Question about Refrigerators
Our samsung rs21wcns american fridge freezer is making a loud noise which stops when opening door
Our american fridge freezer has developed a loud vibrating noise and the twin cooling light has come on permanently and we cannot find our manual
  • Anonymous May 14, 2009
    I have the same problem. Samsung side by side fridge freezer with ice and water dispenser. Loud vibrating noise coming from the back of the fridge. Also noticed that the water dispenser stopped, then all of a sudden a couple days later it was working. Have pulled the fridge out and is really loud behind the fridge. Any help would be MUCH appreciated. Thanks in advance :)
5 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor
Check fan motor for continity IF none replace fan motor
Posted on Oct 12, 2007
  • 958 Answers
SOURCE: samsung side by side refridgerator making noise and freezing
its a heater cycle problem..the defroster is not working properly. its building up ice in the evaporator that touches the evaporator fan that makes that loud noise but stops when you open a door. it could be either a bad heater, a bad thermo disc or a bad timer.hope i was able to help
Posted on Feb 12, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
  • 22 Answers
SOURCE: frigde wont get cold but freezer does.
I am an authorized Samsung service center, and I have dealt with this ongoing design problem for years. The problem occurs when the unit comes out of the defrost cycle, not all of the frost has been removed by the defrost element and an ice bridge occurs at the top and bottom evaporator coil. There are sensors that send readings back to the main PCB during and after this cycle, They have to be replaced along with adding heat transfer clips for better frost meltage and air circulation.
Order the following parts through Samsung:: Fixer # DA61-03585A, Plate # DA61-03502A, Thermal Bi-metal # DA47-10160H, Sensor # DA32-00006W. Have these parts installed by a professional appliance repair company.
I hope this will fix your dilemma, Ward Appliance Repair.
Posted on Dec 29, 2008
Samsung refrigerator loud noise
if the fan is still running when you open the door , the I would be leaving that idea as a last resort
try this
get 2 taper door chocks and put one either side at the back of the fridge
push the cabinet sideways and slip one chock in a bit then do the other side
many noises are from the bottom plate that the compressor is mounted on from tapping on the floor and lifting it a bit stops the noise
the same as when you open the door the pressure on that plate is removed and so it stops hitting the floor
Nov 04, 2015 | Samsung RS261MDWP - 26 cu. ft. Side by...
Fan is making a loud noise. When I open the door, the fan stops.
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Apr 23, 2011 | Samsung RF265AA Bottom Freezer French Door...
I have a samsung fridge freezer model no RSH1DTMH and the fridge will not go lower than 13degrees and the freezer and water dispenser seem ok. The fridge freezer is only 3 years old. Any ideas/
We had the same fault on our Samsung American style RSH1DBRS fridge freezer as lots of other people seem to be having. After doing lots of research, we found the best solution seemed to be to buy a repair kit from Appliance DIY Repairs. The instructions were fantastic and the installation was a doddle. Excellent service & well priced.
Jan 19, 2011 | Samsung RS2630SH Side by Side Refrigerator
Constant and fairly loud noise
thats typically an air circulating fan thats either faulty or something is touthing the blade. open up and see.
Jan 09, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Whirlpool 20RB D4 Fridge Freezer clicking
Hi the reason for your noise coming from the fridge freezer is the plastic that is used in the design of your product is of a low quailty which reacts to the temp change and then as they get cold again they start to crack inside the frigde! Nothing to worrry about........
Hope this helps.....
Dec 23, 2008 | Freezers
Loud noise from the freezer side
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung american style fridge/freezer needs repairing
Spray a good quantity of WD-40 on the spindle of the fan motor where it enters the motor itself. This should get the fan working smoothly with no noise. This will probably solve the other problems, as the fan prevents various components from overheating and shutting down.
Apr 01, 2008 | Refrigerators
Samsung side by side refridgerator making noise and freezing
Feb 12, 2008 | Refrigerators
Refrigerators Logo
638 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
