I'm getting this error code ( 0xeb020b88) when I'm trying to copy a cd.
  • 4 more comments
  • MattnLinda99 Oct 16, 2008
    I'm using Power2GO5 version 5.6.3917 which I downloaded from the website allowing it to be used on Vista. I am receiving this same error message near the end of the DVD burn.
    Elsewhere someone else suggested...
    "Make sure you have the latest XP SP2-compatible version of Nero."
    There are patches available but not for my version.
    Power2Go
    http://www.cyberlink.com/multi/download/...
    I'm still working on a solution any input would help out Thanks!
  • urraka_paka Dec 08, 2008
    Hi! Excuse me for my English. I'm writing from Spain and I have the same problem, error 0xeb020b88 when I use dvd shrink and after that power2go. I work on a hp laptop, Vista, and I've burned some wrong dvds yet. Do you know if this is a software or hardware problem? Maybe the discs?
    I dont' know much about computers but I've bought this one little time ago and this is the first time that I have a problem like that...
    Would you help me, please?
    Regards,
    Ana
  • karthik2020 Jan 02, 2009
    I am facing the same problem.I have a HP laptop with Microsoft Vista. I am getting the error message Burning Failed, ERror Code: 0xeb020b88 whenever I try to write a DVD. Can anyone suggest a solution to this?
  • Anonymous Jan 21, 2009
    Same problem - can't burn a DVD or CD, hardware NOT an issue, Using Nero, everything burning fine, then all of a sudden couldn't burn CD's or DVD's tried other software same thing, changed the drive, same thing..Drives and media work on my other pute..Checked DMA transfer selected..Might be XP.
  • Anonymous Mar 03, 2009
    this is what i've up with.. dvd's will not burn at all, so i burn on Cd's....with no errors whatsoever, regardless of the files...whether music, movies, games or programs. It has something to do with being unable to burn onto Dvd...even though I have the dvd/cd drive burner.
  • Puneet Jain
    Puneet Jain May 11, 2010
    Do you also getting the Data redundancy error?
    Is the error coming up with one CD only and with that CD in all PC ?
    Let me know are you copying the CD to CD or CD to Hard Disk, or else Hard Disk to CD (Burning)
    May be your Cd content is corrupt.. otherwise check the CD/DVD rom with a fresh CD and try to copy it.
Dude,Its very simple. Its nothing to worry. You havent used your DVD drive so frequently. There might be dust, debris or other contaminants from the laser lens that may cause skipping while write process. Get PHILIPS DVD Lens cleaner and run it once. Your problem will be solved.
I was facing the same problem for a weeks time, when my friend suggested me this.It worked well.
Posted on Jan 30, 2009
Error Code : 0xeb020b88
AnsWer is Please Clear Your writer Lance By "Leance clener CD"
It's work 100 %
I m Mohammed Hasan
Cleaning the DVD recorder helped me as well....
I had a can of compressed air, I blew the air inside cover every inch and the next time I tried to record, it worked.
Posted on Feb 16, 2010
Hello!
Error Code : 0xeb020b88 is my problem with a new LG Super multi blue /external Blu-ray Disk Rewriter BE08LU20 and LG BD-RE made in Korea. My solution is the change of media. BD-RE Mr. Data made in Taiwan works well
I have this problem with a LITE-ON external DVD/CD rewritable drive model eSAU20816 2 made in China. This rewriter works well with Sony DVD-R, but not with Verbatim DVD-R media.
Solution: Change the media.
Posted on Jan 31, 2010
  • Miroslav Balchev Jan 31, 2010
    Hello!
After reading the post about lens cleaning and debris by karthik2020 I took some of my Camera Cleaning Supilies , A dust blower (air bulb) and blew off the lens to clear debris the ran a lens cleaning cloth over it a few quick swipes and Bingo Bango it was purring like a kitten and burning like bran new instanly. Thanks a ton for the great help karthik2020 your advice helped me to come up with this solution that worked like a charm.
Posted on Jan 18, 2010
  • mysticwevar Jan 18, 2010
    that or a disk cleaner will fix this problem in no time flat
    Guru:
  • 558 Answers
Reply on the previous email, and try to boot in BIOS with tapping F2, DEL or ESC key
In BIOS change the Boot Priority, let me know if you need further help.
Dont vote till you get the solution.
Regards Ellin
Posted on Oct 15, 2008
  • Puneet Jain
    Puneet Jain Oct 18, 2008
    For burning DVD/CD i would recommend use of NERO 8.0 version.
    Otherwise try simple copy directly to the CD Rom folder and then click on Write these files do CD
    Let me know if it work for you, else I will give you some another solution.
