Question about Sony LBT-D670AV Shelf System
Protect, press power
My sony music centre comes on, then after 10 seconds or so gives out this message and the only thing that can be done is press it off....anyone got any ideas????
    Genius:
  • Sony Master
  • 1,550 Answers
Audio amplifier IC damaged need to be replaced
Posted on Feb 11, 2009
Push Power Protector - Sony MHC-VX777 I am getting Standby message and push power protector .My music system was not operated
Hi!
This is what the manual says:
PROTECT"and "PUSH POWER" appear
alternately.
•A strong signal was input.
Press ?/1 to
turn off the power, leave the system
turned off for a while, then press ?/1
again to turn on the power.
•Check the speaker cables in case
"PROTECT" and "PUSH POWER"
appear alternately again after you turn
the system on.
Jun 05, 2017 | Sony Audio Players & Recorders
I have a Sony Vaio model #pcg-71511L boyfriend was downloading from ITunes he thought it was done and removed cd and put new one in and system froze up cannot even turn off to re-boot or anything
Press the power button down for five to 10 seconds and then restart it.
If this helpful, please give a testimonial and vote by pressing button four thumbs up icon.
Sincerely Thiyaga
Aug 28, 2011 | Sony Computers & Internet
On my MP3 player the start up screen Every moment has its music appears but does not advance. How do I reset so it will advance and play my music?
http://www.retrevo.com/support/Sony-NWZ-S545-MP3-Players-manual/id/23542dj091/t/2/
Possible solution #1: power on the unit and press and hold the reset button for 5 seconds. Then, power off the unit for about 5-10 minutes. Power it on, try the music transfer again and see if you can play it.
Possible solution #2: head to the NWZ-S545 product page and update the unit's firmware. When that is done, reset it and then try to transfer and listen to your music.
If these techniques fail, then I would probably just take it back to where I bought it from and exchange it for a new one. If you are beyond the retail return period, but within your product warranty, call Sony technical support and have them arrange for a warranty replacement.
Jun 28, 2011 | Sony Network Walkman NWZ-S545 Digital...
My psp still shows everything is getting power, but my screen wont come on
  1. Remove the battery from the left side of the PSP while it is still on. The unit will power down instantly. Wait 10 seconds and then replace the battery.
  2. Press both clear shoulder buttons at the top of the PSP and keep them held down while the PSP reboots. This initiates a "Recovery" mode.
  3. Press down on the control pad to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and podcasts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
Hope this helps, give me a good thumbs up please!
Aug 23, 2010 | Sony PlayStation Portable (PSP) Console
I am using view sonic monitor & i am facing a problem with it .At the centre of the screen there is a message in blue colour filled box that"osd lock"its irritating
OSD and Power Lock Settings
• OSD Lock: Press and hold [1] and the up arrow 􀁓 for 10 seconds. If any buttons are
pressed the message OSD Locked will display for 5 seconds.
• OSD Unlock: Press and hold [1] and the up arrow 􀁓 again for 10 seconds.
• Power Button Lock: Press and hold [1] and the down arrow 􀁔 for 10 seconds. If the
power button is pressed the message Power Button Locked will display for 5 seconds. With
or without this setting, after a power failure, your LCD display’s power will automatically
turn ON when power is restored.
• Power Button Unlock: Press and hold [1] and the down arrow 􀁔 again for 10 seconds.
Well this Should resolve ur issue
May 13, 2009 | ViewSonic E70fb 17" CRT Monitor
Protection Light Comes on
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Mar 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
WACS700/05 Wireless Music Centre will not Boot up
tried to hold source and stop got message firmware damaged retriving copy from backup. power turn off, hold down source only power on comes up booting up please wait but in the lite up mode, 30 seconds later everything back on
Aug 20, 2007 | Philips WACS700 Shelf System
Problem with turning my system on....
whan a unit goes into protect, it could be a bad speaker, shorted speaker wires. or the most common fault is a blown audio o/p ic in the unit. due to being compact units they are more difficult to work on than the full size unit. the part typically runs between $25.00 to $75.00 usd. if you are good with working on small places and are good with soldering give it a try. the ic will be on a heatsink. good luck.
Jan 31, 2007 | Sony MHC-ZX10 CD Shelf System
Sony lbt-x5g500
Power protect tends to mean the main power amp chip has "blown" and needs to be replaced. It only costs about 20 dollars (10GBP). If you are handy with a soldering iron it is easy to do (after you get the thing to bits !) It is the big black thing on the big heatsink inside. The Sony part number is STK442 - 130. Seems a waste to throw the whole thing away for the sake of 10 pounds !. Hope this helps. Nik Howell (nh@totalise.co.uk)
Oct 13, 2006 | Sony LBT-XG500 Shelf System
83 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
