
Jan 29, 2009 | Computers & Internet
Maxtor basics 500gb PN-9NZ2A4-500 will not power up. cannot access data on the drive nothingh come up my scren I have the same problem. When i want to acces it , it says drive not formatted ? then i...
Use a differant HDD plug.
You may have a fault in that lead.
It may be that your power supply is too weak to power it, suggest upgrading another 250 watt of your current one.
Jan 14, 2009 | Maxtor Hard Drive
Power supply details for Maxtor 500 gb, external hard drive and ? manual
The PSU for my Maxtor 500Gb 9NZ2A4-500 drive is 12V DC, 2A rating, 2.1mm "plug" with centre "hole" as positive.
Regards, kbsguru
Nov 06, 2008 | Maxtor Hard Drive
Maxtor formatting
i have a maxtor my computer crashed and i lost my disk how do i get my pictures back
Oct 05, 2008 | Maxtor OneTouch A01B080 80 GB Hard Drive
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