    New Friend:
I was getting this error when the source was not readable. I had files that I could not even copy normally, let alone burn. I was getting CRC errors. I restored these broken files and tried again, and burn was successful.
Posted on Nov 23, 2012
There may be a problem with the external usb not getting enough power. I have an external usb slim drive that comes with TWO usb connectors. the extra usb connector is used to draw in additional power form the usb port. When, I connect both usbs to the same pair of usb slot (next to each other) on the computer, I get the error. When I connect each usb to a separate usb slot that is far away from each other on the computer, then i get no error. Since I am drawing power from two separate usb ports that are on two different pair, I have no problem.
Posted on Aug 18, 2011
I couldn't burn a dvd. Was using DVD-R 16x
changed to DVD+R 16x - burned first time
Posted on Jun 17, 2010
  • Tin GO Sep 30, 2010
    I was trying to burn my audio files in a cd and it just flips out three times in a row...
    and this is what it says... I need help..
    User Name : HP
    Company Name : Hewlett-Packard
    CDKey :
    OS Version : Vista Personal
    C:\Program Files\CyberLink\Power2Go\Power2Go.exe : Version 5.60.3327
    CBS.dll : Version 7.7.2111
    Total physical memory : 1982MB (2029888KB)
    Free physical memory : 1006MB (1030296KB)
    Memory load : 49 percent
    Number of CPU : 2
    CPU Name : AMD Turion(tm) 64 X2 Mobile Technology TL-58
    CPU Speed : 1900 MHz
    30.9.2010
    Task Type : Audio CD
    Track list :
    Track 1, Duration:04:12.66, Pause sectors : 150, Name : 01 One Day.mp3
    Track 2, Duration:03:44.34, Pause sectors : 150, Name : 02 Faith.mp3
    Track 3, Duration:04:52.54, Pause sectors : 150, Name : 03 Awesome In This Place.mp3
    Track 4, Duration:03:59.14, Pause sectors : 150, Name : 04 Dwell In Your House.mp3
    Track 5, Duration:06:08.86, Pause sectors : 150, Name : 05 You Are Near.mp3
    Track 6, Duration:05:40.02, Pause sectors : 150, Name : 06 I Simply Live For You.mp3
    Track 7, Duration:05:41.41, Pause sectors : 150, Name : 07 Carry Me.mp3
    Track 8, Duration:03:19.16, Pause sectors : 150, Name : 08 Lifted Me High Again.mp3
    Track 9, Duration:03:46.66, Pause sectors : 150, Name : 09 Here To Eternity.mp3
    Track 10, Duration:07:28.74, Pause sectors : 150, Name : 10 For This Cause.mp3
    Track 11, Duration:06:38.26, Pause sectors : 150, Name : 11 Reaching For You.mp3
    Track 12, Duration:07:06.46, Pause sectors : 150, Name : 12 It Is You.mp3
    Track 13, Duration:05:20.74, Pause sectors : 150, Name : 13 Believe.mp3
    Track 14, Duration:05:51.32, Pause sectors : 150, Name : 14 Everyday.mp3
    23:10:44, File(cl_CDDABurning.cpp), Line(27)
    -> Begin burning process
    Current drive:
    Current writing speed(x): 24.0
    ====== Disc Info =======
    Disc Type: CD-R
    Disc Status: Blank, Appendable
    Num. of Sessions: 1 Num. of Tracks: 1
    Disc Capacity: 359844LBs
    Free Size: 359844LBs Used Size: 0LBs
    Burn mode: DAO
    Burn option: w/ buffer underrun protection
    Burn option: w/o simulation
    Burn option: w/o overburn
    Burn option: w/ close disc
    Burn option: w/o CD-TEXT
    Burn option: w/o verify disc
    Burn option: w/o extra long disc
    23:10:44, File(cl_Cdwrite.cpp), Line(2659)
    -> Setup drive
    Sessn: 1, Sessn type: Disc At Once
    Disc physical format: CDDA
    Trk: 1, Trk mode: CDDA
    Trk: 2, Trk mode: CDDA
    Trk: 3, Trk mode: CDDA
    Trk: 4, Trk mode: CDDA
    Trk: 5, Trk mode: CDDA
    Trk: 6, Trk mode: CDDA
    Trk: 7, Trk mode: CDDA
    Trk: 8, Trk mode: CDDA
    Trk: 9, Trk mode: CDDA
    Trk: 10, Trk mode: CDDA
    Trk: 11, Trk mode: CDDA
    Trk: 12, Trk mode: CDDA
    Trk: 13, Trk mode: CDDA
    Trk: 14, Trk mode: CDDA
    23:10:44, File(cl_Cdwrite.cpp), Line(1951)
    -> Start session
    Sessn: 1, Start trk: 1, Last trk: 14
    23:10:44, File(cl_Cdwrite.cpp), Line(1977)
    -> Start track
    Trk: 1, Track start addr(LBA): 0, Trk size(sectors): 18948, Sector size(bytes): 2352
    23:12:02, File(cl_Cdwrite.cpp), Line(2195)
    -> Write end track
    23:12:02, File(cl_Cdwrite.cpp), Line(1977)
