Question about Kyocera Office Equipment & Supplies
The "check waste toner box" msg will not go away!!
    Genius:
  • 2,120 Answers
Was inside of the bottle with soapy water
Look at the U shaped sensor that the bottle goes into...blow out.
Posted on Oct 14, 2008
What is the waste toner box
the waste toner box is where the left over toner on the drum/transfer belt is wipe away it is not able to be used again so it discards it to the waste toner bottle
Jul 08, 2014 | Kyocera Office Equipment & Supplies
Bizhub 550 error c2204
Waste toner motor. Remove the Waste toner box and transfer belt ensure the waste toner box is not jammed up and check the transfer belt toner removal section is OK. Also check the gears on the left side of the waste toner box is ok and the machine gears ok not jammed. could also have a jam in the internal tube that runs the old toner to waste toner box get a tech out to check
May 29, 2014 | Konica Minolta Office Equipment & Supplies
I get error message "waste
Open the right side door. there at the bottom is a long plastic bottle full of waste toner. If you have no spare bottle then carefully (dont create dust) empty toner into a bin liner. Now tap the bottle on the table to allow any toner on the sides to fall back to the bottom. now refit and all should be well.
May 10, 2011 | Lexmark C544dn Laser Printer
In the screen area I get a message saying" "waste
Your waste toner box might be full and needs to bre replaced. You can order a waste toner box for your printer at Lexmark.com
Here's the part number: C540X75G Please click on the below, this will show you how to replace your waste toner box. http://bitly.com/rkjxWz If you need further assistance, please contact Lexmark Technical Support Center.
Jan 17, 2011 | Lexmark C540N PROD SPECS TBD Printer
Lexmark X543 --Getting msg Waste toner box near Full. What is required ?
very simple there is a waste toner bag that came with your Lexmark X543, so you need to remove it and dispose of the toner inside and replace exactly the same you took it and the message will message will disappear
Jan 12, 2011 | Office Equipment & Supplies
I have replaced the waste toner box but still getting error msg
clean all the area of the drum unit (waste toner box side ) . and check it........
if you have anothe same printer inter change the drum unit....... repalce the drum unit ......if not working change the sensor board.......
Nov 05, 2009 | Kyocera Mita FS-3830N Laser Printer
I have a message that says "waste toner box almost full" I cannot find the waste toner box. can you tell me where it is? The copier is a Kyocera KM-8030. thank you Frances
After looking on the net if your printer is under warranty, you should call Kyocera Service Rappresentative or an Authorised Service Centre as Kyocera is not releasing how to empty or clear the waste toner box and if you do you will woid the warranty.
Dec 02, 2008 | Office Equipment & Supplies
Panasonic DP-1810P Laser Copier
The copier has an "eye" that detects when the waste toner bottle is full. If you dump it and reuse it, the residue can build up and cause the machine to "think" the bottle is still full. I experienced the same problem. If you re-use an old bottle, after emptying, rinse our any remaining residue and dry the bottle out. Your copier should then notice the bottle being empty.
Mar 14, 2008 | Panasonic DP-1810P Laser Printer
102 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
NewYork kyocera HP...
Soulvisitor
Soulvisitor
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