    -> Start track
    Trk: 2, Track start addr(LBA): 19098, Trk size(sectors): 16824, Sector size(bytes): 2352
    23:12:27, File(cl_Cdwrite.cpp), Line(2195)
    -> Write end track
    23:12:27, File(cl_Cdwrite.cpp), Line(1977)
    -> Start track
    Trk: 3, Track start addr(LBA): 36072, Trk size(sectors): 21939, Sector size(bytes): 2352
    23:12:37, File(cl_Cdwrite.cpp), Line(2396)
    -> Write end/Close disc
    23:12:37, File(cl_CDDABurning.cpp), Line(405)
    -> Burning Fail, ErrCode: 0xeb020b88
2 Suggested Answers
  • 194 Answers
SOURCE: error code: 0XEB020B88
do the following
Open Notepad (START>>>RUN>>>type in notepad)
Hit OK
Copy the contents of the CODE box, not including the word "code"
Paste it to the empty Notepad file
In Notepad click FILE>>SAVE AS
Change the Save as Type to All Files.
Name the file as Export.bat
CODE regedit /e Export.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}"
Double click on Export.bat, a text file called Export.txt
should produce on your desktop
Copy>>paste back here the contents of Export.txt
Posted on Jun 23, 2009
Hi, What does Error 235 (19)mean. I keep getting that when I try to copy a 120 minutes DVD.
It means your driver to your DVD/CD is missing you will need to download a driver or reload to fix this problem......try ..................http://www.driverfinderpro.com/lp/error/s-fix-device-code-39-errors.php hope this helps
Jan 27, 2015 | Computers & Internet
I can't able to burn a mp3 cd n errer code is 0xeb020b88
This is a hardware defect of your burning device. Please contact the manufacturer for technical support.
May 22, 2011 | Computers & Internet
Faulty Burner or Optical Drive...
Mar 31, 2010 | Lenovo 3000 Y410 Laptop
Trying to copy DVD data discs to hard drive, some work, many fail with unable to read errors part way through. Tried copy and paste, drag and drop, tried the Power2Go that came with the HPVista64 bit...
The first thing I thought of is that the discs could be scratched, but I doubt that's the problem.
Another possible problem (although unlikely) is that the discs themselves are bad. Sometimes they come with bad sectors, and don't always work.
Next idea could have to do with the burning process not being as perfect as it could. This could either be because of other tasks running during the burn, or burning at a too high speed.
I see that you said you've replaced the drive, so that pretty much rules that out. However, I do have one last suggestion that may help.
I've found that quite a few people have had problems with the Power2Go software, and that may very well be the culprit.
I suggest you download CDBurnerXP from HERE and try burning another disc. Make sure that when you do it, you have as few processes running as possible and do it at one of the lowest speeds possible. Oh and even though the program has "XP" in the name, it still works on Vista,7, etc.
Hope this helped :)
Nov 28, 2009 | HP HDX16t Premium Series Notebook
Error code: 0XEB020B88 when I try to burn music CD's with cyberlinkDVD suite
do the following
Hit OK
Jun 23, 2009 | Computers & Internet
I'm getting this error code ( 0xeb020b88) when I'm trying to copy a cd. when i insert data disc in the driver it shows disc is empty........
This is often caused by a 1st generation DVD-rom. If the drive is a standard DVD-rom and not a cd burner then i would recommend replacing the drive with something more updated and it will usually take care of the issue. other wise is it possable that the cd that you are trying to copy has copy protection on it? if so that could be causing issues.
Mar 20, 2009 | IBM Computers & Internet
Disk or software error
You may be copying discs that have Digital Rights Management, or DRM encoded on the disc. You should have "burn rights" before trying to run copyrighted material...accordianman
Jun 13, 2008 | KLH CDR2000 2-Disc CD Recorder
Error code 6 & error code 4
hi try first to insert a clean up CD, and test your Cd player with an original CD, if the problem persist , your laser sense is defficient you have to go to fix it to a specialist.
hope this helps you
sserpentio
May 21, 2008 | Clarion DXZ438R CD Player
Computers & Internet Logo
17,217 people viewed this question
David Payne
David Payne
